57 minutes ago, jgab said:
You have to look if someone have done a HC3 QA for openweather. It's nothing that I'm using myself.
grabing information from com.fibaro.weather IMHO is common solution instead of getting info from any QA
Edited by 10der
Thanks, but you are much smarter in this kind off stuff as me.
I have no clue how to finalize this
Can you write the rule to retrieve clouds in all various discriptions, Flushing is my town?
Thanks in advance,
//Sjakie
@Sjakie You do use the quickapp from @irekk ?
Edited by SmartHomeEddy
On 10/25/2020 at 12:41 PM, jgab said:
A new version of. ChildrenOfHue. v1.14.
It's a "simple" QA that relies on the QuickAppChildren to realise the Hue devices.
This means that the user interfaces are limited to what are supported by the child app classes.
Supported Hue device classes:
ZLLSwitch.
Hue switch with 4 buttons. Creates centralSceneEvents similar to a Fibaro keyFob (com.fibaro.remoteController)
The interpretation is
     keyId = hueKeyValue // 1000
     keyAttribute = ({"Pressed","HeldDown","Released","Released"})[hueKeyValue % 1000 +1]
It also supports setValue('value',value) to simulate a key press.
ZLLTemperature.
Hue temperature sensor. Behaves like a standard fibaro.com.temperatureSensor.
ZLLLightLevel.
Hue light sensor. Behaves like a standard fibaro.com.lightSensor.
The device quickAppVariables  'daylight' and 'dark' is updated with resp. Hue attribute.
ZLLPresence
Hue presence sensor. Behaves like a standard fibaro.com.motionSensor.
Extended color light
Hue RGB light. Behaves like a fibaro.com.philipsHueLight.
supports:
fibaro.call(<id>,"turnOn")
fibaro.call(<id>,"turnOff")
fibaro.call(<id>,"toggle")
fibaro.call(<id>,"setValue",value)                   -- dim value 0..100
   If the value is a table the value is sent directly to the Hue light as a Hue property table.
  Ex. fibaro.call(<id>,"setValue",{effect='colorloop',bri=50})
        fibaro.call(<id>,"setValue",{startup={customsettings={xy={0.73500005089041,0.26499994910959}}}})
fibaro.call(<id>,"setColor",red, green,blue).  -- color 0..255
fibaro.call(<id>,"changeBrightness")             -- brightness 0..255
fibaro.call(<id>,"changeHue")                        -- 0..65535
fibaro.call(<id>,"changeSaturation")              -- 0..255
fibaro.call(<id>,"startLevelIncrease")
fibaro.call(<id>,"startLevelDecrease")
fibaro.call(<id>,"stopLevelChange")
fibaro.call(<id>,"toggleDim",<boolean>) -- Toggle dim direction. true with 'stop'
The device quickAppVariable  'state' is updated with the Hue state
Dimmable light
Hue dimmable white light. Behaves like a fibaro.com.multilevelSwitch.
supports:
fibaro.call(<id>,"setValue",value)                   --- dim value 0..100
Color temperature light
Mapped as a Dimmable light
Color light
Hue color light. Behaves like a fibaro.com.colorController.
supports:
Room
Hue light group.
   If the value is a table the value is sent directly to the Hue group as a Hue property table.
fibaro.call(<id>,"setScene",<Hue scene ID or scene name>)
Hue CLIPS devices
CLIPPresence          => com.fibaro.motionSensor          class='ZLLPresence'
CLIPTemperature.   => com.fibaro.temperatureSensor class='ZLLTemperature'
CLIPPressure           => com.fibaro.binarySwitch           class='BinarySwitch'
CLIPHumidity           => com.fibaro.humiditySensor.      class='Humidity'
CLIPOpenClose.      => com.fibaro.binarySensor.          class='BinarySensor'
The startLevelIncrease, startLevelDecrease, and stopLevelChange makes it possible to bind a remote controller that support centralSceneEvent to dim when a button is held down and stop dimming when the button is released.
The lights store their Hue values in a quickAppVariable 'state'.
This can be retrieved like below and ex. used to set default startup values for Hue lights...
v 1.1 - Fixed bug with ZLLSwitch
v 1.4 - better startLevelIncrease & friends
v 1.5 - fix for color light
v 1.7 - New dim approach
v 1.9 - Support Zones (same as Groups)
v 1.10 - start dim up with brightness=1
v 1.11 - setValue > 0 turns on light
v 1.12 - startDimLevel
v 1.14 - startDimLevel -> toggleDim
Hi Jan
Can you check if you have same behavior in Children of HUE v1.14?
When I turn off a zone or a group - with Pressed (toggle command)
It turn off fine. The next toggle dont work - So i cant to turn on.
Though a Pressed2 ('setValue',99) turn on the zone/group again.
Single bulb works fine with toggle, both for turn on and turn off.
matrix_bar_bund is also in the code, but not showed here
Edited by ChristianSogaard
P
Jan,
This morning no curtain opening.
I did  first @09:00 nothing happend>> backup HC3 than:
             Rule.eval([[@09:08 =>   post(#morningCurtain);            log('TRIGGER:%s',tjson(env.event)); log('Januari Sensor lux Voor- AchterTuin #morningCurtain 30/20 - remote')      ]]
Nothing in debug
All time rule are not in debug or executed
Ships I am almost finished with moving all from HC2>>>HC3,
What can I do?
Please advice,
//Sjakie
Restart didt help
Back up from yesterday is functioning, hehehe, should now set QA for QA back to see who caused it, if its caused by a QA?
Jan,
Just to inform:
I guess a glitch in HC3 after restore back up and put all newer QA's in time rules are functioning again.
Weird disruption.
Jan,
I have the QA for OWMbut I cant get it in ER4.
The OWM id clouds = 772 it will give a value in % (as shown is the Child device)
I cant find any example how to retrieve the value in this tread, or did i over looked it?
Please advice,
Thanks in advance
//Sjakie
8 minutes ago, jgab said:
It should work if you do
'towel_dryer' should be accessible inside the rule.
Note that it has to be a Lua global. You can't declare it local
local towel_dryer = matrix_badV + 5 -- Will not work!
You could also create a rule variables
towel_dryer and matrix_badV is only accessible inside rules and not visible to outside Lua code.
20 hours ago, ChristianSogaard said:
Hi Jan
Hi Jan - I did some more testing on this - and i have same issue in all my zones. - not sure to provide additional information on this. All triggers are ok ... and send to COH
Jan,
version 5.050.13
is there a limmit on the number off QA's?
HC3 skip time rules again and now it doest work after restore back to this afternoon.
Switch off and after 1 min on result the same
Block scene works.
Anything else I can try? >>>>> I dont want to go back to HC2 now
//Sjakie
2 hours ago, Sjakie said:
Jan,
version 5.050.13
Block scene works.
//Sjakie
I had the same issue when some rules wont work at all - try comment out last changed rule. or your first rule
    If a rule throws an error the rule is disabled and the rule needs. to be fixed and the QA restarted (saved again).
    Other rules should still work.
    If you have an example where you get an error and everything in ER4 stops to work, can you try to capture the error being logged? - because then I can fix it.
    Adding this rules
    stops EV4 from evaluating - its most sure my own mistake. let me look a little more into this, and see which rookie mistakes i made this time ?
    Jan,
    If I have a error due to not added device (device still in HC2) must I comment it out?
    As far as I can see in some QA's it does run after saving it shows as last line:
    [true]>>'Rule:1[@{catch,05:00} => Util.checkForUpdates()]'
    I asume all is well.
    //Sjakie
    6 hours ago, Sjakie said:
    Jan,
    //Sjakie
    Under normal circumstances it should juts disable that specific rule. SO it should work.
    Ok, I have verified that there is something strange with the zone/group and childrenOfHue.
    I will look into it...
    a question about SetColor.
    I created this rule - Winsensors is sensative strips guard - and Ledlights are LEDs in the Logic Group Matrix.
    The native command for Matrix change color for is is
    In this example LEDLights - are the two lower LED in the Matrix.
    So Change Color in Matrix when window breached.
    Change
    I dont think the trigger is working
    I see a event link this
    Incoming trigger:{"id":296,"type":"device","value":1609858822,"old":1609858786,"property":"lastBreached"}
    But i dont see the rule is running.
    this run is a scene works
    fibaro.call(1002,"setColor",0,64,0,0);
    p
    Change
    I got it - it was the list - that was formattet wrong
    This works
    Jan,
    Is there a limmit on the number off rules in a QA?
    At this moment my max is 160 rules. If I want to create Groundfloor it will add another 80 rules.
    Other thing, is it workable so manny rules?
    I know just try and see the result but also curious about the limmit.
    Thanks for theadvice,
    //Sjakie
    Hi Jan
    Thank you for your work with COH.
    Another Group thing - HUE has a Group for ALL light in the house. I dont see that being populated when syncing groups.
    I would like that group for ALARM purpose to be able to flash the light when Alarm is triggered.
    Br Chr
