HC3 QuickApps coding - tips and tricks
jgab
On 8/11/2022 at 2:28 PM, ABDULLAH258 said:
I try in it and write this code but I am not sure what is wrong
it give me error in console
can any one help me with this.
sign chqnge avery time, see on tuya auth sign
TUYA over cloud is nice (easier to recognize device type/class), however i prefer to use local access. Attached TUYA QuickApp, for Näve Divora (Wisdom) lamps (CW/WW) and NEO Smart Bulb RGBW E27 (RGBW-WW).
For local access you need the obtain the key and id from your device, so the "long way" over tuya dev portal, free account and dev local_key readout over web console is necessary.
The good thing about tuya, once you get these keys, your subsripton can expire, the local_key never expires once generated and stored on device (whch happens during registration of device in the app itself).
I will post soon other tuya QuickApps, and cloud maual (updated, that picture below is year old or so), but for now for these who knows how to use (or who wish to cry about my code hehe).
/monthly_2022_08/image.png.df85758baf70750e93986c993af4148a.png" />
EDIT: this is really dirty implementation, but of course working. The best way to work with TUYA is to read device template / information over cloud api, filter the included classes, types and conversions, assign then matching BUI element and create such child QA. But that means, one need still, at leat at time of creation, cloud acces, and when this is offline, one would be unable to create anything. So my implementation (wrote some of them for tuya) is always hardcoded for specific device, lot of them will match one of the other QA, but for others one need to change part of the code.
EDIT2: When trying to implement / change the QuickAps above, to support your specific tuya device, you might use the attached tuya sniffer:
How to use it:
- instal the sniffer QA
- ensure non of your mobile devices has TUYA app opened, if so, close them
- set IP, device id and device key and save
- disable wifi ony you mobile device, open the TUYA app (TUYA can handle only ONE connection locally, that's why)
- click on "connect" button from this QuickApp (if the QuickApp is crashing, won't connect, click few times on disconect, and try again to connect)
- click / select this you wish to sniff, e.g. you wish to know what need to be send to turn light on, cick "On" in the TUYA app
- watch the console window on your HC3, you should see some messages:
-- CB: 9 CMD: HEART_BEAT -> these are just "pings", the QuickApp need to ping the TUYA device from time to time
-- CB: 10 CMD: DP_QUERY -> these are queries, showing your TUYA device current state, e.g.
 {"dps":{"23":736,"20":true,"22":467,"21":"white"},"devId":"f4326db31e606356632c"}
dps -> is command set, it contains number:value, where number is the TUYA command and value the current value
from above this means, TUYA command 23 is set to 736, 20 to true, 22 to 467, 21 to "white". From developer portal you might check what these command are representing, 20 is on/off, 23 (in this class) warm/cold white value * 10, 22 is brightness * 10 and so on. However, there is as well bit older set, e.g. 1 is o/off, 2 is mode, 3 is intensity/level of 2, etc. So  just don't worry if the QuickApp is showing different things as you might expect from API docummentation (you simply reading wrong one).
devID: is your TUYA device id
-- CB: 8 CMD: STATUS, followed by e.g.
  {"t":1665264639,"dps":{"20":false},"devId":"f4326db31e606356632c"}
t is unix time timestamp, dps is again TUYA command, which the sniffer have seen while you did something in the TUYA app. In this case i turned light off
These TUYA command are of course defined in TUYA API, one might get crazy however if the device is combination of two or more devices, e.g. ceiling fan with light - the turn on/off is for the major device, ceiling fan, not for light :) But as said above, with the sniffer one can check every function within few minutes.
Having all the TUYA command (and values) information it's easy to wrie own function, e.g
local chandata = {
                ['20'] = true
self:sendCommand(chandata)
will send TUYA Command 20 with value "true"
You might see other CBx CMD:yyy messages as well, they are more or less docummented on TUYA dev page (or in the QuickApp itself, tuyaAPI file)
Edited by tinman
  • Like 6
Please help, with sending http from a HC3 to an external device. I am a beginner, so please explain ind detail ;-)
I have several Matrix Logic Group devices and they do not work 100% in Homey. That’s why I bought an HC3, where they are added.
How do I send a http from my HC3 to, in my case, a Homey using http?
I can send an http from my Homey to the HC3, but not the other way around.
I want to use it to turn on a virtual button on my Homey Pro, when I press a button on the Matrix (that is included in the HC3). In that way I can use the Matrix buttons from the HC3, to control a flow on my Homey Pro.
The reason why I use a Homey, is because a am a novice, not very much in to programming :-)
In principle, HC3 must send this command to the Homey Pro, when the button is pressed :
192.168.xxx.xxx/api/app/com.internet/Light when a button/switch is pressed.
    The buttons on the Matrix are of type centralSceneEvents. That means that they generate events with a keyId (ID number of the key pressed) and keyAttribute ('Pressed', 'HeldDown', and 'Released'.
    My first thought was to use a HC3 Scene as we can have conditions that triggers on centralSceneEvent and then let the action send the http command.
    However, I'm a bit unsure how well it works as we can only have one instance of a Scene - and people may press many buttons quickly in a row.
    So, I would use a QA. The example below uses fibaroExtra so we can get the triggers that the Matrix device generate.
    The table in the beginning of the code maps buttons to urls.
    The table key is <deviceID>_<key id>_<key attribute>.
    I suggest that you run the QA and press buttons and see what key is logged (it will just warn that the button is not mapped to an url), and then go into the QA code (main) and edit the table.
    The QA can handle multiple Matrix devices.
    Hi Jan
    I looks like that the Matrix ID are not posted with value.keyId,value.keyAttribute though i see id in the code.
    At least when i tried the id was not resolved to the Matrix, just showing nil.
      quickApp:debugf("Matrix:%s key:%s, attribute:%s",id,value.keyId,value.keyAttribute)
      local key = string.format("%s_%s_%s",id,value.keyId,value.keyAttribute)
    [30.08.2022] [17:11:03] [DEBUG] [QUICKAPP1746]: Matrix:nil key:1, attribute:Pressed
    Edited by ChristianSogaard
    Typo
  • 31 minutes ago, ChristianSogaard said:
    Hi Jan
    Yes, it's a bug. Fixed in the code above but not the .fqa
    Should be
    Should be
    Confirmed it works - but you knew that already :-) Thank you for fast reply and great work
    [30.08.2022] [17:58:10] [DEBUG] [QUICKAPP1746]: Matrix:73 key:1, attribute:Pressed
    i promised some time ago a Quick App for the really cool LOQED Touch Smart Lock, finally got some time to "finalize it". You can find it in here
    Hi @jgab
    We got the integration you provided to work yesterday, with Fibaro HC3 and Homey. They guy asked for the code where truly happy. Thank you...
    I really like this syntax of writing, so i was wondering if a subset of above could be re-used in Eventrunner 4 ?
    A normal EV4 rule using the Matrix would look like this for me
    Would it be possible to simplify like this for the Matrix ?
    rule("['1001_2_Pressed'] => stuff with hueconnector-hue-v2-api")
    A mix of the HueConnector and above would also be great, perhaps better, because above finds the Matrix's automatic
    Like
    local Action = {
      ["1001_2_Pressed"] = "setTimeout(function() fibaro.call("Guest_room_Tim","setColor","green") end",
    or
      ["1001_2_Pressed"] = "Guest_room_Tim","setColor","green")",
    Typo
    Folks,
    how do I control the display format of the unit? This QA is of the typy Energy meter, uses self:updateProperty("unit""V"), and the result looks like subscript:
    /monthly_2022_09/985535659_Screenshot2022-09-16195158.png.e0cf38d1bab19ce3fbe17fafb8a7b02c.png" />
    Can I control subscript/superscript and font size? I didn't find anything like this in tinman's table. It seems to depend on device type as well. Some don't seem to have the "unit" property at all. For example Humidity sensor always has a superscript "%" regardless of the unit setting.
    Anyone who could share some light here?
    Thanks,
    jayrock
    no you can't, all you can do is to use - if using own unit - to use special unicode characters instead of e.g. xx/yy
    that's right, some devices types are using the predefined unit (they have to), like humidity which is always in %.
    Please advice me how to fix, in my two buttons QA I want:
    By external cmd change icon
    button On >> GV Test is "On"
    button two >> GV Test is "Off"
    Also reverse if GV Test is "Off" by another command  >>QA button2 change Icon
    I can't get it working
  • On 9/15/2022 at 10:24 AM, ChristianSogaard said:
    Hi @jgab
    Like
    local Action = {
    or
    You have to turn 1001_2_Pressed into an event. Unfortunately events can not start with digits so we need to put the attribute first.
    Hi @jgab
    I question for above QA
    Klavs sees these errors in his log, he exported the QA and I imported it to my HC3,
    It dont show this error, and seems to run fine. I changed a single Matrix value in the URL to test .
    Any idea why ?
    Attaching the Key structure as well.
  • 1 hour ago, ChristianSogaard said:
    Hi @jgab
    Any idea why ?
    Yes, it's a bug in the code res.status -> resp.status
    It should be
    (fixed in the original post)
    It should be
    Sorry i wasn't awake here
    Thank you for your indefatigable help ?
    Would it be possible to merge this QA into your Hue API 2.0 QA?
    So I easy could trigger HUE bulps from my MAtrix ?
    here a way how to set zigbee values from QuickApp, example hue lamp colors. One can of course (try) to use it for other values.
    Hi tinman, I understand that you've integrated many Tuya devices into HC3 and would really appreciate your help.
    I have a ceiling fan with light that's Wi-Fi Tuya enabled that I really want to integrate into HC3, I have the Device ID and Local key but i'm having trouble trying to work out how to do the rest to integrate it into HC3. Could you please help me do the rest of the integration.
    Thanks for any help
