[violation of copyright]
sorry @Tinm
Edited by 10der
@10der
Wow, that is what I expect it to do.
Just to check if I have done the right things:
1. install the QuickApp
2. run a script with only:
fibaro.call(473, "playFromCIFS", "192.168.1.230", "192.168.1.140/Fibaro/female-opening-mail.mp3")
(BTW I play internet radio via the Sonos app and run the scene)
Edited by SmartHomeEddy
If I paste in windows explorer   \\192.168.1.1\Schijf2\04-ServerDomotica\Test2.mp3 >>> it will play So the path and rights to open are okay.
Download Sonos Hub.fqa
Save
Debug>>oninit
Scene 26 run
Song doest play
error below QA 148 is the Sonos Hub (I didt change anything)
Please advice how to solve?
//Sjakie
On 10/4/2020 at 6:30 PM, 10der said:
@SmartHomeEddy can yoi check again?
Hi @10der,
SonosHub works fabulous! Music plays - Sound interrupts - Music play further with own sound level ?
How to change icon of Sonos_Hub.fqa?
only "hack-able"
1) find any humidy sensor
2) upload a new icon
3) cancel - do not change standart himidy sensor icon
4) find  NEW icon ID (via html inspector)
5) set in my QA onInit line self:updateProperty("deviceIcon", 1041)
where 1041 is icon id what you upload
@A.Socha any plans when we can change and assign any icons for generic QA?
 @SjakieI hope 192.168.1.16 your Sonos
Edited by 10der
@10der, yes thats my sonos.
/monthly_2020_10/image.png.0c19aa3f24b1f951453117f30d37eecc.png" />
do you play for example MP3’s or internet radio?
(with internet radio it doesn’t work, the sound plays, but internet radio doesn’t return. And if I push “play” the MP3 message plays, not the internet radio)
sorry @Tinm
Edited by 10der
ok its one step closer by hearing sound.
Next error no permission?
With Windows explorer I can open the disk and play the file. Also with the line I posted earlier.
Must I fill in my credentials for the network acces somewhere?
Please advice,
//Sjakie
With Subsonic on Windows 10 I stream music to Sonos, which can be interrupted by mp3 sounds (playFromCIFS) via 10der's Sonos_Hub.
@10der Wooowww it is working!
Problem: 192.168.1.1 is not equal for Sonos as the name off the Nas.
Now its synchrome it works.
Playing music from music libary>>>insert your .mp3 >>> continuing playing earlier playing music
I noticed sometimes it will not continue to play again the earlier music.
it shows scene run but no sound from the file requested and Sonos waits for push on start.
//Sjakie
sorry @Tinm
Edited by 10der
W dniu 17.09.2020 o 07:41, jgab napisał:
You could try to change the http.request call in the HC2 scene script to use https and see if it works.
Thank You very much. As usual, you helped to solved my problem :)
I have a physical dimmer 2. Which I call 'parent'.
I made a quickapp to change this dimmer 2 in functionality. This QA I call 'child'.
If the 'child' changes now, I will of course update the 'parent' with its value.
This goes fine, until a parent doesn't function/exist anymore.  (it's property dead == true).
Then updating this value (when the parent property dead == true), will slow down the whole system considerably.
What I've come up with, is to copy the parent property dead of his child (So its also vilible in the mobile app).
and if the child is dead, it does not try to update his parent. like:
But this doesn't work. It looks like property 'dead' and 'deadReason' are readonly.
What am I doing wrong, or this is not possible, and will I have to use the parent property dead==true as condition in the 'if' statement.
Which, of course, is quite illogical.
- If the parent is dead, the child in the mobile App must also be dead...
- and why is there a dead property in the quickapp.
    A couple of things going on here.
    Childs can access their parent QA with self.parent after they exit __init.
    Parents can access their children with self.childDevices[<childID>]
    To update the dead property use
    self:updateProperty("dead",true)
    or
    self.parent:updateProperty("dead",true)
    or
    self.childDevices[childID]:updateProperty("dead",true)
    Dead is a boolean. so you shouldn't need to convert it.
    or
    or
    Seems like you need the big gun to set the dead property
    This big gun ? did the trick.
    However, I am surprised that the regular property update did not work.
    Thank you very much again, for you'r provided solution.
    Edited by NLWaard
    Sending the death notification to the quickapp which takes over the function of a physical device work well now.
    Now you see in the mobile app that a device has 'no connection'.
    With that notification, there is also a refresh button.
    Does anyone know how I can pick up the call from that QA  refresh (after I click on it) and send that call to the real physical switch?
