SmartHomeEddy 1,007
This QuickApp contains devices of soil moisture, soil temperature and surface temperature, from accumulated temperature and precipitation data from OpenWeather via Agro Monitoring.
Soil temperature and moisture are essential indices that allow your customer to adjust irrigation work and prevent crop roots damage.
Accumulated temperature and precipitation is essential to make a right decision depends on a threshold setting. Temperature quantity index calculated as the sum of daily temperatures. Humidity quantity index expressed as the sum of daily precipitation.
Current soil data is updated 2 times a day. The soil temperature is provided in Kelvins and in this quickapp converted to Celsius (C = K - 273.15)
/monthly_2021_05/Agro_monitoring1.png.ccb73a7173411fbb5cff0f918c367624.png" />IMPORTANT
iKey (fill in your apiKey. This will return your data in json structure. The first ID you see, is the polygon ID. Use this ID in your quickapp variable.See:
See:
What is soil moisture? The science behind the measurement:
Version 0.2 (24th May 2021))
Version 0.1 (22 May 2021)
Variables (mandatory):
or look it up withPlease login or register to see this link.
Download the QuickApp here (download the file and un-zip):
or from the Fibaro Marketplace:
How to install:
Edited by SmartHomeEddy21 answers to this question
