SmartHomeEddy 1,007
This is the next version 1.2 of the SolarEdge Live (Modbus) QuickApp.
The SolarEdge Live (Modbus) QuickApp represents an advanced integration that provides instant, real-time access to local inverter data without the limitations of cloud-based API’s. This QuickApp uses the Modbus of your SolarEdge Inverter to get the real-time information about your SolarEdge setup. The QuickApp reads the SolarEdge SunSpec Modbus registers and shows the with QuickApp variables requested register values in child devices and labels. The QuickApp runs at an interval setup in the QuickApp variables. A special button is available to adjust the speed up the interval.
Example QuickApp Variables with register addresses and devicetypes:
Enabling Modbus on SolarEdge Inverters:
To enable Modbus communication on a SolarEdge inverter, follow these general steps:
After activation, the inverter is ready to communicate with external systems or monitoring solutions using the Modbus protocol. Always consult your inverter’s user manual for detailed instructions specific to your model.
Important documentation for the right register addresses (use the base 1 address):
Disclaimer:
Use this QuickApp at your own risk. You are responsible for ensuring that the information provided via this QuickApp do not contain errors. SolarEdge is a registered trademark being the property of SolarEdge. SolarEdge reserves all rights to the registered trademarks. Information which is published on SolarEdge’s websites belongs to SolarEdge or is used with the permission of the rights holder. Making of copies, presentations, distribution, display or any other transfer of the information on the website to the public is, except for strictly private use, prohibited unless done with the consent of SolarEdge. Published material on dedicated SolarEdge press websites, intended for public use, is exempt from the consent requirement.
Changes version 1.2 (2nd September 2025)
Changes version 1.1 (9th August 2025)
Changes version 1.0 (27th July 2025)
Variables (mandatory and created automatically):
/monthly_2025_08/image.png.5b9eef364bb7da6bc971e8e0671eb3f2.png" />Download the QuickApp here:
or from the Fibaro Marketplace:
How to install:
(This download contains several example register addresses, but you can choose you own register addresses to create your child devices)
Edited by SmartHomeEddy23 answers to this question
