Jan, getting error
    On 6/24/2026 at 9:21 PM, Sjakie said:
    Jan how to write in ER7?
    Fixed in latest version.
    Now ID:msg will use fibaro.alert('simplePush',{id},...)
    The push push method can be changed by setting
    fibaro._pushMethod = 'simplePush'
    to ex. 'push'. However, I have only made it work for me with 'simplePush'
    1 hour ago, Sjakie said:
    Jan, getting error
    I had spelled it vnum...
    pushed new version with the correct wnum variable defined. (v0.1.47)
    Yes, it looks ok.
    You could do
    You may also want to check that there is a Morning,Day,Event,Night field in p.
    A note about time check t1..t2.
    rule("10:00..11:00 => ... ")
    will trigger the rule at 10:00, and it will also trigger the rule at 11:00:01,
    e.g. 1 second after the second bound.
    However, that last trigger will usually fail as 11:00:01 is not within 10:00..11.00
    The reason that ER will anyway generate a trigger for 11:00:01 is that we may have a rule like
    rule("!(10:00..11:00) => ...")
    meaning if we are not in the interval, the condition should be true.
    Now because we trigger at 11:00:01 that is outside the interval, the test is false, but the not version is true and the condition becomes true... what we want.
    Jan how to kill this rule?
    Or do I need to create something else?
    Edited by Sjakie
    kill
    .mode("killOthers") is changed in ER7. Now we write
    rule("<cond> single => <action>")
    However, it only affect rules that "pause" or post future events t, so I don't know what you are trying to achieve here?
    does nothing of that and will not benefit from the "single" modifier.
    Are you trying to disable the rule?
    Edited by Sjakie
    nightfall
    Well, there was no command to kill other rules. You could use disable but then you need to enable it afterwards, easy to forget.
    So, in v0.1.48 there is a terminate property on defined rules.
    Working, thanks!!
    Dear Jan, great work on EventRunner7 🙏🙏🙏 , just started moving all my rules from 5 & 6 to a single instance on Eventrunner7...
    Looks like the nr.post() does not (yet) work in 7.
    If it is not me doing something wrong, could you include when you roll out a new version?
    Thxs Jeroen
    Jan, if he GV change it does't work as trigger?
    Action comes if light is switched oo than he changes from warm in to Koud or vice versa
    Your rule, simplified, looks like:
    and will only trigger if the any variable in the condition
    changes. And the action will run if the condition is true.
    It will not trigger on Temp_Binnen_Buiten_Delta changing from Koud to Warm or vice versa as that test is not in the condition part of the rule.
    Hi, If you use QA Dist Manager from Jgab, you will see that:
    /monthly_2026_07/image.png.a2237290c4e50f154e6b2811dbc198c4.png" />So the latest is 0.1.48
    BTW, I dont know what means the digit and arrow inside brackets...
    Edited by Christb
