    34 minutes ago, Sjakie said:
    Jan no idea where to fix. Have a few in different QA's
    no rule src printed with the error message?
    v0.1.23 should log the offending rule src.
    Jan first time I see this rule disabled?
    This rule looks ok - I tested it myself. No disabling of the rule. Are you sure it's this rule?
    The error should be on the line above...
    Yep that is the rule. There is only one rule with @{05
    I can't scroll back because I restarted HC3
    What is the alternative for "once(.....)"
    Give also error(s)
    Give also error(s)
    once would work as previous. How does your once rule look like?
    Ok, there was a bug introduced in once. Fixed in 0.1.25
    Jan I deleted "once" or replaced with truFor
    sorry I can't show because I am still correcting error's where they come from .....
    post bug fixed in v0.1.26
    will try.
    Excellent error discovering!!!
    Is it possible to mention with device is having  a nil value???
    will try.
    Don't you get the source and a marker on the line below?
    If I run
    rule("a = nil; return a:value")
    I get
    If possible, I write the source line and a  '^' under the problematic part.
    Is it possible to detect in HC3 if light is switched on with Hue app???
    Edited by Sjakie
    Heu app
    It was the comment --fibaro...
    that crashed. Added -- comments in v0.1.28.
    Let me think about the Hue app. You mean turned on from the app instead of from a rule?
    Jan, mostly HC3 is switching the lights, I want to catch the rare occasions when light with Hue app will be switched on/off.
    It will also minimize my debug. lamp:isOn => debug lamp is on. It will give a lot of lines if lamp will dim.
    Thanks for your cooperation.
    If I restart HC3 no error(s)
    So now I must see if all component has been used if some error will occur.
    Thanks for your speedy replies and solutions.
    Well, thank you! When ER7 can run your rules it can run anything :-)
    There is the :manual property that is negative if the script change the state of the device and >= 0 if it was not the script.
    So if another QA or the Hue app changes the state, it's >= 0, if ER7 changes the script it's <0
    Ex.
    The value returned by :manual is the seconds since last changed externally or by ER (but for ER a negative value)
    It only works for commands that becomes a fibaro.call with action  turnOff, turnOn, on, toggle, off, and setValue, and changes the value property of a device.
    On 5/27/2026 at 3:01 PM, jgab said:
    'restart' is a reserved keyword now, and can't be used as the name of a event or variable. ER7 will give a better error message now that the word is reserved.
    There was a bug in all the arm functions, fixed.
    v0.1.17 uploaded.
    I have this rules in ER7 v0.1.27
    and I am getting this error:
    Does this mean that I can no longer restart the QA for nextDST?
    Well, you have to write plugin['restart']()
    ...which is inconvenient. I have renamed the keyword 'restart' to 'single' in v0.1.29, so you are free to use 'restart' as an identifier, and plugin.restart()
    Jan, about the restart it's for summer/winter time or did you implement it in ER7?
    The external Hue is excellent but perhaps a challenge?
    Zithoek_Verlichting  & Licht_Show  are zones.
    In this example I switch Studio what is a room
    Can you separate it or is Hue giving the same signal out?
    Is wday('last') no longer available?
