15 minutes ago, jgab said:
v1.14 uploaded.
Please @jgab, every time you release a new version I'm browsing many pages to find it, can you point me there?
    I have to browse too to find it :-)
    Maybe it's mature enough to add to the download section...
    Jan,
    Thank you very much for the QA.
    Still a few things wrong with my HC3
    //Sjakie
    @tinman
    Hi Tinman, I bought from Intuitech a IFTTT QA, made by you.
    ifttt_quickapp.fqa has an upload failed error when trying to install.
    All other .fqa files can be installed successfully.
    I made a ticket on the Intuitech helpdesk with the information above at 9.11.2020, but till now no response.
    I have sent an email to Intuitech with title "Not functioning Helpdesk" at 13.11.2020, but till now no response.
    Is this forum the only channel with @tinman?
    Edited by Rover
    30 minutes ago, Rover said:
    @tinman
    this one was created by @boomx
    It looks like the file got broken somehow, first 3 bytes are trash, when one delete them, the QA can be imported.
    I will send you proper version via PM, sorry for the trouble (and delay ...)
    11 hours ago, jgab said:
    The idea was to use only one button and not use 'Released' status.
    But we can have it both ways.
    v1.14 uploaded.
    The command is now toggleDim(bool)
    Ex. fibaro.call(ID,"toggleDim",false) toggles without explicit stop. You need to call stopLevelChange or let it dim all the way.
    Ex. fibaro.call(ID,"toggleDim",true) toggles with stop. One button to cycle between dim up -> stop > dim down -> stop -> etc.
    I got toggle without explicit stop working - it really great - thank you
    - This keymap is working - but no with no true or false.
    So just for my understanding - how would the command be if fibaro.call(ID,"toggleDim",true) should be used ?
    HeldDown={'toggleDim, false'} is not the right syntax
    local keyMap = {
        [1] = {
          HeldDown={'toggleDim'},
          Released={'stopLevelChange'},
          Pressed={'toggle'},
          Pressed2={'setValue',99},
          Pressed3=P3,                 -- "Dynamic" parameters can be decided by a function...
          deviceID=HueLampID4
    TNX for the response @tinman ?
    The repaired .fqa could be imported.
    Edited by Rover
    Hi, @tinman,
    I want to set temperature of NEST thermostat from HC3 via IFTTT.
    Therefore I can connect a HC3 scene via IFTTT to my NEST thermostat.
    But how to use the IFTTT QA for this? In IFTTT I only see scenes and no QA's.
    local keyMap = {
        [1] = {
          Pressed={'toggle'},
          deviceID=HueLampID4
    HeldDown={'toggleDim', false}
    On 11/17/2020 at 2:26 PM, Rover said:
    Dear Krikroff,
    I like your amazing implementation of QA_Sonos_ZC_1.3.1_RC. But the CPU load is hugh!! I wished it was not true.
    At the picture beneath you can see at the right site the effect of deleting the QA.
    12 hours ago, Rover said:
    Hi, @tinman,
    honestly, please send @boomx PM
    On 11/19/2020 at 10:48 AM, Rover said:
    I must admit that the CPU load is moderate at the moment:
    I hope you are willing to repair this extreme CPU load, so that I can use your magnificent Sonos player.
    Hi @Rover
    Sorry I don’t have the problem.
    why do you have 99 notifications, are the QA configured correctly?
    Edited by Krikroff
    Checked now with fresh five QAs installation and playing two zones
    /monthly_2020_11/image.png.c8737442c5256b956db0954a0f86af67.png" />
    I do not detect anything, sorry.
    On 11/22/2020 at 12:07 PM, Krikroff said:
    Hi @Rover
    The 99 notifications are gone, so I cannot see them at the moment.
    The QA got as only configuration change in the variable the IP number of the Sonos speaker. Should I have done more than this?
    Updating the variable for the IP is sufficient for configuration.
    Tja, how to detect the origin of the troubles?
    Maybe are these notifications a finger to the right way:
    Edited by Rover
    Hi @Krikroff,
    Now I have 99 notifications:
    Hum... Strange.
    i will try to reproduce when sonos are not available on network.
    have you any problems with wifi ?
