32 minutes ago, NLWaard said:
Does anyone know how I can pick up the call from that QA  refresh
i hope all commands from UI passed via HTTP RPC calling,.
1) you can peep the command in ypur browser by F12 developent mode
2) grab events via refreshState
Jan,
I download and installed ICalendar.
I see two items under the refresh button>>>> Nice QA!
The name of the item I have placed behind >>>#start:xxxx (Not available)<<<< Remark there is a space between xxxx (Not available) That I cant change.
In ER scene:
Rule.eval([[#start:xxxx (Not available) =>
        woonKamer.wcdPlug:on; log('if calendar gives Not  available wcdPlug - On')
Plug will not be on.
What I am doing wrong?
How fast the calendar is refreshed if push the refresh button?
Please advice
//Sjakie
    10 minutes ago, Sjakie said:
    Jan,
    In ER scene:
    Please advice
    //Sjakie
    The iCalendar will post the calendar event as a fibaro custom event.
    The problem is that I try to name the event '#start:xxxx (Not available)' which is not a valid event name.
    If you had just '#start:xxxx' you could have triggered it in ER as
    rule("#custom-event{name='xxxx'} => ...")
    The QA was written in February - I will have a look at it during the weekend if it can be "modernised" a bit...
    Guest kallecux
    SONOS-QA-Question:
    Hi there, if i use this syntax:
    i get:
    Any hint?
    Greetings Karl Heinz
    53 minutes ago, kallecux said:
    SONOS-QA-Question:
    i assume the QA from @10der, in my QA Sonos Player i haven't implemented stream info (because i don't care about that - i wish just to play).
    When i need more, then there is QA from @Krikroff which can catch such things properly.
    Guest kallecux
    Hi @tinman, yes it is the QA from @10der - i take a look at the solution from Krikroff.
    Thanks!
    @kallecux btw, Fibaro still unimpkement main (as for me) thing
    1) we can`t definde user (custom) properties.
    ( more clear: I want to add and use in Generic (and not on;y generic) QA
    here user/custom properties
    /monthly_2020_10/image.png.0d9c5a7ef7406b03f083fd5d2a38c869.png" />
    2) please make able to get result of fibaro.call
    yes I know what this function is asynced and we can get only Succ ro not succ resut,
    but we want to get response result in some cases!
    please!
    @A.Socha
    Edited by 10der
    Guest kallecux
    Hi @10der
    In Germany there is a saying if you don't understand a thing: It goes like this: I only understand "train station" -> Ich verstehe nur "Bahnhof"
    What do i have to do?
    Greetings!
    @kallecux idk :( you can use QA from Kri, but idl how you can get track info. maybe via reading QA labeL
    Ok, I have "modernised" the
    The original idea was that the QA would emit custom event with names from the the calendar event title or special tags in the description. That way one could make block scenes that reacted to calendar events. However, due to how custom-events work, it's not a great idea as custom-events can "overwrite" themselves as they need to be predefined before we can emit them...
    Anyway, besides custom-events, the new QA publish the event at start and end of the calendar event - using the QA_toolbox pubs mechanism. ER4 scenes can subscribe to pubsub events.
    These rules subscribe to 'iCAL' events and then a rule that logs start events.
    The QA publish an event when the it starts and when it terminates. The 'status' key is either 'start' or 'end' depending on.
    The full event have this structure:
    endDate and startDate is unix.time for the start and end of the. event.
    You could match on the title or the. descr field to trigger actions in various ways...
    Jan,
    Just started HC3 downloaded your file
    add as QA error:
    //Sjakie
    I'm getting error:
    HTTP Error:"Operation not supported"
    Can't figure out what am I doing wrong.
    Jan, sorry something with Firefox??
    Download again with Chrome restarted HC3 and its accepted
    //Sjakie
    btw I see calendar Items
    Uploaded in Firefox; no probs at all
    1 hour ago, Bodyart said:
    I'm getting error:
    Is your iCal URL correct?. You use iCloud or Google calendar?
    Example.
    We mark in the calendar what time the sauna should be on. In the description field we have the keyword "SaunaON" somewhere.
    We then trigger on the start event. We check if the description contains the keyword SaunaON and then turn on the sauna.
    ...and then we trigger on the end event, and turn off the sauna.
    If we just want to turn on the sauna at a given time we of course skip the last rule.
    Just realised that this post should have been in the EventRunner thread.
    I use Google calendar and i'm using the same URL as in previous version iCalendar (v0.1), where it worked correctly..
    CALURL = "https://calendar.google.com/calendar/ical/xxxxxx%40gmail.com/private-ffffffffffffffffffffffff/basic.ics"
    Ofcourse with correct credentials...
    If you paste the url into the browser does it download the calendar?
    I had to change:
    if CALURL then self:setVariable(CALNAME,"Joe",CALURL) end
    to
    if CALURL then self:setVariable(CALNAME,CALURL) end
    Ah there is a bug in the code.
    At the end of the "main" file
    Change
    to
      if CALURL then self:setVariable(CALNAME or "Joe",CALURL) end
    I assume that you have set CALURL and CALNAME?
    2 minutes ago, bgoldie said:
    I had to change:
    to
    You beat me with 30s :-)
