    8 minutes ago, ChristianSogaard said:
    No - getting this
    [11.11.2020] [14:21:01] [DEBUG] [QUICKAPP812]: Can't install groups:20-Skrivebord
    [11.11.2020] [14:21:02] [DEBUG] [QUICKAPP812]: Can't install groups:24-Spisebord
    From the List UI
    [11.11.2020] [14:22:53] [DEBUG] [QUICKAPP812]: Group id:20, name:Skrivebord, type:Zone
    [11.11.2020] [14:22:53] [DEBUG] [QUICKAPP812]: Group id:13, name:Viktualierum, type:Room
    [11.11.2020] [14:22:53] [DEBUG] [QUICKAPP812]: Group id:22, name:Arbejdsværelse, type:Room
    [11.11.2020] [14:22:53] [DEBUG] [QUICKAPP812]: Group id:25, name:Test, type:Room
    [11.11.2020] [14:22:53] [DEBUG] [QUICKAPP812]: Group id:24, name:Spisebord, type:Zone
    Can you try 1.9 that I uploaded. I found out how to do a zone (never noticed that option before in the Hue app) and I managed to install my new Zone.
    Zones installed Successfully as groups
    • Installed groups:20-Skrivebord
    • Installed groups:24-Spisebord
    ? I'll test later when I home if its actually turns on the light - but I would expect that - Zones is like having a group in a group. Nice Feature ;-)
    I Uploaded ver 1.9 - redeployed all Bulbs "toggle" is working for Bulbs in my office -
    Dimming dont work at all
    [11.11.2020] [15:58:42] [DEBUG] [SCENE119]: Calling 904 Params: ["stopLevelChange"]
    [11.11.2020] [15:58:59] [DEBUG] [SCENE119]: KeyId: 1 KeyAttr: HeldDown
    [11.11.2020] [15:58:59] [DEBUG] [SCENE119]: Calling 883 Params: ["startLevelIncrease"]
    [11.11.2020] [15:59:02] [DEBUG] [SCENE119]: KeyId: 1 KeyAttr: Released
    [11.11.2020] [15:59:02] [DEBUG] [SCENE119]: Calling 883 Params: ["stopLevelChange"]
    [11.11.2020] [15:59:05] [DEBUG] [SCENE119]: KeyId: 2 KeyAttr: HeldDown
    [11.11.2020] [15:59:05] [DEBUG] [SCENE119]: Calling 904 Params: ["startLevelIncrease"]
    [11.11.2020] [15:59:08] [DEBUG] [SCENE119]: KeyId: 2 KeyAttr: Released
    [11.11.2020] [15:59:08] [DEBUG] [SCENE119]: Calling 904 Params: ["stopLevelChange"]
    [11.11.2020] [15:59:09] [DEBUG] [SCENE119]: KeyId: 2 KeyAttr: Pressed2
    [11.11.2020] [15:59:09] [DEBUG] [SCENE119]: Calling 904 Params: ["setValue",99]
    [11.11.2020] [15:59:14] [DEBUG] [SCENE119]: KeyId: 2 KeyAttr: Pressed
    [11.11.2020] [15:59:14] [DEBUG] [SCENE119]: Calling 904 Params: ["toggle"]
    [11.11.2020] [15:59:16] [DEBUG] [SCENE119]: KeyId: 2 KeyAttr: Pressed
    [11.11.2020] [15:59:16] [DEBUG] [SCENE119]: Calling 904 Params: ["toggle"]
    Using this
    Edited by ChristianSogaard
    I see that you have a short time between hold down and release - are you sure you have time to see the dimming effect. Hold it down for 10s and see if you notice.
    The toggle is strange as I have no problem with any of my devices (toggle is just alternating turnOn/turnOff)
    If you look at the QA log - do you see "onAction toggle <child deviceID>"   when you press the toggle button?
    I'm sorry - Toggel IS WORKING - for all Bulbs. I change my text twice and didn't check the meaning before submit??
    What i tried to say - Dimming is NOT work for any bulbs
    Here trying for 10 Sec
    [11.11.2020] [17:26:54] [DEBUG] [SCENE119]: KeyId: 2 KeyAttr: HeldDown
    [11.11.2020] [17:26:54] [DEBUG] [SCENE119]: Calling 904 Params: ["startLevelIncrease"]
    [11.11.2020] [17:27:03] [DEBUG] [SCENE119]: KeyId: 2 KeyAttr: Released
    [11.11.2020] [17:27:03] [DEBUG] [SCENE119]: Calling 904 Params: ["stopLevelChange"]
    To precise the Dimming Behavior
    if a Bulb is turned ON - holding for 10 sec - Nothing Happens
    if a Bulb is turned OFF - holding for 10 sec - Light turns ON 100% efter 2-3 sec, No dimming
    Is there anything I can do to make it easier for you to debug? - or if its my setup that is f.... up. Where to start? - Should I try setting up a new HUE GW in parallel with a few bulbs ?
    When dimming up and the bulb is turned off it starts by turning on the light and then starts to dim
    When dimming down and the light is already off, nothing is done. So it needs to be ON to dim down.
    Somehow your bulbs don't like the dim command. I send a set brightness to the Hue bridge (bri=X)  for the lamp and set the transition time to the time it should take to reach that brightness level. The bridge is then expected to handle the "dimming". It works for all my lamps Extended, temperature, and white dimming light - and it's really smooth.
    To stop the dimming a bri_inc=0 is sent to the bridge that stops any transition.
    So, is it correct that it's only your color temperature lights that don't work?
    Can it be that they are of a version that doesn't support brightness transition commands?
    If so, I could make a version (the code is already there) that dim the old way by setting new brightness values in a loop. It's not as smooth but it will work.
    Somehow your bulbs don't like the dim command. I send a set brightness to the Hue bridge (bri=X)  for the lamp and set the transition time to the time it should take to dim. The bridge is then expected to handle the dimming. It works for all my lamps Extended, temperature, and white dimming light - and it's really smooth.
    So I tried structure my testing.
    Dim dont work - I saw dim was working "non linear" before introduction the dimstep variable.
    In V1.9 - i cant get it working at all.
    The LWB006 Bulb is really buggy, i can just replace it. Dim and double klik is more important imo?.
    /monthly_2020_11/image.png.fa3e565783a437a07a4b2d60a3904b50.png" />
    I went down and bought a second Hue Starter Kit - and installed a second ChildrenOfHue Ver1.9 instance connected to the new gateway with One bulb connected - (ambiance and Color) com.fibaro.philipsHueLight / LCT015
    /monthly_2020_11/image.png.4370681f9cd65f73fca91f1a850c7587.png" />
    Ready for some more testing :-)
    For new Gateway with one Bulb - (ambiance and Color) com.fibaro.philipsHueLight / LCT015
    • DoubleClick Dont work.
    • Dim Dont work
    • Toggle works fine
    Ok, lets debug.
    Create a scene with this code. Uncomment one test at the time and note the debug out and how the lamps behaves.
    You could maybe trigger the scene with some button so you can be in the room where the bulb is located?
    Edit: update with you new bulb IDs
    Added setValue 99 and 25 to test the setValue function
    • Dim Dont work
    • Toggle works fine
    The LCT015 is a "Extended color light" - I have 8 of these and they have always worked for me.
    I suspect the double-click is from the scene? and it should set the brightness to max? It could be something with the scene.
    Dim maybe also something with the scene... Try the test scene and see how the light reacts to the different commands sent to the QA/child device.
    38 minutes ago, jgab said:
    Ok, lets debug.
    Oh, and the dim step variable is gone now and replaced with 'dimtime'.
    It's the time in seconds for a full dim sequence from 0 to max or reversed. Default is 10
    2 hours ago, jgab said:
    Ok, lets debug.
    I started testing - Are this error expected ` because the test stops here on fist Bulb
    Will fill in results in a MAtrix - just want to be sure that "bad argument" is ok?
    [12.11.2020] [15:20:24] [DEBUG] [SCENE121]: Testing device 923
    [12.11.2020] [15:20:24] [DEBUG] [SCENE121]: Turning off device
    [12.11.2020] [15:20:25] [DEBUG] [QUICKAPP920]: onAction: {"actionName":"turnOff","args":[],"deviceId":923}
    [12.11.2020] [15:20:25] [DEBUG] [QUICKAPP920]: URL:/lights/3/state
    [12.11.2020] [15:20:28] [DEBUG] [SCENE121]: Toggle, should turn on
    [12.11.2020] [15:20:28] [DEBUG] [QUICKAPP920]: onAction: {"actionName":"toggle","args":[],"deviceId":923}
    [12.11.2020] [15:20:28] [DEBUG] [QUICKAPP920]: URL:/lights/3/state
    [12.11.2020] [15:20:31] [ERROR] [SCENE121]: (load):1: bad argument #2 to 'format' (no value)
    Ok, lets debug.
    Sorry, into the  printf statements there are some strings with like "...... 50%". It needs to be ".... 50%%"
    I will edit the code example...
    /monthly_2020_11/image.png.3d9af3d3a5b669e0e0f20c393a1670aa.png" />
    I'm not so good at scenes..., there is a "bug" in scenes which prevents table from being sent as arguments in fibaro.call...
    Can you change the last fibaro.call to use json.encode on it's table argument. Like:
    I changed the original code too.
    I believe that the dimming should work too.
    So, the problematic child is the Skrivebord.
    That "Skrivebord" doesn't even turn on is mighty strange as it is a basic command that's been around since the first Hue was invented... You say "Stay in 25%" for "SKrivebord" but you mean that it doesn't change I guess?
    So, I suspect that there is something with the connection to the bulb.
    Wuhoooo :-)   Just tried on the last Bulb - and now its start dimming
    I guess the last call need to change ;-)
    I have seen Skrivebord work with toggle - but today its a mess. I only have two of those bulbs  - and an lot of spare, so I can replace them
    No the last call's argument is not a table.
    table.unpack takes a table (array) of arguments and "unpacks" them as arguments to the call. So it's still correct.
    From the scene we don't send any tables.
    but Skrivebord still doesn't respond?
    However, that the lamps doesn't start to dim when used from the scene and the Matrix, is probably an issue with the scene then...
