    I have released EventRunner 7.
    It's to a high degree backward compatible with ER6 but a total rewrite of the internal engine and script functions.
    It's cleaner architecture and cleaner code, coming from the experience of writing ER6.
    It should be better and faster and produce better error messages when something goes wrong with rules.
    I have a backlog of stuff still missing in ER7 that are mostly old things from earlier ER implementations - questionable if they are needed. If you miss something, let me know and I'll add it.
    I'm still keeping EventRunner 6 around for people that are happy with it, otherwise I recommend to make the jump to EventRunner7. You need to move over the rules by hand from ER6/ER5.
    After that, ER7 is upgradable/downgradable using
    I will come back with what's new in ER7 and roadmap in a separate post.
    🎉 EventRunner7 v0.1.8 — Rule Modifiers, Named Scenes & Rule Groups
    Three new language features landed in v0.1.7–v0.1.8 that make rules more expressive and easier to maintain: Rule Modifiers, Named Scenes, and Rule Groups.
    ⚙️ Rule Modifiers
    Modifiers are optional keywords placed between the condition and =>. They change when or how often the action fires — without touching the condition itself.
    Modifier Syntax Effect
    single cond since => Cancel all pending timers and wait() suspensions from the previous run before starting a new one
    since T cond since 00:02 => Condition must stay continuously true for T seconds before firing
    debounce T cond debounce 0.5 => Wait T seconds of silence after the last trigger; any re-trigger cancels and restarts the wait (implies restart)
    cooldown T cond cooldown 00:05 => Suppress re-triggering for T seconds after the last fire
    every N cond every 4 => Fire only on every N-th true evaluation of the condition
    first_in W cond first_in 07:00..08:00 => Fire at most once per opening of time window W; the latch resets automatically when the window closes. W must be a .. time range.
    What each modifier desugars to
    All modifiers except restart and debounce are pure condition sugar — they rewrite the condition expression before compilation. restart and debounce also carry a runtime flag that clears active timers on each invocation.
    Modifier Expands to Clears timers?
    cond single => action RULE node flag {restart=true} set; action unchanged cancels pending wait() / timers before each run
    cond since T => action condition becomes trueFor(T, cond)
    cond debounce T => action RULE flag {restart=true} set; wait(T) prepended to action block cancels previous wait(T) on each re-trigger
    cond cooldown T => action condition becomes cond AND cool_down(T)
    cond every N => action condition becomes cond AND every_other(N)
    cond first_in W => action condition becomes cond AND once(W)
    Examples
    ℹ️ first_in requires a .. time window as its argument. Passing anything else (a number, a variable, etc.) is a parse-time error. Under the hood it desugars to cond AND once(W) — the existing once() latch function, which auto-resets when the window closes.
    🎬 Named Scenes
    A named scene groups a set of device property assignments under a name. Scenes are declared with the soft keyword scene and activated or deactivated via the familiar obj:property syntax inside any rule action.
    Short form — activate-only
    Long form — separate activate and deactivate bodies
    Using scenes in rules
    Dynamic values — re-evaluated at activation time
    Literal values (10, true, "off") are stored at declaration time. Any non-literal expression is wrapped in a thunk and re-evaluated every time the scene activates:
    ℹ️ Calling :deactivate on a short-form (activate-only) scene is a runtime error that disables the rule, so you know immediately if you forgot a deactivate body.
    �️ Rule Groups
    Rules can now be tagged with a group name at registration time. The entire group can then be enabled or disabled in a single call — from outside in Lua, or from inside any rule action using the built-in enable / disable functions.
    Registering rules in a group
    Enabling / disabling a group from a rule action
    The built-in enable / disable accept:
    • A group name string — acts on every rule in the group
    • A rule object — acts on that rule only
    • A numeric rule id — acts on that rule only
    • No argument — acts on the current rule (self-disable pattern)
    Vacation mode example
    Accessing groups from Lua
    📥 Download
    • GitHub Releases:
    • Direct download:
    📚 Documentation
    • Please login or register to see this link.
       — updated with modifiers and scenes sections
    On 5/24/2026 at 4:58 PM, jgab said:
    Direct download:
    I did download the FQA file: using the above direct link and also going to your GitHub but I am always getting an error without any code followed by error 500 when trying to upload the fqa file in my HC3 Version 5.210. Any other FAQ file is accepted.
    What I am doing wrong?
    Sorry, it was an error when I packed it to an fqa. I fixed it now - try to download 0.1.10.
    EventScript Debug Tooling (ER7)
    EventScript provides a set of runtime debug functions that help you understand why rules fire (or don't). All functions work on both plua (development) and the real HC3 (production) — output goes through the standard log console in both environments.
    Table of Contents
    Named Rules
    All debug functions identify rules by name. Give a rule a name via the {name=...} option:
    Without a name, rules get an automatic name like "RULE3" (based on their registration order). You can still address them by name or by numeric ID:
    The rule name also appears in all standard log output:
    Rule Inspector — info()
    info(rule) prints a snapshot of everything known about a rule at that moment: its source, triggers, enabled/disabled status, active modifier state, and history recording status.
    Sample output:
    For a rule with modifiers and active state:
    Trigger from another rule:
    Live Watch — watchOn() / watchOff()
    Watch prints a log line immediately every time a rule's condition is evaluated — pass or fail. Use it when you want real-time feedback without needing to dump a buffer later.
    Every trigger now produces a line like:
    Turn it off:
    Watch all rules at once:
    Schedule a watch window from a rule:
    watchOn and historyOn are independent — you can use both on the same rule simultaneously.
    Invocation History — historyOn() / showHistory()
    History records the last N invocations of a rule in a circular buffer. Unlike watch, it doesn't print anything immediately — you dump it on demand with showHistory().
    Start recording:
    Stop recording (buffer is preserved):
    Dump the buffer:
    Sample output:
    All-rules variants:
    Set buffer size at definition time (recording still starts off):
    Scheduled history window:
    Combining Tools
    The debug functions compose freely. A typical investigation pattern:
    Function Reference
    Function Description
    info(rule) Print full rule snapshot: src, triggers, modifier state, history status
    watchOn(rule) Print a log line immediately on every condition evaluation
    watchOff(rule) Stop live logging for this rule
    watchOnAll() Enable live logging for all rules
    watchOffAll() Disable live logging for all rules
    historyOn(rule, size?) Start recording invocations into a circular buffer; resets buffer
    historyOff(rule) Stop recording (buffer is preserved)
    historyOnAll(size?) Start recording on all rules
    historyOffAll() Stop recording on all rules
    showHistory(rule) Print the recorded buffer for this rule
    All functions accept a rule name (string), numeric ID, or the rule object itself.
    Jan I am playing but what ever I do the light does't shine over me.
    Edited by Sjakie
    Fibaro.call
    I have been able to load the version 1.13 into my HC3 but QA crashes with the following error:
    [26.05.2026] [20:44:00] [DEBUG] [QUICKAPP767]: EventRunner 7, v0.1.13
    [26.05.2026] [20:44:00] [ERROR] [QUICKAPP767]: QuickApp crashed
    [26.05.2026] [20:44:00] [ERROR] [QUICKAPP767]: rule.lua:691: attempt to index a nil value (upvalue 'vm')
    I have not been able to understand why...
    Edited by Christb
    13 is an unlucky number. Try 0.1.14
    The error was the order that the QA files are loaded - I didn't see that I had a dependency on the load order and I was always lucky - but you didn't on your HC3.... Anyway, I fixed that now so it should work. Thanks for the patience.
    I need more info. I assume ER7? You need to tell me 6 or 7 as they do have different implementations.
    This works: rule("@19:38 | 178:breached => 496:on")
    This makes no sense: fibaro.call(keuken.Keuken_Spots,"turnOn","Energie");
    turnOn don't take "Energie" as argument.
    I see you load HT. Do you also set it up as variables? I.e..
    local var = er.variables
    for k,v in pairs(HT) do var[k] = v end
    Okay fixed my error.
    give error
    Edited by Sjakie
    Eventrunner fade and dim error
    Hello everyone,
    I have been using ER5 for many years now. It works great for me. Now I would like to switch to ER7.
    In ER5, I have the following function:
    Can I use this in ER7 as well? I can't seem to find the right way to implement it.
    Another Question:
    I use
    Is it no longer possible to create rules with "||...." in ER7?
    give error
    triggerVariables is named triggerVars.
    local triggerVar = er.triggerVars
    The way to patch in setProps commands are not in ER7 in this way.
    You need to do
    1 hour ago, KaWi said:
    Hello everyone,
    Another Question:
    I use
    stdProps is a bit different...
    The ||>> construct requires case ... end around it (ER6 and ER7)
    Thanks for the quick reply 😀.
    Unfortunately, I'm getting an error with the function:
    Jan where to place?
    " {name="Badkamer__Vrij"};"
    Sorry, fixed in previous post. It's not a function def, just a call to er.addStdProp
    28 minutes ago, Sjakie said:
    Jan where to place?
    I don't know/understand. What do you want to accomplish?
    Sorry I want to name that rule as in:
    🔧 EventRunner7 — Adding a Custom Device Property with er.addStdProp
    EventRunner7 comes with a set of built-in device properties you can use in rule conditions, such as value, batteryLevel, dead, and so on. If you need to use a property that is not built-in — for example a sensor's lastBreached timestamp — you can register it yourself with er.addStdProp.
    Once registered, the new property works exactly like the built-in ones: you can read it, trigger on its changes, and use it with multiple device IDs.
    Basic syntax
    The definition table fields:
    • trigger — the HC3 event that fires when the property changes. Usually {type='device', property='...'}.
    • get — called when the rule reads the property value. Receives the definition table and the device id.
    • set — called when the rule assigns a value to the property. Optional.
    • reduce — aggregation function used when the rule references a list of device IDs. table.mapF returns a list of values, table.mapOr returns true if any are true, table.mapAnd returns true if all are true. Optional.
    • setCmd — alternative HC3 action name to use for set. Optional.
    Register the property inside your main(er) callback or in a module with a negative priority (so it is available before rules are compiled).
    Example 1 — reading a sensor timestamp
    Many Fibaro sensors expose a lastBreached property that records the last time they were triggered. It is not a built-in ER7 property, but you can add it:
    The rule fires whenever the HC3 fires a device event with property='lastBreached' for device 42. The getfunction is called when the rule reads 42:lastBreached inside the action.
    Example 2 — a boolean wrapper property
    The built-in value property of a dimmer is a number (0–99). If you want to react to "is the light on or off" as a boolean, you can add a custom property: (note, :isOn is already defined, in a similar way)
    Example 3 — a writable property
    You can also register a set function to allow writing from a rule:
    When to use addStdProp vs a custom PropObject
    addStdProp is the right tool when you are working with standard device IDs and the HC3 property system. The property is always accessed as <deviceId>:propertyName.
    If you need a reactive variable that is not tied to a numeric device ID — for example a weather object, a third-party API, or any other data source — use a custom PropObject instead. That is covered in a separate post.
    🌐 EventRunner7 — Custom Reactive Objects with er.definePropClass
    EventRunner7 lets you create custom reactive objects that can be used in rule conditions just like device properties. These are called PropObjects. Unlike er.addStdProp which extends the built-in device-ID system, a PropObject is a standalone variable that can wrap any data source: the HC3 weather API, a third-party REST service, a virtual sensor — anything you can read from Lua.
    addStdProp vs PropObject — which to use?
    • er.addStdProp — use when you want to add a new property to existing devices. The property is always accessed as <deviceId>:propertyName, e.g. 42:lastBreached. The trigger must be a device event.
    • PropObject — use when the data source is not a numbered device. The object is a named variable, accessed as varName:propertyName, e.g. weather:temp. The trigger can be any HC3 event type (weather, custom-event, global-variable, etc.).
    The four steps
    1. Call er.definePropClass("ClassName") to create the class.
    2. Define an __init method that calls PropObject.__init(self).
    3. Populate the getProp and trigger tables with functions for each property.
    4. Create an instance and store it in er.variables so rules can access it.
    Example — Weather object
    The HC3 has a built-in weather API. Here is how to wrap it as a reactive PropObject with four properties:
    Now you can write rules like this:
    The rule weather:temp < 0 fires every time the HC3 posts a weather event for Temperature. The getProp.temp function is called to read the current value for the condition check.
    Example — Custom REST API object
    PropObjects are not limited to HC3 data. Here is a minimal example wrapping a custom event:
    Adding a set property
    If you want to allow rules to write to a property, add a function to the setProp table:
    Where to define PropObjects
    PropObjects must be defined and instantiated before the rules that use them are compiled. The safest place is in a module with a negative prio value, which runs before your main(er) callback:
    Alternatively, define the PropObject at the start of your main(er) callback, before any rule(...) calls that reference it.
    Summary
    • Use er.definePropClass to create a reactive variable wrapping any data source.
    • Populate getProp, trigger, and optionally setProp tables.
    • Store the instance in er.variables so rules can read and trigger on it.
    • The trigger can be any HC3 event — not just device events.
    • For properties on existing numbered devices, use er.addStdProp instead.
    The same
