    No. $24clock is always shows current value, so $24clock+300 will never be equal to $24clock.
    But, as  I understand you want to set &AttilaHome value to 5 after 5 minutes when &Attila=Home, right?
    {0, "&Attila",{state="value=Home",trueAct={"&AttilaHome","setGlobal","~300~5"}}},
    Just to remind you, in commands where third field is not a delay you can set delay (or formula) included in tilde
    ~?20*@400>value?~
    ~?20*@400>value?~
    Wow! Thanks! Working fine!
    Hi cag,
    Sorry to disturb you again, but I would like to ask for some help if you don't mind.
    Based on location when i arrive home, after 10 sec, the gate should open, and inside my garden ther is motion sensor and when it is breached the gate should close.
    For the reason not to close the gate, when we go out off the garden and hence breach the motion sensor i use defenerent variablaes.
    If i am far this variable, changes to 2. If I arrive home, it changes to 5 after 5 min.
    Below you can see my code tha i use, but it doesnT work, because altough it starts to open the gate, but straight away it close is it.
    I want to delay the opening of the gate, because i don't want the gate to open if i just pass in front of the house.
    The gate ID=468, the Motion sensor ID=3393
    {0, "&Noncsi",{state="value=Home#10",trueAct={{"468","open","","{&NoncsiHome:value<5}"},{"468","close","","{3393:value=true|&NoncsiHome:value<5}"}}}},
    Edited by SmartLifeSystems
    • 4 years later...
    Hi @cag014,
    I've been counting on the QA for the last several years and it's been working flawlessly. Unfortunately, the latest Fibaro HC3 update (5.170.13) broke the table preview for the AIO QA. It's now shown as seen below. The same is seen in the Edit screen with preview enabled. Can you please advise on how to either restore the previous view (if possible at all, of course) or share some other ways of viewing the updated QA table?
    Thanks a lot!
    Just fiddle with the "Use the new views in mobile application" option and it will be ok
    Thanks, but what about the browser version? As it is desktop browser that I mostly use for configuring the AIO QA. Isn't there an option to display the table elsewhere?
    Did you try it and nothing changed?
    Ah, it took me some time to figure it out - I found the respective setting in the AOQ QA advanced settings screen. It's shown as expected now, thanks a lot!
    A quick question though - is there an option to display the table full screen, rather than scrolling left-right? This is not related to the update, just something I wondered.
    With full screen, you mean outside the box of the quickapp?
    Let me explain - I am currently viewing the table either in the QA in Edit mode, with Preview toggled on, or (most of the time) - using the Edit & Preview screen in the QA settings, as seen below. This requires horizontal scrolling in order to see devices status, but that way you loose some line details, especially if you want to check some values on the far right columns.
    The question is, is it possible to extend this screen to the right so that the table is seen in its completeness? A different URL is also an option, I don't need to view it from this QA settings.
