Does anyone already re-made the QuickApp for Siren Gen5?
I want to use the different sounds of the Siren like in the HC2 with the VD.
7 answers to this question
I'm also interested in QA for AEOTEC Siren Gen 5 or Gen 6. I hope someone can help us!
Why a qa? you can use the siren6 with blockscene
What is it that you want that needs a qa?
I'm looking that Siren 6 is not pretty recognized by HC3 (configuration parameters) And maybe a QA is a better approach to integrate it¿?
Do you have Siren 6 o Doorbell 6 configured in HC3?
@DavidLopez
Yes,
with firmware 1.4 no problem
i posted firmware 1.4 somewhere on this forum
@akatar
Sorry for the question, I'm new to fibroids and HC3. I don't understand what is meant by firmware 1.4?
I understand that you have the Siren 6 with your HC3 and it recognizes all the parameters to be able to change the tones, the volume and others from a block scene?
Your answer would be very helpful. Thank you
Edited by DavidLopez
1 hour ago, DavidLopez said:
@akatar
Yes,
Here you see the scenes to choose a tone and set volume
The doorbell has it's own firmware and this moment only 1.4 is working with hc3.
Well i am also having a struggle with the Gen5 Siren....
Can't get it to work under HC3.
