    It seems like these lights don't have a bri attribute?
    What are they?
    When you do a list what Hue type do they report?
    It seems like they are either
    "Color light" or "Color temperature light"
    "Color light" should have bri attributes.
    "Color temperature light" don't have a bri value and needs another approach to dimming...
    What are they?
    Do you mean this info ?
    both bulb misbehave ;-)
    [10.11.2020] [17:23:01] [TRACE] [QUICKAPP812]: Dimmable_light inited, hueId:10, deviceId:814
    [10.11.2020] [17:23:02] [TRACE] [QUICKAPP812]: Extended_color_light inited, hueId:38, deviceId:839
    deviceId:814 = Hue Dimmable (model id LWB006/LWB007) – white, 2700K only
    deviceId:839 = lct001 - 3 gen Hue White Ambiance
    List detects following four Bulb types in my system
    • Color temperature light
    • Extended color light
    • Color light
    • Dimmable light
    Ok, I don't have that dimmable light model.
    Can you get the Hue definition from the bridge?
    If you follow this guide to get into the clip debuger
    and then you GET the command
    /api/<your Hue key>/lights/<Hue id of device 814>
    The Hue id is listed when with the "List" button in the QA UI.
    It's a json table. I have a dimmable light (LWA001) that looks like this and works well with the QA (dim/turn on /off etc)
    The "Color temperature light" light does not have a brightness (bri) attribute and can't be dimmed the normal way. I guess one could lower the temperature ct value...
        "state": {
            "on": true,
            "bri": 254,
            "alert": "select",
            "mode": "homeautomation",
            "reachable": true
        "swupdate": {
            "state": "noupdates",
            "lastinstall": "2020-03-09T13:21:23"
        "type": "Dimmable light",
        "name": "Skrivebord",
        "modelid": "LWB006",
        "manufacturername": "Signify Netherlands B.V.",
        "productname": "Hue white lamp",
        "capabilities": {
            "certified": true,
            "control": {
                "mindimlevel": 2000,
                "maxlumen": 800
            "streaming": {
                "renderer": false,
                "proxy": false
        "config": {
            "archetype": "classicbulb",
            "function": "functional",
            "direction": "omnidirectional",
            "startup": {
                "mode": "safety",
                "configured": true
        "uniqueid": "00:17:88:01:10:4d:a5:c7-0b",
        "swversion": "5.130.1.30000"
    And NExt One
        "state": {
            "on": true,
            "bri": 254,
            "hue": 14988,
            "sat": 141,
            "effect": "none",
            "xy": [
                0.4575,
                0.4101
            "ct": 366,
            "alert": "select",
            "colormode": "ct",
            "reachable": true
        "swupdate": {
            "lastinstall": "2018-12-23T11:12:31"
        "type": "Extended color light",
        "name": "Klint",
        "modelid": "LCT001",
        "productname": "Hue color lamp",
        "capabilities": {
            "certified": true,
            "control": {
                "mindimlevel": 5000,
                "maxlumen": 600,
                "colorgamuttype": "B",
                "colorgamut": [
                        0.675,
                        0.322
                        0.409,
                        0.518
                        0.167,
                        0.04
                "ct": {
                    "min": 153,
                    "max": 500
            "streaming": {
                "renderer": true,
                "proxy": false
        "config": {
            "archetype": "sultanbulb",
            "function": "mixed",
            "startup": {
                "mode": "safety",
                "configured": true
        "uniqueid": "00:17:88:01:00:d0:9a:9e-0b",
        "swversion": "5.127.1.26581"
    11 minutes ago, ChristianSogaard said:
        "state": {
            "on": true,
            "bri": 254,
            "alert": "select",
            "reachable": true
        "swupdate": {
        "capabilities": {
            "certified": true,
            "control": {
                "maxlumen": 800
            "streaming": {
                "renderer": false,
                "proxy": false
        "config": {
            "startup": {
                "mode": "safety",
                "configured": true
    And NExt One
        "state": {
            "on": true,
            "bri": 254,
            "hue": 14988,
            "sat": 141,
            "effect": "none",
            "xy": [
                0.4575,
                0.4101
            "ct": 366,
            "alert": "select",
            "colormode": "ct",
            "reachable": true
        "swupdate": {
        "name": "Klint",
        "capabilities": {
            "certified": true,
            "control": {
                "maxlumen": 600,
                "colorgamut": [
                        0.675,
                        0.322
                        0.409,
                        0.518
                        0.167,
                        0.04
                "ct": {
                    "min": 153,
                    "max": 500
            "streaming": {
                "renderer": true,
                "proxy": false
        "config": {
            "startup": {
                "mode": "safety",
                "configured": true
    Also getting
    • Color light
    • Dimmable light
    Do the extended color light work?
    The color temperature light shouldn't work -- need to think about that one....
    Color light ? I have not seen one of these but they should behave close to the extended color light.
    Dimmable light - no? -- I have a dimmable light that do work. Strange that your's don't.
    g @Freddan67 had a similar issue with a white hue light and my first attempt of the Hue QA. I guess that issue was that it was a color temperature light.
    • Color temperature light - Dont work
    • Extended color light - works
    • Color light - havent tryed yet
    • Dimmable light - works
    Perhaps I was not precise - sorry for that
    I have two different errors
    On - the Color temperature light dont work
    two - all bulbs are not being initiated when QA start - and I manually need to press off/on a couple of times before QA device have connection
    Ok, the color temperature light don't work - I will loan one from a friend and test it.
    For the initialisation, it can take a few seconds after the QA starts up until all devices have read their data.
    The QA connects to the Hue bridge and read all the devices and their current data and then it updates the child devices accordingly.
    So it most certainly have connection to the lights, it's just that the UI is not updated.
    I have seen issue with QA/Child UI on HC3 not getting updated correctly when I set the new values from Lua.
    What happens if you reload the web page?
    ...or is it in the mobile app it is problems?
    :-) Thank you for putting so much energy in this - its highly appreciated.
     I primary test from my Mac - i dont use the APP much - i use google assistant instead.
    if you cant loan one from a friend, PM me, and I will send you one to keep - i have two.
    For the UI not being updated, im not sure on this, but i will do some structured test on this, you are probably right.
    v1.8 of childrenOfHue - works with "Color temperature light". If you already have generated child devices for the lamps of this type you need to delete the children (trash-can in UI for each light) and generate the lights again. They are now of type multilevelSwitch.
    Lovely ;-) I will test later..
    I was wondering if you are going to support Zones? - I use it in situations where i have two bulbs over a Table? - but dont want to turn on all lights in a room / Group
    I think it is the same as Groups. "Install Groups" will install the ones you have defined in the Hue app.
    I have a couple of Groups myself - also 2 bulbs over the dinning table.
    The Hue type is "Room" I think. I will install them as multilevelSwitche group so they can be turned on/off and dimmed. With Lua you can send any attribute to the group....
    I see it - its a group with type:Zone ?
    [11.11.2020] [13:50:23] [DEBUG] [QUICKAPP812]: Group id:22, name:Arbejdsværelse, type:Room
    [11.11.2020] [13:50:23] [DEBUG] [QUICKAPP812]: Group id:25, name:Test, type:Room
    [11.11.2020] [13:50:23] [DEBUG] [QUICKAPP812]: Group id:24, name:Spisebord, type:Zone
    It seems like zones and rooms use the same api.
    What happens if you in the QA (around line 33) add
    Does it add your zones then as groups if you click "Install Groups" ?
    Added v1.9 that supports Zones (they are treated as Groups and installed with "Install Groups" button)
    No - getting this
    [11.11.2020] [14:21:01] [DEBUG] [QUICKAPP812]: Can't install groups:20-Skrivebord
    [11.11.2020] [14:21:02] [DEBUG] [QUICKAPP812]: Can't install groups:24-Spisebord
    From the List UI
    [11.11.2020] [14:22:53] [DEBUG] [QUICKAPP812]: Group id:20, name:Skrivebord, type:Zone
    [11.11.2020] [14:22:53] [DEBUG] [QUICKAPP812]: Group id:13, name:Viktualierum, type:Room
    [11.11.2020] [14:22:53] [DEBUG] [QUICKAPP812]: Group id:22, name:Arbejdsværelse, type:Room
    [11.11.2020] [14:22:53] [DEBUG] [QUICKAPP812]: Group id:25, name:Test, type:Room
    [11.11.2020] [14:22:53] [DEBUG] [QUICKAPP812]: Group id:24, name:Spisebord, type:Zone
