SmartHomeEddy 828
This Quickapp retrieves energy consumption, energy production and gas usage from the Toon Energy meter version 1 or 2.
This QuickApp has Child Devices for Consumption (Watt), Production (Watt), Consumption High (kWh), Consumption Low (kWh), Production High (kWh), Production Low (kWh), Production Actual (Watt), Gas Usage (l/h) and Total Gas (m³)
The Energy Usage from the Child devices Consumption High, Consumption Low, Production High and Production Low can be used for the HC3 Energy Panel
Your Toon Energy Meter needs to be rooted, see:
This is the recommended all in one solution with a one time boot from USB stick, 10 minutes of work and done.After rooting you don't need a subscription anymore and you have access to a ToonStore with a growing number of apps. For more technical people there is a possibility to ssh into the Toon if they want with username root and password toon. Rooting is at your own risk, look here for further support and info:
(if you already have a running Linux environment)Please login or register to see this link.
Version 2.0 (22th April 2023)
Version 1.3 (20th February 2022)
Version 1.2 (27th December 2021)
Version 1.1 (27th December 2021)
Version 1.0 (3th October 2021)
Version 0.2 (30th September 2021)
Version 0.1 (29th September 2021)
Variables (mandatory):
/monthly_2021_10/Toon_icon.png.43fa0d12228dcf5bd4b32951beb156f1.png" />Download the QuickApp here (download the file and un-zip):
or from the Fibaro Marketplace:
How to install:
24 answers to this question
