MQTT Only works at one QA at a atime
TECNORTE
Hi there!
I am messing around with MQTT for integration with a third party device (Logic Machine 5) that has MQTT broker built in.
I have successefully connected a QA with MQTT and it commands a KNX group address just fine.
But, when I add a different QA to control another group address, subscibing a different topic of course, it behaves a bit strange.
When I edit the QA (I endup triggering it's OnInit function) it is normal and keeps working on the home menu but, the other QA I created before stops working.
Then, if I go to edit  the other QA (OnInit debug message comes in the console), this one takes the place of the previous QA, starts to work, but then the previous QA that was working stops responding.
I see a pattern here, that tells me the OnInit function of each device is not called at system startup (I rebooted to check).
Wouldn't it be best to create a scene at startup that could subscribe all the topics at the broker?
About that... is there anyone that can tell me how to use MQTT on scenes, instead of only on QA's?
Thanks in advance!
Edited by TECNORTE
missed some info
