    Because your vremote variable is undefined (nil).
    The error message could be better so in v0.0.47 it will complain that the variable is nil.
    Hello Jan,
    Fibaro changed the background in debug window into white and the date, QA id also.
    Do you know if it is possible to change it back?
    All my colored debugs are more or les unreadable.
    Thanks in advanced
    Isn’t there a dark mode (skin) option?
    Yes there is but then all screens are black.
    Must get used to it if this the new set up is from Fibaro
    Edited by Sjakie
    Fibaro
    Jan, is it possible to  add what is causing this error?
    Yes, I fix it in next version.
    You have a rule with ".... <X>:<prop>...." where the "object" X is nil. Probably your HT that is faulty or misspelled?
    Jan perhaps my question was not clear.How I can give the ER Qa a self chosen ID visible in Debug?
    When I add child devices I have my QA's at the end of the list.
    for example:  "prefix_ID_name_ID_number"
    Set __TAG to the label ?
    Ex.
    __TAG = "MyER"
    Jan, No debug in  version .48
    Did you set the __TAG and the debug output appears on another label?
    Jan, thanks sorry I did something wrong is fixed now.
    The only problem is the old "Quickapp580" is still visible in Debug drop downlist.
    If click the old notification screen is empty as it should be.
    Restart did not clear the old notification how to get rid of it?
    Edited by Sjakie
    remove
    Ask Fibaro :-)
    hahaha, nice one!
    @jgab
    there is typo in version 0.0.49
    /monthly_2025_10/image.png.4c311ecb973d18bac2ece491c2441bb6.png" />
    Yes,  there was a bug in my release script.
    I've uploaded v0.0.50 where it should be fixed.
    @jgab How to create rule for checking if motion sensor is without moving detection more than 2 days? I would like to change Fibaro Home Profile to Vacation.
    Using of TrueFor is problematic because my Fibaro has problem with stability and every night there is restart (Unexpected error ... )
    Fibaro Home Profile states:
    /monthly_2025_10/image.png.158fb2e5c392ad61faaa39d6704cc1f9.png" />
    I haven't been able to verify it but I think this would work.
    The sensor:last will return time since the sensor changed state (in seconds).
    We .start() the rule so if the sensor is safe it will start to count down (minus the time since the sensor became safe).
    This will allow the QA to restart and continue with the time left up until 2 days...
    If breached and the sensor later becomes safe the rule will trigger and sensor:last should be close to 0 which will give us 2 days...
    There is a more complicated way to solve it by implementing some kind of persistent timer that survives restarts, but it is more prone to errors...
    OK, thanks
    and is there support for home profiles (read/write)?
    13 hours ago, petrkl12 said:
    OK, thanks
    I made a change in v0.0.51 so it may work better for some corner cases in trueFor...
    No, there is no default profile functions. You can add them yourself
