easier to believe aliens. (Playing the music from x-files)
6 minutes ago, jgab said:
but Fibaro will fix that soon - just hold your breath ? ...and when you wake up it will work :-)
breaking news, tomorrow app update ?
1 hour ago, jgab said:
I don't fully understand this sentence
"...but test Toggle HC2 device (switch) from HC3 test blockscene delivers the next on HC3Proxy on HC2 (and no toggle of the HC@ device)"
Can you elaborate?
A test blockscene on HC3 tries to toggle a binary switch on HC2. No success in toggling. On HC2-scene HC3Proxy the next debug output is to be seen:
15 hours ago, jgab said:
Just to recap:
You have a double switch today that is visible as two binary switches in the UI.
One of those switches control a light bulb that can dim depending on the number of  clicks.
Correct?
You can't "attach" a childDevice to an existing z-wave device. A child device needs a QA that runs the code and creates the child devices. We can't add Lua code to z-wave device.
Why would you like it to be a child device? You want them to group together in the Web UI? (child devices are listed directly below the "mother QA"  that creates them)
What you maybe could do is to create a regular multilevelSwitch QA (on, off, dim level) that takes the input from the binary switch (on, off) and add a slider for the "dim" value. Then hide the z-wave binary switch. Can you control the dim-value by sending rapid turnOn/turnOff commands to the bulb?
Thank you for your quick response.
Your recap is Correct, and also your adoption.
But not only that, if it is a separate QA, it has no direct link to his parent (the double switch).
And therefore it does not know the status of the double switch.
The QA as standalone works the way it should.
Only I bumped into a Bug, When calling the updateProperty twice in a row. Than the property does not update.
A timer of at least (Sleep( 200)) solved this problem. But it asks for an extra variable.
It also looks great in the iPhone app..(if that was one of the questions ;)
If the code needs an other way of doing things, please let me know...
For those who have the same light bulp, here is my code..
First add a variable deviceID, with the ID of the parent device..
KlickDimmer is the QD, in the mobileApp.
Edited by NLWaard
Have you done all the configurations?
Have you set the HC3 IP/user/password variables in the HC2 scene?
Have you set the HC2 IP/user/password variables in the HC3 QA? (and setup the table with the devices)
Yes I have configured all you mentioned.
    Ok, the code is from February 23rd... I used it for a few months and it worked well for me but I moved all to the HC3 now.
    I will make an effort to go through the code and update it with the latest know-how (using child devices) - give me a day or two...
    Ok, can you try this QA and HC2 scene?
    Don't forget to add the devices that should trigger in the HC2 scene header.
    I'm not really using the HC2 anymore so if you try this and find error let me know so we can work together to fix it. Thanks /J
    Hi @jgab,
    You are a genius ?
    It works!
    Just toggle of a HC2 binary switch behaves only as turnon, while turnoff reacts correct.
    26 minutes ago, Rover said:
    Hi @jgab,
    You are a genius ?
    It works!
    You call toggle in a block scene on the HC3?
    Yes.
    9 minutes ago, Rover said:
    Yes.
    Try this - I spotted a bug..
    I guess there are room for improvements..
    Is there a need to sync global variables between HC2 and HC3?
    Device interfaces like battery and power status?
    Other types of devices then the basics...?
    You could run a loop in the QA that polls the double switch (or the switch id that you are concerned of)
    Like.
    Like.
    There you have a point.
    But I try to avoid as many loops as possible in my code.
    I think, thise loops made my HC2 to slow.
    I hope the HC3 will be able to deal with that better...
    Anyway, thank you very much for highlighting it, and helping me.
    It helped me a lot..
    gr. Mike
    gr. Mike
    Yes, always be careful what you spend CPU time on.
    However, a getValue takes ~1.3ms, if you check that once every second it's 0.13%
    Jan,
    I need your advice in relation with arming my complex.
    Try to solve the errors? there for I need your expertise
    or
    Try to do as you posted last for HC3
    I am now able to test the arming because I have in all four parts of the complex some devices connected to HC3.
    The real arm is still in HC2 to have enough time to get it working in HC3.
    Please your valuable advice what to do.
    //Sjakie
    6 minutes ago, Sjakie said:
    Jan,
    or
    //Sjakie
    So, what are your errors?
    QuickApp Lua Environment, firmware 5.040.37
    This is an attempt to be a list of all functions and variables available in the Lua QuickApp environment. It's what's visible in the _G. environment.
    It's a mix of standard Lua functions and Fibaro add-ons.
    It's also an attempt to write something about what they can be used for and what they do beyond what's in the standard documentation.
    I will return to complement the text as It's too much to write in one swoop (why don't we have a wiki so we could collaborate on texts?). In any case, if you are missing something let me know.
    Globals:
    Std.Lua. Lua table with all global values.
    Ex. To define a global function
    _G['foo'] = function(x) return x+x end
    foo(9)
    Std.Lua. A global variable that holds a string containing the current interpreter version.
    Fibaro. Used to tag log printouts in QAs. self:debug, self:trace etc.
    Defaults to "QuickApp"..self.id
    Fibaro. DeviceId of the QA. Equivalent to self.id
    Json. Author of the json library. See
    Json. Version of json library.
    Json. Flags that affect decoding
    Json. Flags that affect encoding
    Fibaro. Constants for functions Logger.*. Unclear if it is used.
    Std.Lua. A number larger than (or equal) to all other numbers.
    Std.Lua. Largest whole number that a be represented in Lua
    Std.Lua. Smallest whole number that a be represented in Lua
    Std.Lua. PI constant
    Std.Lua. The string "[\0-\x7F\xC2-\xF4][\x80-\xBF]*" for the pattern to match one UTF-8 byte sequence.
    Fibaro. Set to the current QuickApp instance (e.g 'self'). Only valid after we exit self:onInit()
    Functions:
    Fibaro. Checks if obj is of type <type> and throws an error if not. Many fibaro.* check their arguments with this function.
    Fibaro. Used by fibaro.sleep(ms). Halts the processing in the QA/Scene for the specified time (milliseconds). Note that no other tasks can run in a Scene/QA during that time. Like processing button clicks, http requests, or setTimeout timers.
    Fibaro. Used by fibaro.useAsyncHandler(bool). Default is true and makes fibaro.call asynchronous. Before fw 5.031 fibaro.call was synchronous causing fibaro.call(self.id,action,...) to hang for a certian time (~5s) before it timed out. fibaro.call(self.id,action,..) should in any case be replaced by self:action(...).
    Fibaro. Used by fibaro.debug etc to log messages
    Fibaro. Returns device structure.
    API version: api.get("/devices/<deviceId>")
    Fibaro. Used by fibaro.getValue(deviceId,property).
    API version: api.get("/devices/<deviceId>/property/<property>")
    Fibaro.  Returns an array of all devices
    API version: api.get("/devices")
    Fibaro. Returns a global variable struct. It returns the whole struct and not just the value.
    API version: api.get("/globalVariables/<name>").
    Fibaro. Returns room struct.
    API version: api.get("/rooms/<roomId>")
    Fibaro. Returns scene struct.
    API version: api.get("/scenes/<sceneId>")
    Fibaro.
    Fibaro. Returns e1 or e2 depending on if test is true or false.
    Fibaro. Probably used by fibaro.alarm(...)
    Fibaro.
    Fibaro.
    Fibaro.
    Fibaro.
    Fibaro.
    API version: api.post("/customEvents/<name>")
    Fibaro. Returns 2 values: property value and modification time
    API version:
    local p = api.get("/devices/<deviceId>/properties/<property>") or {}
    return p.value,p.modified
    Fibaro. Return the property value
    API version:
    return (api.get("/devices/<deviceId>/properties/<property>") or {}).value
    Fibaro.
    Fibaro. Get value of Fibaro global variable. Returns string.
    API version: (api.get("/globalVariables/<name>") or {}).value
    To emulate the HC2 version that returned both the value and the modified time use
    local v = (api.get("/globalVariables/<name>") or {})
    return v.value,v.modified
    Fibaro. Set value of Fibaro global variable.
    API version: api.put("/globalVariables/<name>",{value=<value>})
    Fibaro. Returns array of the device structs in <devices>. It excludes deviceIds < 4.
    local res = {}
    for _,d in ipairs(devices) do if d.id and d.id > 3 then res[#res+1]=d end end
    Fibaro. Returns name of device
    API version: (api.get("/devices/<deviceId>") or {}).name
    Fibaro. Returns room device is assigned to.
    API version: (api.get("/devices/<deviceId>") or {}).roomID
    Fibaro. Return name of room
    API version: (api.get("/rooms/<roomId>") or {}).name
    Fibaro. Return name of room that deviceId is assigned to
    local roomId = fibaro.getRoomID(deviceId)
    return roomId and fibaro.getRoomName(roomId)
    Fibaro. Returns section id that devices belongs to
    API version: api.get("/rooms/"..fibaro.getRoomID(deviceId)).sectionID -- assuming deviceId exists.
    Fibaro. Returns type of device. Ex. "com.fibaro.binarySwitch"
    API version: (api.get("/devices/"..deviceId) or {}).type
    Fibaro.
    Fibaro.
    Fibaro. Schedule a function to run after <ms> milli seconds. Equivalent of setTimeout(fun,ms).
    To schedule a function after 0 ms (fibaro.setTimeout(0,fun)) can be useful instead of calling the function directly as it will give time to other scheduled function in line for running to start. It also gives time to UI and http requests. Note though that setTimeout doesn't return the value from the function, it returns a reference to the scheduled timer.  See also
    Fibaro. Cancels a function scheduled with setTimeout. Equivalent of clearTimeout(ref).
    Fibaro. Halts the processing in the QA/Scene for the specified time (milliseconds). Note that no other tasks can run in a Scene/QA during that time. Like processing button clicks, http requests, or setTimeout timers.
    Fibaro.
    Fibaro.
    Fibaro.
    Fibaro. Returns a Hierarchy object-
    Fibaro.
    Fibaro.
    Fibaro.
    Fibaro.
    Fibaro.
    Fibaro.
    Fibaro.
    Fibaro.
    Fibaro.
    Fibaro.
    Json. Decodes a json encoded string into a Lua table
    Json. Encodes a Lua object into a json string representation.
    Json. Utility functions (of limited use)
    Fibaro?.
    Fibaro.
    Fibaro.
    Fibaro.
    Fibaro.
    Std.Lua.
    Std.Lua. See
    Std.Lua.
    Std.Lua.
    Std.Lua. See
    Std.Lua. Issues an error when the value of its argument v is false (i.e., nil or false); otherwise, returns all its arguments. message is an error message; when absent, it defaults to "assertion failed!"
    Std.Lua
    Std.Lua
    Std.Lua. Returns three values: an iterator function, the table t, and 0, so that the construction
         for i,v in ipairs(t) do body end
    will iterate over the pairs (1,t[1]), (2,t[2]), ···, up to the first integer key absent from the table.
    Std.Lua.
    Std.Lua.
    Std.Lua.
    Std.Lua.
    Std.Lua.
    Std.Lua. If index is a number, returns all arguments after argument number index. Otherwise, index must be the string "#", and select returns the total number of extra arguments it received.
    Std.Lua. Tries to convert its argument to a number. If the argument is already a number or a string convertible to a number, then tonumber returns this number; otherwise, it returns nil.
    An optional argument specifies the base to interpret the numeral.
    Std.Lua. Receives an argument of any type and converts it to a string in a reasonable format. For complete control of how numbers are converted, use string.format.
    Std.Lua. Returns the type of its only argument, coded as a string. The possible results of this function are "nil" (a string, not the value nil), "number", "string", "boolean", "table", "function", and "userdata".
    Std.Lua. Returns the elements from the given table. This function is equivalent to
         return list, list[i+1], ···, list[j]
    except that the above code can be written only for a fixed number of elements. By default, i is 1 and j is the length of the list, as defined by the length operator
    Std.Lua.
    String.
    Std.Lua. See
    For string/regexp patterns see
    Note that string.split and string.starts is added in QAs and is not part of standard Lua
    table
    Std.Lua. See
    Given a list where all elements are strings or numbers, returns the string list..sep..list[i+1] ··· sep..list[j]. The default value for sep is the empty string, the default for i is 1, and the default for j is #list. If i is greater than j, returns the empty string.
    Inserts element value at position pos in list, shifting up the elements list[pos], list[pos+1], ···, list[#list]. The default value for pos is #list+1, so that a call table.insert(t,x) inserts x at the end of list t.
    Moves elements from table a1 to table a2, performing the equivalent to the following multiple assignment: a2[t],··· = a1[f],···,a1[e]. The default for a2 is a1. The destination range can overlap with the source range. The number of elements to be moved must fit in a Lua integer.
    Returns the destination table a2.
    Returns a new table with all arguments stored into keys 1, 2, etc. and with a field "n" with the total number of arguments. Note that the resulting table may not be a sequence.
    Removes from list the element at position pos, returning the value of the removed element.
    Sorts list elements in a given order, in-place
    Returns the elements from the given list. This function is equivalent to
    Math.
    Std.Lua. See
    When called without arguments, returns a pseudo-random float with uniform distribution in the range [0,1). When called with two integers m and n, math.random returns a pseudo-random integer with uniform distribution in the range [m, n].
    For a started QA the random sequence will always be the same. To make it start on differen values a seed can be given. Note, don't use os.clock() as that gives the time the QA have run, which tends to be the same every time the QA starts.
    bit32.
    Std. Lua. See
    Lua 5.3 has built-in 64bit operators
    UTF8
    Std.Lua. See
    Std.Lua. Receives zero or more integers, converts each one to its corresponding UTF-8 byte sequence and returns a string with the concatenation of all these sequences
    Std.Lua. Returns the codepoints (as integers) from all characters in s that start between byte position i and j (both included). The default for i is 1 and for j is i. It raises an error if it meets any invalid byte sequence.
    Std.Lua. Returns values so that the construction
         for p, c in utf8.codes(s) do body end
    will iterate over all characters in string s, with p being the position (in bytes) and c the code point of each character. It raises an error if it meets any invalid byte sequence.
    Std.Lua. Returns the number of UTF-8 characters in string s that start between positions i and j (both inclusive). The default for i is 1 and for j is -1. If it finds any invalid byte sequence, returns a false value plus the position of the first invalid byte.
    Std.Lua. Returns the position (in bytes) where the encoding of the n-th character of s (counting from position i) starts. A negative n gets characters before position i. The default for i is 1 when n is non-negative and #s + 1 otherwise, so that utf8.offset(s, -n) gets the offset of the n-th character from the end of the string. If the specified character is neither in the subject nor right after its end, the function returns nil.
    Luabind.
    Luabind.
    Luabind.
    Userdata: (typically object that are create by C/C++)
    Fibaro. Base class for all devices?
    Fibaro. Base class for QuickApp and QuickAppChild. Methods in common is defined here. Like debug/trace etc.
    Fibaro. Class that creates hierarchy object. See above.
    Fibaro.  Class that creates your QuickApp object. E.g. self
    Fibaro. Helper class to manage child devices.
    Fibaro. I don't know how this is used....
    Json. Various lpeg pattern objects
    Fibaro. Wrapper for MQTT library.
    Fibaro. HTTPClient class. Most likely a wrapper for Luasocket.
    Fibaro. TCP socket class. Most likely a wrapper for Luasocket.
    QuickApp methods:
    Fibaro. See this tutorial on the QuickApp class and how it's implemented <
    Fibaro.
    Fibaro.
    Fibaro.
    Fibaro.
    Fibaro.
    Fibaro.
    Fibaro.
    Fibaro.
    Fibaro.
    Fibaro.
    Fibaro.
    QuickApp properties:
    Fibaro.
    Fibaro.
    Fibaro.
    Fibaro.
    Syncing global variables: no need because the aim of sharing devices is to facilitate a smooth migration from HC2 to HC3. Then the global variables are created in HC3 in order to use in HC3 scenes and QA's.
    Device interfaces like battery and power status?: yes, because all attributes of HC2 devices are useful in HC3.
    Other types of devices then the basics...?: Yes I have a Danalock lock device and a Nest thermostat.
    22 hours ago, jgab said:
    I deleted the old HC2Proxy QA and installed this one. Problem is that all HC2 device ID's have been changed. Is there a way to avoid this?
    Parameter HC2ID was nil in the previous QA but has an number in this version. Do I have to fill this value, if yes by what?
    The test blockscene with toggle binary switch still can only turnOnn.
