1 hour ago, 10der said:
dear Rover this issue I can't fix. This issues sometimes occured also for me.
only reboot (Noooooooooooooooo) :D can solve this issue.
do not change anything just reboot.
another way (lol also) just copy / paste all code from my QA to a new one.
crazy? yes.
@petergebruers check this :) Ha ha? no. it's no ha ha :(
Hi @10der,
Firstly congratulations with your 3000th post to this forum ?
I had rebooted HC3 and then run the SonosHub scene again:
17 minutes ago, tinman said:
ehm honestly, there is one thing i really hate: bad (or crashing) code and statement "can't fix, it's software, do reboot". If you know there is issue with your code, fix it or remove it or add warrning to the posting/place where the code is located/into the updated code. Just respect users, installers and support - crashing code (without any information about know bug) produce tons of frustrating support/debug hours, for everybody. It's not against you, it's against "i don't care, my crashing code must be Fibaro fault"
not it's not, if part of the code produce kind of memory leak, overflow, process kill, only reboot will help.
Hi @tinman,
I used earlier your nice QA SonosPlayer, but then came SonosHub with a huge advantage: Saving the volume of the interrupted Sonos play and  after playing the SonosHub sound restoring the original play with the original volume! This was the big omission in Krikroffs HC2 Sonos VD.
The newest Sonos HC3 QA of  Krikroff has this same advantage as SonosHub but is unusable because it blows up the HC3 CPU load till near 100%.
@tinman, with all due respect to your
I have test QA with 4  (lines of code)
/monthly_2020_11/image.png.fb68c439fdcb249b00c9507be1c3bee8.png" />
and sometimes I can see
Are you really thinking what I am stuped?
Rover, can you put here original command to Sonos Hub.
Ill test it also
@Rover
btw
Ill test it also
@Rover
The only line in the testscene: fibaro.call(125, "playFromCIFS", "192.168.1.19", "Mediacenter/d/SonosGeluiden/Deurbel.mp3", 40)
Ill test it also
@Rover
btw
My iPhone updates automatically all apps. Actual version Sonos app is version 12.2.1
@Roveryou wrong
my latest QA doesnot have this command
and
fibaro.call(fibaro.getDevicesID({name="Sonos Hub"})[1], "playNotification""192.168.1.70""//192.168.1.29/Multimedia/Music/female-opening-mail.mp3")
works like a charm
here is my lates QA
@Roveryou wrong
and
works like a charm
here is my lates QA
Do you mean that "playFromCIFS" is not working anymore?
10 minutes ago, Rover said:
12.2.1
Hmm
/monthly_2020_11/image.png.4360a3d2d2dea545147deecc1aac0f8c.png" />
I mean what cuz I violeted some rights of some user on this forum I should
1) re-write my QA from the scratch
2) re-name all commans in my QA
so. here is some commands from my qa
function QuickApp:play(ipaddr)
function QuickApp:pause(ipaddr)
function QuickApp:stop(ipaddr)
function QuickApp:next(ipaddr)
function QuickApp:prev(ipaddr)
function QuickApp:setVolume(ipaddr, volume)
function QuickApp:setMute(ipaddr, mute)
ex
 fibaro.call(1987, "pause", "192.168.1.70")
 fibaro.call(1987, "play", "192.168.1.70")
extended commands
function QuickApp:playNotification(ipaddr, uri, volume)
function QuickApp:clearQueue(ipaddr)
function QuickApp:addToQueue(ipaddr, uris)
function QuickApp:save(ipaddr)
function QuickApp:restore(ipaddr)
ex
fibaro.call(1987, "playNotification", "192.168.1.70", "//192.168.1.29/Multimedia/Music/female-opening-mail.mp3")
fibaro.call(1987, "cleareQueue", "192.168.1.70")
fibaro.call(1987, "addToQueue", "192.168.1.70",  {
             "//192.168.1.29/Multimedia/Music/!NEW/Squazoid - Voyage Across (The Remixes) - 2020/06. Squazoid - Sacred Mantra (Kuba Remix).mp3",
             "//192.168.1.29/Multimedia/Music/female-opening-mail.mp3",
             "//192.168.1.29/Multimedia/Music/Ding.mp3",
             "http://192.168.1.29/Ding.mp3"
    fibaro.call(1987, "save", "192.168.1.70")
    fibaro.call(1987, "restore", "192.168.1.70")
ex
extended commands
ex
TNX for the information, @10der ?
I am going to use this.
Especially the feature of filling and clearing a sort of playlist (Queue) offers a lot of possibilities.
What are the functional or other changes from the initial SonosHub?
that's all list of the commands.
rewitten was core. cuz initial version was based on code by TinMan what is not right as for me. And I am really sorry for this, TinMan.
no worries, i was (more than) twice married\divorced, so one can call my ass*** and i really don't mind
oh well, one can write perfectly QA with only one line and wonder why HC3 is "broken" after one clicked on save button ^.^
If this would be new empty QA, without button, label, or any other copy/paste action, on a empty HC3, i would say "we have general problem", but i know this is not the case.
If this would be new empty QA, without button, label, or any other copy/paste action, on your HC3, i would say "it might be caused as well by other crashing QA/scenes, illegal API calls, missing code cleaups", and then this simple 3 lines QA is restarting (with). Now you have 3 (init) lines, button and label ... label with strange characters should be not a problem (huge chance for "not issue"), button can be already filled with wrong call/callback (e.g. reserved names), the init code might have special characters ... so the QA is starting, crashing, and automatically restarting and crashing ...
the majority of humans is stupid, so really does not matter what i think (and as i never met you, i can't judge about you, so no).
But from your 3000 postings i can tell you following: think twice before you post, test on HC3 before you post, check your HC3 logs (and fix your errors first, before you test/publish), don't think you can develop everything better and Fibaro/others are idiots. Use less caps and exclamation marks.
@10der SonosHub  playNotification does not work.
Edited by Rover
"//192.168.1.29/Multimedia/Music/female-opening-mail.mp3" - file for notification.
@Rover
yes, cuz you thoughtless friend...
// leading mean playing with network
also ypou can use other prefixes
x-rincon-stream:                Line In
x-sonos-htastream:              TV
x-file-cifs:                    Local Library
x-rincon-mp3radio:              Radio
x-sonosapi-stream:              Radio
aac:                            Radio
x-sonosapi-radio:               Radio
hls-radio:                      Radio
http:                           Track or Radio
https:                          Track or Radio
x-sonos-spotify:                Spotify
x-sonos-http:                   Google (music library or mix)
x-sonos-http:library            Amazon (my music)
x-sonosapi-hls-static:          Amazon (tracks and radio stations)
x-sonos-http:ondemand_track     Napster tracks
x-sonosprog-http:station_track  Napster stations
@Rover
Works! TNX @10der
@10der
fibaro.call(212, "play", "192.168.1.19")
produces:
What could wrong?
Edited by Rover
@Roveridk
fibaro.call(
    fibaro.getDevicesID({name = "Sonos Hub"})[1],
    "pause",
    "192.168.1.70"
fibaro.call(
    "play",
    "192.168.1.70"
but question what was before in queue
3 minutes ago, 10der said:
@Roveridk
fibaro.call(
    "pause",
    "192.168.1.70"
fibaro.call(
    "play",
    "192.168.1.70"
So if queue is empty, SonosHub is in error ?
fibaro.call(212, "addToQueue", "192.168.1.19",{"//Mediacenter/d/SonosGeluiden/Deurbel.mp3"})
idk again
fibaro.call(
    "addToQueue",
    "192.168.1.70",
    { "//192.168.1.29/Multimedia/Music/female-opening-mail.mp3" }
/monthly_2020_11/image.png.aab40e4fde72129d99f07bac2d814347.png" />
@Rover may (guess) you are caling from SCENE. encode params for calling
Edited by 10der
