    1 hour ago, Sjakie said:
    Jan,
    Downloaded QA Distmanager. Selected Yahue >> update version 0.2
    It removed all HUE devices.
    Connect with HUE Bridge >> Select devices>> apply selection >> changed room by some devices >> HC3 on black
    After 3 minutes restart browser open HC3 it still adding devices
    Renamed room for all devices.
    Seems to installed right.
    How to get rid of these errors?
    Light is Color temperature Light Tradfri bulb E14 ws470lm
    I just need to know what the correct phrase is to dim a light with the time to accomplish the dim?
    Thanks for the update
    I accidentally sent a color command to a grouped_light that didn't support it.
    Uploaded 0.2.1 that should fix it.
    For dimming I think the correct way is to call startLevelIncrease or startLevelDecrease with the correct dimvalue set in the lights QV.
    Jan, still having error:
    Try v0.2.2
    Jan
    v0.2.2
    for the crash I need to wait a bit longer I guess.
    The Dim delay is new?
    Operation cancelled is caused by???
    Edited by Sjakie
    The warning you can ignore.
    the eventstream will poll again if interrupted.
    Jan, no crash since the update!
    In device view I can't see that the icon, ring, light is on or off. Hue color candle
    Jan,
    In device view I can't see that the icon, ring, light is on or off. Hue color candle.
    In historie it the icon shows on/of and color, strange behavior.
    I am sorry I did't read your modified explanation for the new Yahue.
    My problem was I modified my kitchen lights but they don't respond as HUE.
    It's implemented on HUE spots and is working nice.
    If I open the variable of the child device I only see one scene instead of all the scenes of that zone is that correct?
    Still a bit confused about startleveledcrease and startlevelIncrease.
    In the Hue scene the intensity is set on 1%(minimum)
    I guess all levels I use start with switch:on followed by startlevelIncrease
    Thanks for the big improvement!
    45 minutes ago, Sjakie said:
    Jan,
    I will fix the icon ring soon.
    I realize that startLevelncrease will just start to dim up the value to 100%, unless some calls stopLevelChange...
    So these functions are best connected to buttons operated by humans.
    Have releases 0.2.3 that you can set a QV 'transition' on the child device with time in ms for transitions.
    Will be used for turnOn,turnOff, and setValue.
    SO you should be able to do
    keuken.Keuken_Spots:value = 40
    To set dim level to 40 and if you have a QV 'transition' on keuken.Keuken_Spots set to 5000 he transition will take 5s....
    If 'transitions missing or 0 the transition is immediate.
    Let me know how/if it works...
    Jan,
    HUE scene brightness 1%
    transition in Child as QV set on 20000 to have some time to
    Does't work to switch on.
    If :off you see a delay in going off.
    Work partly!
    if :on no delay
    if :off you see delay
    White or color lights?
    Jan also releases 0.2.3 cannot be installed like QA Dist Manager.
    updated to >>> v0.2.3
    This is the first lights I did.
    Keuken_Spots:
    Dimmable lights (IKEA) 2x
    Color temperature light (IKEA) 1x
    On my TV_Lampen:
    Hue color candle 3x
    Hue lightstrip plus
    Hue play Gradient 2x
    TV_Lampen act the same as Keuken_Spots in one case they don't switch on even as transition is set on zero
    Edited by Sjakie
    GV
    -Crashes ?
    -0.2.3 Don't show up?
    -0.2.3 can't upgrade existing Yahue?
    It works on my side...?
    Jan,
    If in Hue app lights are on and brightness switched complete down (1%)  HC3 says off?
    23 godziny temu, jgab napisał:
    -Crashes ?
    Now everything works.8-)
    Edited by XTeK
    Jan,
    Yahue 0.2.3
    Eventrunner 0.0.54
    HUE Bridge 1.76.2071280000
    I have big problems with my lights! >> Related to the HUE bridge, first time I have a problem with that new bridge.
    A few minutes ago the lights did't respond at all
    Restarted HUE bridge and seems to help
    Sorry I did't investigate that first.
    About transition can it become different for switch on and off so that on can become instant and off smoothly?
    Edited by Sjakie
    transition
    Jan,
    Something is't right a lot of triggers in Eventrunner6 does't work anymore because the state of switching on in HUE app is not in the HC3!
    Yahue is showing in debug those events of switching on or off if operated in HUE app
    This does't show nothing in Debug if operated by HUE app
    Hal_Indicatie is a group of 6 lights;
    Ikea Color temperature light
    Hue white spot
    Hue color spot 4x
    Please advice
    Jan, in block scenes, you can't change the lighting colors, even though there is an option. Now the light also turns on very quickly without dimming. I think dimming worked in the older version. Overall, the project is great; if you refine it, it will be really interesting. Thanks for your work.
    Updated to 0.2.4.
    Fixed bug in setColor and state handling
    • Thanks 2
    Jan, thanks for the update.
    In devices the icon does't change if light is on or off. (Color and Dim light)
    As I can see now it will switch on without delay
    For switching off I need more time and to have a separate Hue lamp to see exactly what happens. Now I have disturbance due to normal movements in house.
    Please see .mov in pm
    Edited by Sjakie
    video
