2 minutes ago, jgab said:
No the last call's argument is not a table.
table.unpack takes a table (array) of arguments and "unpacks" them as arguments to the call. So it's still correct.
From the scene we don't send any tables.
but Skrivebord still doesn't respond?
Ohhh .... ? i am very embarrassed ? - After yesterday, testing the ZONES - i have a dublicate name for a Zone an a Bulb.
Running the test for 883 (the Bulb) -
All test completed Successfull
[12.11.2020] [16:07:42] [DEBUG] [SCENE121]: Testing device 883
[12.11.2020] [16:07:42] [DEBUG] [SCENE121]: Turning off device
[12.11.2020] [16:07:45] [DEBUG] [SCENE121]: Toggle, should turn on
[12.11.2020] [16:07:48] [DEBUG] [SCENE121]: Setting brightness to 50%
[12.11.2020] [16:07:51] [DEBUG] [SCENE121]: Setting brightness to 100%
[12.11.2020] [16:07:54] [DEBUG] [SCENE121]: Setting brightness to 25%
[12.11.2020] [16:07:57] [DEBUG] [SCENE121]: Brightness transition to 100% for 5s
/monthly_2020_11/image.png.a7843ab61e97f48e90a99ff076c7f4a2.png" />
So this can dimm
 fibaro.call(id,"setValue",json.encode({bri=254,transitiontime=50}))
But this still have an issue
  if keyMap[key.keyId] and keyMap[key.keyId][key.keyAttribute] then
    local params = keyMap[key.keyId][key.keyAttribute]
    if type(params)=='function' then params = params(key.keyId,key.keyAttribute) end
    fibaro.debug(tag,"Calling ",keyMap[key.keyId].deviceID," Params:",json.encode(params))
    fibaro.call(keyMap[key.keyId].deviceID,table.unpack(params))
    So this can dimm
    Can you post the whole scene as it looks now?
    Can you try to change the scene setting "Allow to restart a running scene" to No.
    It could be that the scene is triggered multiple times and kills the running scene that tries to make the calls?
    The same scene works for me but I'm not using the Matrix but a Fibaro keyfob - but that's the only difference that I can see.
    I tested that, but no success
    /monthly_2020_11/image.png.73eefd6c9bc91ec3d63aa01fae538793.png" />
    But Double Click (Set 99% )- dont work. and thats only one command
    Så this is not working from the scene
    [12.11.2020] [16:42:36] [DEBUG] [SCENE119]: KeyId: 4 KeyAttr: Pressed2
    [12.11.2020] [16:42:36] [DEBUG] [SCENE119]: Calling 923 Params: ["setValue",99]
    Edited by ChristianSogaard
    It looks like its only being triggered once.
    Lamp "Sort bestlite" seems to get a "Increase level" and "Stop level change" within 4s. (33-37).
    It does turn on? If it needs to turn on it takes a second or two and then it starts to dim up - then I wonder if 4s is enough for you to see a change.
    If you do a double click does it log a setValue and then the lamp being 100% ?
    I changed my scene to use the Matrix and it still works.
    For "Sort Best" light
    Bulb starts OFF - Press and Hold - after 2-3 sec Bulbs turns on 100% - No transision.
    Bulb starts on 1 % - Press and Hold - dimming works - transision 10 sec - very smooth
    Bulb starts on 100 % - Press and Hold - NO dimming
    Bulb starts on 99 % - Press and Hold - NO dimming
    To dim down you need to send ''startLevelDecrease'. Have you bound that to any button?
    Ok, so if the bulb is off I turn on and then start to dim up. Just turning on will restore the old value. I will start up with bri=1 of course.
    I will release a v1.10 soon.
    I assumed ??  there was a toggle function in the Dimming - so when I "Hold Stop" and again "Hold Start"  it would reverse dimming - like HUE does native
    I updated the Scene  - and now it can Dim Down as well - smooth.
    start up with bri=1, wouldn't that ruin the possibility to dimm from eg. 33 or 75%  =
    I only turn on with bri=1 if the bulb was off. If it was on I start at the current level.
    I think that is the most intuitive approach.
    Uploaded v1.10
    You could implement reverse dimming but you need to keep track if the last command was a dim and in what direction
    Uploaded v1.10
    ??? I just love 1.10 - Smooth dimming, toggle, turn On/off - just works awsome.
    For reverse dimming - is the other way that with a global Variable? - to remember DIM direction?
    I like the two button system - but have learned people are different ;-) and for some situations - one button control is needed.
    Just now, ChristianSogaard said:
    ??? I just love 1.10 - Smooth dimming, toggle, turn On/off - just works awesome.
    For reverse dimming - is there another way besides a global Variable? - to remember DIM direction? - i should be in the QA ?
    I will start test on the ZONES ;-) i never finished that ...
    Uploaded v1.10
    A small wish - when I dimm down - it seems that the bulb ends a 1%.
    Its probably a thing for discussion. But I like it better ending a 0% - like turn off.
    And if you press "toggle" after this - what should the start value for the bulb be ? - i think it should start on 1%.
    another thing.
    If you Bulb is off - and "Double Click" = 'setValue',99 - it dont turn on the Bulb.
    "Double Click" = 'setValue',99 only works if the Bulb already is turned on
    another thing.
    Good ideas - will fix tomorrow.
    Ok uploaded v1.11 that turns on the light if setValue > 0
    The idea that the light should be turned-off when dimming down may work for some. The problem I see is that some lights have a lowest dim-level that is still quite high so it feels like a quite abrupt turn-off end the end of the dim. Myself I prefer to dim down to bri=1 and then press once more to turn off (toggle)
    Anyway, if you want to experiment with it set the quickAppVariable 'dim2off' to true.
    I’ll test ?
    I’ll test ?
    Would you also look into a optional one button solution ? With memory of dim direction?
    For 1.11
    Thank you for adding these features ?
    "Double Click" to 100% af after dim down ?  works
     dim2off = true - i think it kicks in too fast, if dimtime = 10. if i press Hold for 2-3 sec starting from 100%, its ends up turning off the bulb
    dim2off = false - , if dimtime = 10 i can stop after 8-9 sec, and can still dimm a little in second time I press Hold.
    @10der
    The very nice SonosHub QA is not working anymore:
    I did not change anything in the QA. It was working all the time till now...
    Please help @10der ?
    Edited by Rover
    2 hours ago, Rover said:
    @10der
    dear Rover this issue I can't fix. This issues sometimes occured also for me.
    only reboot (Noooooooooooooooo) :D can solve this issue.
    do not change anything just reboot.
    another way (lol also) just copy / paste all code from my QA to a new one.
    crazy? yes.
    @petergebruers check this :) Ha ha? no. it's no ha ha :(
    ehm honestly, there is one thing i really hate: bad (or crashing) code and statement "can't fix, it's software, do reboot". If you know there is issue with your code, fix it or remove it or add warrning to the posting/place where the code is located/into the updated code. Just respect users, installers and support - crashing code (without any information about know bug) produce tons of frustrating support/debug hours, for everybody. It's not against you, it's against "i don't care, my crashing code must be Fibaro fault"
    crazy? yes.
    not it's not, if part of the code produce kind of memory leak, overflow, process kill, only reboot will help.
