JortC 1
I currently have my hc3 setup with the quickapp p1 meter for house energy metering and made my own quickapp for metering the solarpanels. I used most of the code from the p1 quickapp to make sure it would work simply because I am not a coding wizard sadly :).
I started running my quickapp and it worked like a charm, except for the energy panel aspect. I was producing megawatt houres of energy...
The consumption also was acting up wierd at the same time.
The child app resposible for reading the kwh data from the Growatt inverter is setup as an energyMeter like this:
some more code of this child:
When I noticed it starting to register megawatts I removed the line of code responsible for saving the data.
While coding this quickapp I came across multiple "special" ways of fibaro to register certain types of data.
My question now is, how does fibaro read this kwh data and process it?
/monthly_2022_10/image.png.dffdc0ce0f6ef82406aa1f9aeeab7dfb.png" />21 answers to this question
