Joep 156
At the moment I'm working on trying to integrate the Somfy Tahoma/Switch IO system. At my local system (with
) I can connect to the API to get a access token. When I run exactly the same code on the HC3 I get a HTTP 404 error (Page Not Found). The code isn't that complicated:Please login or register to see this code.
The HC3 doesn't show me the body or headers when an error occurs. In the message variable only the error code is shown (404).
Has someone experience with this? I tried everything, it looks like they are blocking traffic from the HC3. I tried to add another User-Agent string, but no luck.
21 answers to this question
