Infiniverse 0
I'm trying to get my central heating pump to switch on when my Aeotec TRV valve is open.
This ought to be easy. The TRV has a parameter which allows it to report the value position when it changes:
Parameter 6: Valve percentage report
Reports the valve percentage on change.
Size: 1 Byte, Default Value: 0
It should be possible to create a scene that switches on the Fibaro Switch 2 which is connected to the heating pump/boiler relay.
Now I've installed the devices I can't see how to do this from the Home Centre 2 UI. I don't see any way of specifying the value change message value in a scene.
I also can't see how to see the messages that are received from the TRV to verify that they are being received.
I guess that initially I need to work out how to switch this parameter 6 on - Fibaro don't appear to have added template support for the Aeotec TRV (nor my TKBHome thermostats
Is this going to be a problem, or can I set them manually somehow?
Can someone please give me a steer?
Many thanks,
Joe
Edited by Infiniverse0 answers to this question
