Did someone know if its possible to get outside temperature in garden (Tuin) room?   I have installed YR weather.
Can i do it with a scene or is it not possible?
Thanks.
OK, I have published version 1.1.1, that has fallback to english and i changed the code of swedish to sv
@10derHello,
I cant see I have given data about location to Open Weather.
Where OpenWeather take geographical location from? Fibaro?
BTW thanks for your excellent QA!
Thanks in advance,
//Sjakie
I am not author.
ok thanks.
//Sjakie
The quickapp uses the location from the HC3
/monthly_2020_11/2046F773-8F61-4311-89F8-9824C77C0888.jpeg.35f2f32559ef578a81e9e840533762e1.jpeg" />
Eddy,
I doubt!
When I look in the code I find:
function QuickApp:initializeProperties()
    local locationInfo = api.get('/settings/location')
    self.latitude = locationInfo.latitude
    self.longitude = locationInfo.longitude
    self.apikey = self:getVariable("APIKEY")
    self.interval = 1
but in the open weather I didt give data about location (I tthink)
//Sjakie
ok I just recieve the picture.
Thanks!
Just did a check and the query string has my GPS coordinates.
in de main is a function
function QuickApp:getUrlQueryString()
You can add a debug message to show the variable string
Edited by SmartHomeEddy
Sorry for the delay but great.
Do you know if its only using clouds or clear?
I just installed again to use to open my curtains.
There I have severall different clouds.
Please advice,
//Sjakie
If I check OWM in HC2 it shows me "scattered clouds"
                              HC3                      "clouds"
can that be adapt? or modifyed?
@Sjakie I didn’t build the OpenWeather quickapp. But on the HC3 it does have a “Clouds” Child device with a percentage.
Just released the new version of
QuickApp with a childs device with “Visiblity” in km.
Quote
(In meteorology, visibility is a measure of the distance at which an object or light can be clearly discerned. It is reported within surface weather observations and METAR code either in meters or statute miles, depending upon the country. Visibility affects all forms of traffic: roads, sailing and aviation. Meteorological visibility refers to transparency of air: in dark, meteorological visibility is still the same as in daylight for the same air.)
Eddy I have that QA but how to use the value?
QA id=767
button id =3_5
label = CLOU [ ]
Please advice,
//Sjakie
@Sjakie Like in a script?
local clouds = tostring(fibaro.getValue(767, "value"))
fibaro.debug("Clouds: ", clouds)
[03.01.2021] [16:54:06] [DEBUG] [CLOUDS: ]: 77.0
(if device 767 is the child device with the clouds percentage)
Thanks Eddy,
Where I have to  put in QA or scene?
//Sjakie
This was an example for a script, but it could be both (fibaro.debug versus self:debug). It depends on what you want to do with it. You want to open your screens sooner or later, you do that in a scene or quickapp. Then that is where you need the value.
Hello. I installed the app, but I don't understand why it shows me 2 different temperatures on mobile app. I set a debug and the correct value from API is 7.3. Also, I tried to uninstall/install the app, but still it shows me different values.
@andreiqu You can set a default device for a room for temperature and humidity. Are you sure the default temperature device of the room is the same as the one you see the temperature reading?
@SmartHomeEddy it's the same because I have only one device set for Terrace (this quick app) and one more device for another room - flood sensor which is reading the temperature. But now I observed that the flood sensor has the same problem, when I want to see the details on mobile app it shows different temperature. For example "Room 1 - 23.3C" and below "Temperature - 23.2C". In the browser I don't have this problems. Is it a bug in the mobile app that the "Temperature" is not updating correctly?
Notice
sometimes fibaro assign as default room sensors any hidden devices
what about hidden devices? Ok a some multi-sensors devices has some hidden technical devices where device can store some raw dat for internal using. This data not related to real sensor data.
...and question what about default room sensors is actual
and last open default room. With 99% probability you can see humidity or temperature of this room... but also with 99% probability you hasn’t any sensors in default room.
Edited by 10der
in my setup I also see now and then a difference of 0.1 degree, but not more like in your previous example.
I attached the list with all of my devices, including hidden devices. The humidity for example in the app is updating good. Only the temperature has different values. Now for example is only 0.1 difference which is ok, but like one hour ago, I had again 1.6 difference (-9.3 and -10.9).
