Change a single parameter value using lua code scene
Hi - I would like to modify a device parameter configuration using a scene.  In this example I have a set of security lights which have a timer to switch on for 60 seconds.  sometimes we want to use them as normal lights and i'd like to be able to set the timer to 20 minutes so they dont keep turning on and off.  Parameter number 1 desired value would change using lua code to 1200.  thanks.
