Jan I am ashamed it's not working. If I resume point by point:
Install homebrew>>>>get overview commands to use
Install luarocks    >>>>get overview commands to use
brew install luarocks>>>warning already installed and up to date
which lua>>>>>>/usr/local/bin/lua
ln -s /opt/homebrew/bin/lua ~/Documents/LUA>>>>file exists
Privacy and full acces >>lua checked
luarocks install luajson>>>luajson 1.3.4-1 is now installed in /usr/local (license: MIT/X11)
brew install openssl>>>>Warning: openssl@3 3.0.5 is already installed and up-to-date.
    When you installed openssl with brew it said something about the directory it installed openssl@3
    In my case it was
    which is then used as the path when installing luasec  (minus the /include and /lib part)
    Your brew may install the openssl libraries in another path. (I have a company Mac that is partly locked down so stuff are not always installed in the most obvious places)
    If you have forgot the openssl message, you can uninstall and install openssl again.
    >brew uninstall openssl
    I did  clean and after that an >brew install openssl>>result in:
    I am lost complete now?
    Please advice
    and after that
    Jan, finished? It give an error but also
    Will wait for your adapted iOSLocator to see the effect.
    Thank you very much for your time and effort
    You are almost there ?
    You should set macUser to "sjaakkoppejan" instead of "MacBook Pro van Sjaak".
    I deduce that from your previous post with the log
    and also make sure that you run FindMy and that it shows some users or devices...
    ...and then when pushFmipcore don't crash it will list devices and their IDs. Add the IDs you want to track to the list items in the script.
    user modified
    FindMy is enabled
    pushFmipcore only report
    tracking 2 devices no id's are showing
    Ok small problem SSD 1TB almost full I add 80Gb data!!
    Apple support wiped complete clean and now I have done all again.
    If in terminal execute lua pushFmipcore.lua should that show ID's or does it show in testLoc?
    Thanks for your time and effort
    Edited by Sjakie
    4 hours ago, Sjakie said:
    user modified
    FindMy is enabled
    Yes, when the scripts starts it logs all devices it can find in the terminal window incl their IDs.
    Then you edit the lua table in the script named 'items' to the IDs of the devices you want to track. The one that are there now is my devices - and you can't look them up :-)
    This I have in my file but it shows only 3 devices tracking. I double checked computername is as you proposed on Mac
    If the username is wrong you should get an error when it tries to open the fmipcore/Items.data file. If you don't, then it works - or do you still get errors?
    But how did you get the IDs that you have put in the items table? From the log?
    @Sjakie your right - it was a problem in my script.
    Add an all=true variable at the beginning of the script, like this
    Sorry, got carried away - that's not the problem.
    But you can still add a variable
    in the beginning of the script. It may log some more (not location enabled) devices. Those devices I usually ignore.
    The items numbers are from HC3
    Still no devices
    Edited by Sjakie
    add data2
    Ok, you still get error. It says "Operation not permitted" when trying to open the file.
    That means that you have not managed to get the lua interpreter "Full disk access" - like in the first steps.
    You may have managed to install another lua while you did your trials.
    In the terminal, move to the directory where you have the script and do
    >which lua
    and use that path for the ln - s operations etc. incl. giving Full disk access to it as described in the first posts in this thread.
    You also said something about Apple wiping your laptop? Then the lua program also lost it's full disk access rights and you need to redo it.
    Jan, there was a LUA with full permission, deleted add new one>>>you are the best!
    hehehe after a hard day of Mac stuff its showing!! Thanks
    {} to addin QA testLoc or in a separate QA?
    So the test QA I posted previously
    The 'data' argument will be a list of changed locations (even if it's only one).
    The QA in this example just loops over the list and logs the name, lat and long. But there is also an address field and (if applicable) battery status/level.
    Jan, okay will See what will happens if we go away and come back later on today.
    Is there a easy way to start the script when Mac is starting?
    Thanks again
    Jan, I started the lua pushFmipcore.lua at 13:33>>the message for all 3 devices location=true
    I left home with my iPhone just before 14:00 and cam back around 17:30
    in the editor I only see since 13:34:
    no changed items/devices is that I have 3 devices and that did't change?
    and your laptop was running with the FindMy application open?
    Yep as just now I left and came back after being 30 km away
    No changed items/devices
    Well, I did some tests.
    When the FindMy app is in the foreground it updates very often.
    FindMy app in the background updates less often, like the iPhone, ~each minute.
    FindMy app when in power save (screen saver) - unsure if it's updates...
    FindMy app when the Mac is sleeping doesn't update.
    Did you laptop go to sleep or power save?
    It may turn out that this method is not something that one can rely on, but more as a complement.
    To run the script startup we probably need to add it as a cron job to the Mac. Haven't tested it.
    Jan,
    FindMy should be in the foreground, I don't see option run in back ground, all option are on in iPhone and Macbook.
    Screensaver is on 20 min will set it off, yesterday I left my computer and house on the same time in both cases.
    I noticed that if I switch off Macbook I have option to steer Terminal it comes up after restart
