NLWaard 12
Locally I can place the current class (self) in a variable and call an Object in this class.
This code is working (localy):
[15.09.2020] [13:22:42] [DEBUG] [QUICKAPP105]: Can I print this : Yes
If I send this variable to another class using fibaro.call(id, 'action', variable) , the call disappears into the darkness.
Calling the Object in the other class(QuickApp) results in calling the nil value?
!!! This next code is (because of the class=self) not working:
This is a pity because I would like to indicate in the called class where the call was coming from.
Now I solve this by sending a table with : sender = {id=self.id, name=self.name, value=newValue}.
Do I do something wrong? or has Fibaro disabled the oop function for sending object classes?
5 answers to this question
