    15 hours ago, ppeterr said:
    Could it  be, that after removing the quickapp. There remain some parts
    of code in other quickapp on my system ?
    [26.02.2022] [17:47:00] [ERROR] [QUICKAPP225]: QuickApp crashed[26.02.2022] [17:47:00] [ERROR] [QUICKAPP225]: ./quickApp.lua:239: module 'include.MEMORYWATCH' not found:
    Maybe i forgot to remove the probes. Not sure.
    MW adds an extra file to QAs named "MEMORYWATCH". The file only adds an extra QuickApp function used get info from the QAs. The QuickApp function is "passive" when not called - no setTimeout or loops are started,
    So, even if the file would be left in some QAs it should not have any impact (and can be removed by hand).
    Your error message I can't figure out what it mean. Does QA 225 still contain the MEMORYWATCH file?
    You could reinstall the memorywatch QA you could run the "remove" function.
    @jgab Not sure where to look, i checked the QA225 LUA, and there is no
    reference to any file. I will run the remove function again :)
    [edit] That worked
    Edited by ppeterr
    I experience the same issues
    I have
    QA 1077 is SONOS Zone controller by kirkoff
    I dont see any file in QAs named "MEMORYWATCH"
    I tried "remove QA Probes" - and delete the memorywatch QA
    @ppeterr Was it the SONOS Zone controller for you too?
    I reinstalled, my SONOS QA - it was an old version anyway,so I am up running again.
    Thank you Jan - your help is alway highly appreciated
    @jgab
    you should use some trick to minimize potentional error during deleting
    1. save empty source code of deleted module (it should restart QA)
    2. than to delete empty module
    1 hour ago, petrkl12 said:
    @jgab
    Yes, I suspect that there must be some bug with deleting files. A delete causes a restart, but it may be safer to clear the content in a step before...
    No, it was.
    I had the error also, but in an other quickapp
    • 5 weeks later...
    On 2/12/2020 at 7:34 AM, jgab said:
    Ok, back to code.
    The QD has support for UI buttons, labels, and sliders like the old VD (no improvements here).
    We declared handler in the QD, so if we have a button with id 'button1' it will call
    function QuickApp:button1Clicked() .... end
    when we click on the button.
    Disclaimer: Still some bugs on the HC3 that makes these UI's not working on mobile apps, and sometimes flaky even in the web gui... but that will hopefully be fixed.
    So, on to an example:
    Assume, we make a simple QD to work as a code lock - here we make the QD to be of type ''door sensor' (we chose the type when we create the QuickApp device).
    It could look like this:
    We lay out the controls like this
    and name the handlers 'button0' etc.
    This device will then act as a code lock, that will get 'unsecured' when the right code is typed and auto-secure again after 4s.
    Other scenes and devices (or block scenes) could trigger on this device being unsecured and do something - like disable an alarm.
    FQA:
    Next post, a bit more advanced...
    Hi @jgab
    I'm new to quickapps.
    I tried your doorlock QA but it doens't work.
    I get
    UI callback for element: buttonx not found
    when i press a button.
    12 minutes ago, Lode said:
    Hi @jgab
    I get
    Hi, this was really early code and the UI defs changed a bit. I have uploaded a new version that works in the original post
    Hi @jgab
    Thank you so much. Got it working now but i really have to study that code before i understand it.
    I learn the most from good examples but can't find them that much.
    I have my HC3 (had HC2 for 7 years) since yesterday so a lot to discover but until now i like it a lot.
    Anyway, thanks again !!?
    • 3 weeks later...
    I just looked at an old QA I wrote and it had the lines
    ...and it took me a couple of seconds to understand what I was doing and why - and the thinking behind the code was actually not that bad.
    It creates a local variable 'self' that we can use in non-QuickApp functions. Note the use of a function to set 'self' as 'self' is already a local variable in :onInit.
    For QAs (without children or other classes) this makes it easy write most of the functions as local lua functions and avoid to unnecessarily expose them as external QickApp functions.
    • Like 3
    Unless the casual reader has had a course on lua, or has read the lua book, it will probably seem like voodoo. To be honest, I am only going to add to the confusion, but I think I am here to motivate people to learn the difference between a local variable, a global variable (which is the default) and an upvalue which is "a local variable in an outer scope".
    The whole quick app file acts an "outer scope" so it seems, as if a global variable "self" exists everywhere - unless it is hidden in a (sub) scope.
    Errrm is that a trick question on lua :)
    I would say... The lua philosophy is that variables with the same name are hidden indeed and are inaccessibly by name, there is no prefix or suffix to get to a global or an upvalue if the local scopa already has a variable with that name. Your function is a "trick" to get different names.
    But I think you could go via the global or local environment instead of using a function. EDIT: it would work using a "normal" lua interpreter, but not sure about HCx, Fibaro has denied access to some parts of lua to increase security.
    Just saying, I appreciate your post - it made my brain work (and ache a bit at the same time).
    Lua is such a neat, concise, orthogonal language... I love it.
    If you think this is all WEIRD... For those who love PYTHON.... I only recently found out...
    thistuple = ("apple")
    That is a tuple, a list of items, right? No it is not! it is a string! What makes a tuple is the comma separator... So to make a tuple with one item in it the correct syntax is...
    thistuple = ("apple",)
    Doh
    Edited by petergebruers
    Well, some people don't understand where the 'self' variable inside a QuickApp defined function comes from. That it's just an extra parameter prepended by the Lua "preprocessor" to the methods parameter list is not obvious.
    I.e.
    is equivalent to writing
    Well, it's not a trick if you know how it's done ;-)
    No, but more seriously, it's easy to think about the scope as a single hierarchy - but it becomes much more interesting with closures that we get with all Lua functions that have "free" local variables.
    In a way our setSelf function has access to another scope then the scope from where it's called - which in itself is a powerful concept if used properly.
    It's really ugly to access and set local variables - one need to use the debug library (
    ) that is blocked on the HC3 and one needs to search through the environment for the name. Not for the faint hearted...
    ...this thread could easily diverge into tales of strange programming languages... but I'm not taking that bait :-) For the Python thing, I think the designer actually was happy when coming up with that syntax for a single item tuple... and a 0-tuple is ()....
    Excellent point.
    I think it sometimes is the "syntactic sugar" that throws off new users, but makes the code more readable in the end.
    This is one of those idiosyncrasies I use but it confuses new users:
    There is a lot going on there. You have to know how "or" returns valua, understand "short circuiting" in some cases, and understand that nil has its own type that cannot be added to a string...
    Yup. I like the programming style and the way it encapsulates data. However. As I understand it, academics point out the downside to using closures and upvalues is that you can willingly or accidentally create long lived objects that keep a portion of the memory "locked". Which is evident, on the one hand, because if the function lives, then all the associated variables must live and cannot be garbage collected. On the other hand... It is not trivial to see the impact of that, it is not very clear from the code which variables have to be kept in memory. IMHO the academics may have a point.
    Oh right, yes, the debug library for locals.
    Hehehe I would not dare to derail this thread into a discussion of strangeness of other languages.
    What I wanted to say is... I don't see many thing in the Lua language that bite you, and require a "linter" to catch because the compiler itself won't catch it (iir the runtime barks at you, but that can be ... rather late).
    BTW I have been doing Python since version 1.2 and I think the reason behind this is quite mundane. Python did not use a "parser framework", they handcrafted the parser (up to 3.X that is still true). I imagine, in this case they sted "if it has a comma, then it is a list".  Does not explain why indeed () is an empty list, it should be (,) to be consistent, but that is a syntax error :D Give me Lua, please.
    12 hours ago, petergebruers said:
    Excellent point.
    The problem is without the comma that they wouldn't know if (2-1)+(3-2) was the arithmetic calculation resulting in 2 or the tuple concatenation (yes, they use the + operator for that) resulting in (1,1)
    I know that we agree - but to add to it I think the mindset should be that functions are just values (or data types) like all other data types - or objects in object oriented languages. People have a tendency to accidentally create long lived data in forgotten global variables, arrays and hash tables too - or on the call stack in endless recursions....
    On the other hand, closures gives a very fined grained control over scope. Ex
    The point is that x is shared between two functions being created - and no one else can change/touch x - that's pretty powerful. In a way it's a similar mechanism we use in other languages with objects and private instance variables - but this is much simpler.
    • 1 month later...
    Is there a way to put a single button in a QA that adds a value each time it's pressed, and change the name of that button in that value?
    For example, when the button pressed 1 time, the name of the button is 1. After press another time it's 2. This until 10 and then start over again.
    I tried with function Quickapp: Clicked() and self:updateview, but doesn't work for me.
    Use AddValue in your button's onReleased function
    That works, thanks?
