mmmhhh  is this true?? No idea where to look! no further info. QA restaring
4 minutes ago, KaWi said:
Is wday('last') no longer available?
I switched from v0.1.29 back to v0.1.28. There is no error in v0.1.28
My rule TOD  does't work Avond_Vroeg is >> Early Evening Variable show still >> Late_Afternoon
Any quick solve for a QA who is in a loop?
Edited by Sjakie
loop
    It's not the wday('last') that crashed, it was my fix for tracking :manual.
    I posted v0.1.30 that fixes it.
    4 hours ago, Sjakie said:
    Jan, about the restart it's for summer/winter time or did you implement it in ER7?
    Yes, nextDST() is still there.
    The external Hue is excellent but perhaps a challenge?
    Zithoek_Verlichting  & Licht_Show  are zones.
    In this example I switch Studio what is a room
    Can you separate it or is Hue giving the same signal out?
    Ehh, I don't understand. You want check if it's a room or a zone?
    okay a room contains lights
    a zone can contain lights from different rooms
    If zone is switched on the correspondent rooms will switch on also in the Hue app.
    In HC3 you  see than several rooms and the zone notify the light is on. So for HC3 in my case I like only to see the zone or rooms who aren't part of a zone to minimize debug lines or as a choice.
    This I see after restart without touching the hue app
    I can't find what is wrong with this rule
    Good Morning,
    I have some trouble with this rule:
    ID247 is HT.blind_Nr_4
    The rule started if $Present_Kai=='away' and $Present_Katharina=='away'. But it should only check @22:00+rnd and then run.
    I can´t find the fail. In ER5 the rule runs without problems
    1 hour ago, KaWi said:
    Good Morning,
    Sorry, rules with @daily triggers and normal triggers are always a bit tricky to get right and I always save it to last to implement... this time I forgot. This caused your rule to trigger when 247 was changed state.
    Anyway, now in v0.1.32 it is fixed 🤞
    You have an 'end' last in the rule that doesn't belong there.
    Thank you very much for the help.😀
    When a rule condition becomes true it's actions is executes
    While the action part runs no other rule can run until the action finish. Lua is a single threaded language.
    However, if we include a wait(seconds) in the action, the rule is suspended and other rules can run meanwhile.
    With the wait, it logs A,C,B
    without the wait the log would be A,B,C
    wait is implemented by starting a setTimeout to run the rest of the rule after the wait.
    Timers the rule start with setTimeout is recorded with the rule. Also if we do a post for the future, a timer is started and recorded.
    This run triggers when a sensor is breached, turn on a lamp and post an event to turn off the lamp after 5min.
    Here we must remember the timer reference post returns so we can cancel ev. timer when the sensor is breached.
    This is because we typically want to extend the period the lamp is on if the sensor is breached again while the lamp is on.
    This is such a common pattern, so we can tell the rule to cancel all it's timers when the rule is triggered again.
    The 'single' keyword cancels all timer the rule have started earlier when triggered again, in this case the eventual post. No need to track the ref ourself and cancel it.
    With 'single' we can make this rule even simpler.
    The 'single' keyword will cancel the timers, so if an earlier invocation of the rule was sleeping in the wait(00:05) it will be canceled. So, we get the "extend lamp time when sensor breached again" logic in a simple way.
    All of these examples do turn on the light even if the light is already on. Normally, that is not a problem, but otherwise it's easy to add a check for that.
    Jan, since HC2 I use fa:
    pir:breached | radar:isOn | door:isOpen => $Occupation = 'Yes'. So as long as $Occupation don't change all stay the same
    halfway using HC3  I use pir:breached | radar:isOn | door:isOpen => action. Now everytime one of the trigger is triggered it result in action.
    Does this make sense?
    Just to show ER7 is running a few resources:
    7 QA's with around 1100 rules
    62 Z-Wave devices
    70 Hue devices
    remark I know it's an open door but I still notice it if HC3 memory is climing;
    RAM is growing it's not giving back if used
    short after restart 44% - 4% -  31% - 21%
    Jan,
    Since HC2 I use:
    pir:breached | radar:isOn | door:isOpen => $Occupation = 'Yes'.   $Occupation == 'Yes' => several actions
    One year ago I switched: pir:breached | radar:isOn | door:isOpen =>action
    Does that make a difference or better to use the GV as trigger for follow up?
    ER7
    6 QA's
    62 Z-wave devices
    70 Hue lights
    No idea what's wrong?
    V0.1.32
    Should this error also be listed in debug window if error is selected??
    Is easier to see all your error instead of scrolling trough each QA??
    V0.1.32
    Are you missing the '=>' ?
    appPhone.alarm_Ring:isOn => log.yellow('a ....
    Yes, they should be tagged as errors. Fixed that in v0.1.33.
    28 minutes ago, Sjakie said:
    Jan,
    Since HC2 I use:
    If you use
    the action will run every time any of the triggers change, and at least one of them (not necessarily the one that changed!) is true.
    If you do
    the action will only run when Occupation goes from 'No' to 'Yes'.
    If Occupation is already 'Yes', setting it to 'Yes' again will not trigger the third rule.
    The second rule make sure that when all triggers are false, Occupation is set to 'No'
    Jan why you write
    instead off:
    Is your rule better for HC3?
    2 minutes ago, Sjakie said:
    Jan why you write
    instead off:
    No, but you want to set it to 'No' if none of the triggers are true?
    You could write
    e.g. no trigger is detecting anyone at home.
    ...or did I misunderstand your intention?
    Nope correct just curious, thanks.
    62 Z-Wave devices
    70 Hue devices
    I think it looks good. In general we shouldn't worry too much about the memory. Linux will try to use as much memory as possible for buffers and cache etc. In your case even the 50% used can be partly released when memory pressure increases if apps are written correctly.
    EventScript is so scalable because it only tries rule that can react on a specific event, when that specific event happens.
    This means you can have thousands of rules (well, memory is a constraint here), and ER will only trigger relevant rules.
    Each rule is inspected what events it can trigger on and a clever hash lookup mechanism maps incoming events to rule signatures, so we can quickly pick out what rules to try.
    Some other system loop through all rules at intervals to see which rules should fire, which of course creates a constant load on the system that grows with number of rules.
