The example JSON in swagger states that a request similar to the first code in this post sent to IP/api/devices as POST should create plugin. Well, response is (verbatim) the second code. I think that extra quotation mark appearing twice in "message"  is an indicator of an internal error, and HC can't recongnize the device type. And I'm certain of that because after querying another device (IP/api/devices/{deviceId}), or querying device type hierarchy (IP/devices/hierarchy), that device type exists. I'm open to other opinions, perhaps I'm doing something wrong even.
JSON in swagger:
Server response:
Edited by jooftian
I experienced the same issue. Is there any work in progress with this?
It's not for creating QuickApps, it's for instantiating versions of Fibaro's own plugins.
Try
To create an QuickApp, do
where content is an json encoded .fqa structure.
