Alarm Control
HC3 new alarm concept could be used very efficiently by AOQ:
For example:
Assuming we have defined "nightSleep" which includes 1 doors and 2 window sensors. The zone is activated during the night (23:00~06:30).
Edited by cag014
    HTTP request Integration
    • 3 weeks later...
    Hi cag!
    I integrated the Satel Integra alarm system in to HC3 and I would like to get a notifications if it's armed or disarmed or breached.
    The arm and disarmAlarm functions work, but if I give the following sentence then it says error.
    {0,"$Night_Armed",{"trueAct"={"Satel Integra:","sendPush","A riasztó élesítve."},"state"="value=armed"}}
    (21) Wrong action/criteria state found for Keyword |$Night_Armed|
    Accpted actions/criteria:
    timeSlot vacation trigAct timeoutAct timeLoopAct initAct errAct
    This is my sentence.
    {0, "$Night_Armed",{state="value=armed",trueAct={"Satel Integra:","sendPush","A riasztó élesítve."}}},
    Can You help me?
    7 hours ago, SmartLifeSystems said:
    Hi cag!
    Can You help me?
    Oppssss........ my mistake....bug
    Please don't use underscore "_" in the name... sorry.
    The bug fixed...
    Let me know if you must to have underscore, and I will send you what to change in code.
    Edited by cag014
    The bug fixed...
    Here is the Satel Partitions, what I use.
    I have tried without underscore and I got the following error message.
    I mean change the "Night Armed" to "NightArmed" (no space) in alarm panel and then you can use it in AOQ as $NightArmed.
    Edited by cag014
    OK, thank you, I will try it.
    If I want just to monitor it, it works with undescore.
    That's the code:
    {0, "$Night_Armed"},
    And it works.
    ?$Night_Armed disarmed (value) 00:00:22 Activity
    Yes, for monitoring that should work... the bug that the code assumes this is a scene !!!
    Hi cag!
    I have tried what you sad. Now there is no error message, but it doesn't sense the change of stae of the alarm system, it continuously senses if it was disarmed.
    This is my code:
    {0, "$DayArmed",{state="value=armed",trueAct={"Satel Integra:","sendPush","Riasztás!"}}},
    $DayArmed disarmed value=armed 00:00:33 Activity   sendPush
    Edited by SmartLifeSystems
    May I ask you if you have any sensors defined in $DayArmed zone?
    Looks like no sensors defined...
    Have fixed the issue for next release. Alarm Zone state will be changed even if no devices defined in the zone.
    Edited by cag014
    What I see always, the Zones disarmed. I don't understand what is the problem...
    But you do have device/sensors defined  in that zone?
    Did you try to arm this zone manually?
    This is a Satel Alarm system. I did in the Alarm system some partitions (DayArmed, NightArmed, etc.). In the alarm panel these are the zones. Working fine everything. I can armed, disarmed with your codes, and manualy too, but the qa can't see the zones's state.
    Now I use variables that I can see the alarm systems's state.
    Please define any device in that zone... and it will work.
    You can define QuickApp as a sensor and use it inside the zone as dummy sensor.
    Like that
    As I mentioned this behavior fixed in next release.
    Edited by cag014
    Like that
    Wow! Really. That's working fine! Thank's your help!
    Hi cag,
    Can you help me?
    I would like to start a scene with the code below, but the scene doesn't start, but the AOQ is restarted instead of the scene after 20 sec.
    {0, "425",{state="centralSceneSupport=1.Pressed",timeSlot="m=9~12;1~5",trueAct={"_202","startScene","20"}}},
    Some changes at new Fibaro release...
    please find line
    fibaro.scene("execute",{realId(sId)},sArg)
    changed to
    fibaro.scene("execute",{tonumber(realId(sId))},sArg)
    String not accepted anymore....
    Edited by cag014
    please find line
    changed to
    How wouldyou write the line written by me?
    Your line is obsolete correct.
    The problem that fibaro.scene supports now array of numbers.
    Hi cag,
    I would like to set global variable, after 5 min, when I arrived Home with the code below.
    This is correct?
    {0, "&Attila",{state="value=Home",trueAct={"&AttilaHome","setGlobal","5","={$24clock:value=?$24clock+300?}"}}},
