Walli Controller association Dimmer 2
Sten
I have a Dimmer 2 with security level S0 and tried to connect Walli Controller by the book and with the code I got security level S2 Authenticated and leaving it blank or 000000 security level was set to None. When associate the two devices it complain on different security levels. When Adding Walli Controller as described below it gets added with security level S0.
  • Add device
  • Zwave
  • Button Advanced, uncheck ‘Add in S2 Security mode if device supports it’
  • Device will be added in security level S0
  • Walli Controller
    • Tab Advanced, Walli configuration
      • Operator mode: Dimmer/Roller Shutter Controller
    • Tab Associations
      • Endpoint 0, Group 6 Multidevice, Choice your ‘Dimmer 2’ devices.
Edited by Sten
  • On 11/12/2023 at 6:02 PM, SmartHomeEddy said:
    @Sten What are you trying to tell us?
    @SmartHomeEddy Hi, thanks for commenting. I hope it’s a bit clearer now. I think his maybe will help beginners.
