On 10/6/2022 at 10:04 PM, colhemm said:
I have the Device ID and Local key but i'm having trouble trying to work out how to do the rest to integrate it into HC3.
two things:
- on TUYA developer page, cloud, api explorer, you can read the Instruction set, please read it and post here, that will be helpful
/monthly_2022_10/image.png.020223c929706761fe3606448b998f8e.png" />
- you device is color/music/etc. device, so take the NEO Smart Bulb tuya QuickApp (maybe even work for you immediatelly .. who knows who knows)
Please install it, set ip, device and key, save, open edit tab, go to line 21 and set the showdebug to true (and save)
    self.showdebug = true
Now you should see lot of thing coming in the console window,
if so go to dashboard view and click in that tuya quickapp all the buttons and sliders, then copy all the information from console window and send me it via PM (better - let's not spam here)
EDIT: added some "how to use for unkown devices in EDIT2 here
Edited by tinman
  • 1 month later...
I have a problem with QA Slider read and display value.
I have 10 pieces of venatian blinds and I want to adjust with the same time and same value all the venatian blinds lamella.
I created QA with slider to adjust the lamella value and one button for start the necessary Scene.
My idea is that I give the value with the slider and save this value in one Global variable. Next time when I open the QA the slider must show me the latest saved slider value.
Here is my QA code:
local tmpLamella
function QuickApp:onInit()
    self:debug("onInit")
    tmpLamella = fibaro.getGlobalVariable("LamellaValue", value)
    self:updateView("label", "text", "Label value: " .. tostring(tmpLamella))
    self:updateView("sldLamella", "value", tmpLamella)
    self:updateView("lblLamella", "text", "Lamella open % :" .. tostring(tmpLamella))
function QuickApp:onSliderChanged(event)
   tmpLamella = event.values[1]
   fibaro.setGlobalVariable("LamellaValue", tostring(tmpLamella))
/monthly_2022_11/image.png.ca246c2477f514bc30d633aeed769e0d.png" />
- Write the value to the Global Varieable --> OK, working
- Read the value from the global Variaable --> Ok, working
- Lamella open % --> shows the % of the slider what was adjusted
- Label value just for temporary here for show the init of the QA the Global Variable value
The problem is when I close this QA and open again the application read the Global variable and show in the "Lamella open%" and this is good.
But don't move the slider to that position. The slider is stay on the previous position value.
If I press the "Edit" for see the QA code and close the QA initalized and all value get the Global Variable value. But just when I go to the Edit --> see the program code.
If I just close and open the slider stay in the previously value and not on the Global Variable value.
As in the picture show the Global Variable is 21 but the slider stay in the value 55 what was the previous vaalue adjustment.
Can you help us to solve that issue ?
Thank you
Edited by Szakos
    Thank you
    You don't update the label 'label in the QuickApp:onSliderChanged(event) function
    Hi It dosn't matter the "label" is just for testing there. The problem is when I modify the slider value it will be saved in the Global Variable but if I close and open the QA the slider don't move to the value what is in the Global Variable.
    Edited by Szakos
    Just a guess,
    Maybe its because you set the slider value only in oninit function.
    Here is a
    implementation in "limited" Lua aka works on the HC3
    Added to a separate QA file it will extend the json functions with json.path(<str>)
    json.path then returns a function that can traverse a Lua (json) table.
    The parser function returned by json.path can be used several times and we avoid having to re-parse the json expression every time.
    Other examples:
    It also runs all the "bookstore" examples on the net.
    It's useful to collect values from complex json values returned by external devices.
    It can also be used parse what we get back from api.get..
    Ex.
    • Like 3
    I'm just starting to learn about QA's. I'm working through every example of @jgab fantastic tutorials and am nearly at the end of the first one  The anatomy of QuickApps - Part 1. I have sooo much to learn !!
    I'm stuck at this section of the tutorial......
    We will also have a 'createObject' function that creates new objects by creating copies of the class template.
     Lets define the functions 'createClass' and 'createObject'
    When I do.......
    function createClass(tab) return tab end
    function createObject(foo) return foo end
    myClass = createClass({a = 42, b = 17}) -- class or 'template'
    object = createObject(myClass,{a = 17}) -- copy template and initialize object with specific values
    print(object.a+object.b)
    I get 59
    I think I should get 34 because the first a = 42 should be replaced with a = 17
    I'm I doing something wrong ?
    Thanks for any help on this
    createObject is defined in the lines below in the tutorial and is a bit more complicated
    (not sure where you got the function createObject(foo) return foo end from...)
    It needs to copy over the class values and the values we give (in that order) to our new object.
    Tack så mycket @jgab
    The  "function createObject(foo) return foo end", was me trying to figure out how to get it working !!  This is what happens when a 60 year old starts to learn coding from scratch 🙃
    Your tutorials are fantastic. I'm determined to get some QA's working and I'm tantalisingly close to "Part2" tutorial !!
    I think the tutorials are a bit "deep" going into how stuff work under the hood of a QA - you could probably get away coding without this - on the other hand, knowledge is never wrong :-)
    Really understanding Lua will make life easier developing QAs...
    I think there is a space for a missing tutorial focusing on "QA best practices" when coding...
    @jgab  Finally the "penny dropped" for me!
    I had been struggling with using.....
    and getting an error... "attempt to call a nil value (global 'createClass')"
    Then I added ... "function createClass(tab) return tab end" at the beginning and I learned the reason for the error and how to fix it, but I got the wrong result.......
    returns 59
    Then based on your last post I added the Object elements and of course, it works and I understand why - I think!! .....
    function createObject(class,args)
      local obj = {} -- create a new table that is going to be our object
      for key,value in pairs(class) do obj[key]=value end -- copy the values from our class template to our new object
      for key,value in pairs(args) do obj[key]=value end -- copy the values from provided argument to initialize our new object
      return obj -- return our new object.
    returns 34
    This is tough stuff, but worth it. Thanks again for great tutorials. Moving onto Part 2😀
    God jul och gott nytt år
    • 3 weeks later...
    Its @jgab its still early days for me with QA’s and I’ve got another syntax problem.
    I’m setting up a QA to monitor movement sensors (from several rooms) and depending on which movement sensor is triggered, different QuickApp functions will run.
    The code is very basic at the moment, its running in a loop (not included below), and it works with one movement sensor being triggered and calling QuickApp:lounge() which turns the lights on & then off
    sensors ={718}
    room={"lounge"}
    if#sensors>0 then
    for i = 1,#sensors do
     a=fibaro.getValue(sensors[i],"value")
     b=(room[i])
    if a>0 then self:lounge() else
    end end end
    To be able to scale this I want to add more “sensors” and “rooms” like below and instead of calling self:lounge() I want to use  self:<myVariable()
    sensors ={718, 820,940,980}
    room={"lounge",”B2”,”B3”,”snug”}
    f#sensors>0 then
     b=(room[i])
     if a>0 then self:b()else
    end end end
    I’ve tried many syntax options and the one above doesn’t crash, but it also doesn’t call the QuidkApp !!
    Is it possible to use code which uses a variable after “self” to call a QuickApp like self:<my Variable>()
    Thanks for advice on this one.
    self is kind of a Lua table but you can't print it out because it's "protected".
    However, when you define
    function QuickApp:snug()
    it's added to the 'self' table as
    self = { snug = function(self) ... end }
    note that even if you defined the function snug() taking no arguments it will have an added argument 'self' as the first argument. This is because you defined it with a ':', i.e. QuickApp:snug()
    Anyway, to call that function in self you do
      self['snug']()
    self['snug'] will retrieve the value that has the key 'snug', our function in this case. Then we call the function by adding ()
    In your case it becomes
    b=(room[i])
    if a>0 then self[b]() else ...
    Many thanks again @jgab  Its great that you take the time to help me with the answer and an explanation which helps me with syntax logic.
    Here's another thing I'm battling with... I'm trying to make one QA for whole house lighting which runs a method "QuickApp:<room>()" for each room. To make scalable I would like to be able to get the <room> part from the method name and use it as a variable within the method which can then call various tables.
    Example:
    function QuickApp:Hall()
    at the moment I create a variable within this method
    local qaRoom="Hall"
    What would be really cool is if I could extract "Hall" from the method name automatically, then the methods for each room could populate local qaRoom variable themselves.
    Setting up the variable local qaRoom="Hall" isn't so much work, but being able to automate would be 😎
    I've read through your notes on QA anatomy and your listing of functions and variables, but I don't see anything that enables me to do this.
    Example:
    local qaRoom="Hall"
    Unfortunately, a Lua function doesn't know what its name is - Lua functions are just
    function(...) ..... end
    objects that are assigned to variables or table.
    I think the trick is to let the code that calls the function pass on the name of the room. That code should know what the name is.
    How are you QuickApp:<room> functions called?
    Hi @jgab That suggesting works perfectly, thanks for the great idea. All’s well & good & working on ZeroBrane but when I move into a QA on HC3 I immediately run into CPU issues with the loop set at 250ms. With the loop at 1 second HC3 doesn’t really like it. Longer than 1 second will give too much lag.
    It’s frustrating that we can’t auto trigger like we can is scenes.
    To speed things up with less CPU I’m thinking about having one simple scene who’s only purpose is to be triggered by movement sensors and do two things. 1. It send a trigger to a receiving QA method 2. Save the trigger ID as a variable which the receiving QA method uses to trigger the correct room method.
    Not a very elegant solution but I’m hoping that it will be faster than the 1 second loop and it should consume less CPU
    Any thoughts on this approach?
    Are you attempting to loop and check sensors?
    The trick is that you shouldn't. There is an underlying mechanism in the HC3 that emit events when a device, like a sensor, changes state. These are the events that a scene can trigger on.
    There is no ready made way to do that in an QA, but we can access the event stream with the api.
    api.get("/refreshStates")
    I would strongly recommend you to use my readymade library, fibaroExtra.lua, that you can add to any QA as an extra file. It also works to use fibaroExtra in QAs developed with ZeroBrane. (include it with the --FILE directive)
    It will add a lot of functions, but in particular functions to work with events and triggers in a QA.
        function QuickApp.post(_,...) return fibaro.post(...) end
        function QuickApp.event(_,...) return fibaro.event(...) end
        function QuickApp.cancel(_,...) return fibaro.cancel(...) end
        function QuickApp.postRemote(_,...) return fibaro.postRemote(...) end
        function QuickApp.publish(_,...) return fibaro.publish(...) end
        function QuickApp.subscribe(_,...) return fibaro.subscribe(...) end
    It will let you trigger on system events. post your own custom events. post and handle events between different QAs. ...and even a publish/subscribe system that lets one QA publish an event and every QA that subscribes to the event will receive it - thus decoupling the sender receiver so they don't need to know each others IDs.
    The fibaroExtra also contains a lot of other "missing" QA functions and it can be a good source to look at how things are implemented.
    Anyway, the event model is something I swear by and use in all my QAs as it lends itself well to QAs needing to react to asynchronous stuff/events going on.
    /monthly_2021_07/layers.png.19435943d1287e3c3f0bfec339e165ce.png" />
    Let me know if you need some examples, happy to spread the gospel of "event handling" for QA programming....
    Hi @jgab, thanks as always. This has made me think! I have some homework to do, learning how to work with event streams with API, but I am sure I will find what I need in your tutorials. I will also take your advice and utilise fibaro extra. I'll give you a shout if I need more help.... Hmmmm when I need more help !!
    Hey @jgab. fibaro extra is awesome. working like a charm. tack så mycket
    Think this is a good example of a QA with children. Credits to
    in the French forum
    It creates children defined in the children Lua table (6 children)
    It removes children not in the table (if you change the number of children)
    Each child has a unique ID that is used to call methods on the children
    Now all the children is of the same type, but the initialisation table 'children' can contain type and class also, to initialise children of different types.
