API endpoint /events/history - wrong lastId evaluate
HC3, version: 5.050.13
API endpoint: /events/history
Parameter: lastId (Description: requests with id<=lastId will be skipped (only more recent entries then lastId will be returned)
Test call:
Result:
It seems data are returned in wrong order, not recent but older entries are returned.
I haven't tested it myself but based on the documentation what you want to do should be achieved by using sourceid instead of lastid.
Check the swagger: https://[HC3-IP]/#/historyEvent/getHistoryEvents
Actually I just tested it and sourceid isn't working as I expected either. one thing for sure is that when using the lastid, system returns the number of records prior to the lastid
Edited by Ash
    lastId - ID of event
    sourceID - ID of device that trigger event (i think so)
