Get a 404 error with the Somfy API on HC3 only (are they blocking FIBARO?)
At the moment I'm working on trying to integrate the Somfy Tahoma/Switch IO system. At my local system (with
) I can connect to the API to get a access token. When I run exactly the same code on the HC3 I get a HTTP 404 error (Page Not Found). The code isn't that complicated:
The HC3 doesn't show me the body or headers when an error occurs. In the message variable only the error code is shown (404).
Has someone experience with this? I tried everything, it looks like they are blocking traffic from the HC3. I tried to add another User-Agent string, but no luck.
14 godzin temu, Joep napisał:
No, I didn't, so I can't say if it works. :(
Now I know, it wont. I founded the comparation between Tahoma Switch and Connectivity, and Local API is unchecked.
