8 minutes ago, jgab said:
Yes, you can replace the main code in. your existing QA so you don't need to regenerate the child devices...
I will look into the dimming issue, should be able to provide a quickVar variable to control the interval.
[09.11.2020] [18:05:13] [ERROR] [QUICKAPP719]: QuickApp crashed
[09.11.2020] [18:05:13] [ERROR] [QUICKAPP719]: main.lua:35: attempt to index a nil value (global 'hc3_emulator')
[09.11.2020] [18:05:58] [ERROR] [QUICKAPP719]: QuickApp crashed
I just deleted everything with emulator - and that works
    Sorry,  just realised that I uploaded the code and not the actual QA.I updated the post with the QA - but you managed anyway :-)
    It seems that “Multilevel switch" Hue is still causing issues. Now the toggle arent working - and it can only dimm down - not up. Other bulb is working fine
    [09.11.2020] [19:40:56] [DEBUG] [QUICKAPP719]: onAction: {"args":[],"actionName":"stopLevelChange","deviceId":745}
    [09.11.2020] [19:41:07] [DEBUG] [QUICKAPP719]: onAction: {"args":[99],"actionName":"setValue","deviceId":745}
    [09.11.2020] [19:41:07] [DEBUG] [QUICKAPP719]: URL:/lights/10/state
    [09.11.2020] [19:41:24] [DEBUG] [QUICKAPP719]: onAction: {"args":[],"actionName":"turnOff","deviceId":745}
    [09.11.2020] [19:41:29] [DEBUG] [QUICKAPP719]: onAction: {"args":[],"actionName":"turnOff","deviceId":745}
    [09.11.2020] [19:41:32] [DEBUG] [QUICKAPP719]: onAction: {"args":[],"actionName":"turnOff","deviceId":745}
    [09.11.2020] [19:41:34] [DEBUG] [QUICKAPP719]: onAction: {"args":[],"actionName":"turnOff","deviceId":745}
    Somehow turnOff dont work for my “Multilevel switch"
    Updated to v1.4 - I think it should behave better. I tried it both on multilevel (white dimmable light) and extended color light.
    (turnOn/off works for me)
    Dimming speed can be affected by setting quickVar dimstep to a value. Default is 14. Higher will dim faster.
    The Lua compiler is included in the QA Toolbox now.
    It's based on the Lua compiler I posted previously
    It makes it easy to do "loadstring" or evaluate Lua expressions in QAs.
    I tried follow the "Turn Off" error. Diving into a CoH  Bulb device - it like the device dont have connection to the HUE Bridge
    /monthly_2020_11/image.png.fd0879f12db261129fcbe454b6f95e10.png" />
    If i manual press "off" and "on" a couple of times the light starts to react. And afterwards my "turnOff Scene" also work.
    Waiting some more time, and the CoH  Bulb device seems out of state with the HUE Bridge
    What Hue type is that device?
    'Color light' or 'Color temperature light' ?
    You can see the type with the 'list' button.
    I have been focusing on the "White dimmable light" and "Extended color light" as these are the lights that I have.
    Of course there was a bug in Color light. Fix 1.5
    I have issues for both Color controller and Multilevel switch
    What is the multilevelSwitch? Is it a Hue group/room ?
    No its a HUE Bulb
    /monthly_2020_11/image.png.fbe415643d9c68047ce9551a76085f7c.png" />
    ...and you tried the last v1.5 I just linked?
    Sorry no - is at work. So cant press any physical buttons. But I can upload the 1.5 version
    How would the Scene look like when implementing quickVar dimstep?
    Or should i just create a Variable dimstep?
    I uploaded 1.5 version - but cant tell if it changed anything (is not home)- Bulb is still Multilevel Switch
    /monthly_2020_11/image.png.6d92425591bd384987a3817f603cf882.png" />
    I uploaded v1.7.
    The dim mechanism is changed - I leverage the Hue transition time mechanism now so It should be smoother.
    The default time is to dim 1-254 in 10s.
    It can be changed by setting the quickAppVariable (in the UI panel) 'dim time' to the seconds wanted.
    9 minutes ago, jgab said:
    I uploaded v1.7.
    Did you pre populate the dim time in the (in the UI panel)?  i installed V1.7 and i UI is the same as 1.5
    /monthly_2020_11/image.png.10c1835f5e862c8393d3d1d6d3dbc63d.png" />
    No, if there is no dimtime variable it defaults to 10s, if you provide one I will use it instead.
    and the time is to dim the whole interval. If the light is already at 50% it will dim the rest in 5s.
    Trying ver 1.7
    I cant turn on or turn off light, and QuickApp crashed when trying to Dimm
    [10.11.2020] [16:30:03] [TRACE] [QUICKAPP812]: Color_light inited, hueId:33, deviceId:851
    [10.11.2020] [16:30:03] [DEBUG] [QUICKAPP812]: 39 children
    [10.11.2020] [16:30:04] [TRACE] [QUICKAPP812]: Hue connected to 192.168.201.3
    [10.11.2020] [16:30:24] [DEBUG] [SCENE119]: KeyId: 1 KeyAttr: Pressed
    [10.11.2020] [16:30:24] [DEBUG] [SCENE119]: Calling 814 Params: ["toggle"]
    [10.11.2020] [16:30:24] [DEBUG] [QUICKAPP812]: onAction: {"args":[],"deviceId":814,"actionName":"turnOn"}
    [10.11.2020] [16:30:24] [DEBUG] [QUICKAPP812]: URL:/lights/10/state
    [10.11.2020] [16:30:27] [DEBUG] [SCENE119]: KeyId: 1 KeyAttr: Pressed
    [10.11.2020] [16:30:27] [DEBUG] [SCENE119]: Calling 814 Params: ["toggle"]
    [10.11.2020] [16:30:27] [DEBUG] [QUICKAPP812]: onAction: {"args":[],"deviceId":814,"actionName":"turnOn"}
    [10.11.2020] [16:30:54] [DEBUG] [SCENE119]: KeyId: 1 KeyAttr: Pressed
    [10.11.2020] [16:30:54] [DEBUG] [SCENE119]: Calling 814 Params: ["toggle"]
    [10.11.2020] [16:30:54] [DEBUG] [QUICKAPP812]: onAction: {"args":[],"deviceId":814,"actionName":"turnOn"}
    [10.11.2020] [16:30:57] [DEBUG] [SCENE119]: KeyId: 1 KeyAttr: HeldDown
    [10.11.2020] [16:30:57] [DEBUG] [SCENE119]: Calling 814 Params: ["startLevelIncrease"]
    [10.11.2020] [16:30:57] [DEBUG] [QUICKAPP812]: onAction: {"args":[],"deviceId":814,"actionName":"startLevelIncrease"}
    [10.11.2020] [16:30:57] [DEBUG] [QUICKAPP812]: DU
    [10.11.2020] [16:30:57] [DEBUG] [QUICKAPP812]: ./include/main.lua:622: attempt to perform arithmetic on a string value (field 'bri')
    [10.11.2020] [16:30:57] [ERROR] [QUICKAPP812]: QuickApp crashed
    [10.11.2020] [16:30:57] [ERROR] [QUICKAPP812]: Unknown error occurred: handleJsonRpc
    [10.11.2020] [16:30:58] [DEBUG] [SCENE119]: KeyId: 1 KeyAttr: Released
    [10.11.2020] [16:30:58] [DEBUG] [SCENE119]: Calling 814 Params: ["stopLevelChange"]
    4 minutes ago, ChristianSogaard said:
    Trying ver 1.7
    another thing - Only bulbs i switch on/off manually is showing the right state.
    LIke here - 839 i turned on manually from COH device - and then device are showed.
    former versions have same issue
    /monthly_2020_11/image.png.76a0d1d04efb9f95bfcdf9200f6a1f8f.png" />
