ERUpdater I saw the present version ER qa listed, excellent thanks!
In case of error during reading of rules (ie. some device is nil) - ER6 stop working with error message.
Is it possible to only show error(s) and continue to reading rest of rules and ER6 will continue to work ?
Edited by petrkl12
Jan,
Manny errors:
ERUpdater set older versions under a button, the list becomes verry long.
Is there a possibility to subscribe so we can get a notification there is a new update?
Edited by Sjakie
add error/ ERUpdater
    2 hours ago, Sjakie said:
    Jan,
    Manny errors:
    The first error is from inside of fibaro's own code. Is it ER6 or ERUpdater?
    It seems to be from fibaro.getType(deviceId). I don't use that function in my code. Do you?
    The second error implies that hal.Hal_Verlichting is either an empty table or a
    non strict array. e.g. it contains key=value elements like discussed in your earlier post.
    Yes, ERUpdater is going to be updated...
    JAN, fibaro.getType(deviceId) is correct ,now I know what caused the error >> removed.
    Cleaning all my QA's removing stuff what not helps for a better automation.
    For lights I use xy for color and still bro and transition time what else to use> fibero.call?
    @jgab maybe bug in wnum ?
    error:
    26.09.2025] [07:08:00] [ERROR] [QA_ER6_1551]: [Rule:5]: ["var","wnum"]: Expected number, got: nil (disabling)[26.09.2025] [07:08:00] [ERROR] [QA_ER6_1551]: [Rule:5]: attempt to perform arithmetic on a nil value (local 'arg1'): mod ["var","wnum"] ["const",2] (disabling)
    On 9/25/2025 at 8:42 AM, Sjakie said:
    Jan, fibaro.getType(deviceId) is correct now I know what caused the error >> removed.
    Is there an alternative for using bri and transitiontime except setting in the HUE bridge?
    What Hue QA are you using?
    🚀 EventRunner 6 - Release v0.0.43
    Changes in v0.0.43
    • ♻️ Refactor: add optional name property to rule creation
    • ♻️ Refactor: improve clarity of rule data structure
    •  Feature: add wnum function to computed variables
    • ♻️ Refactor: clean up GVAR function by removing commented code
    • ♻️ Refactor: improve rule index handling
    • ♻️ Refactor: enhance error handling in executeSetProp function
    • ♻️ Refactor: update device creation path handling in createDevice function
    • ♻️ Refactor: update rule execution logic for clarity
    Generated automatically from git commits
    📥 Download
    • GitHub Releases:
    • Direct .fqa files:
    📚 Documentation
    • Full Documentation:
    This release was automatically generated from commit e82bd67
    We can give names to rules now by adding an extra string as first argument
    we can also do
    adding the name as an option last. The first example will just move the string to the name options...
    The rule will log as
    error:
    Yep, wnum was not implemented - is now in v0.0.43
    Jan after update version v0.0.43 in all ER6 QA's. All aa's stopped.
    Still using COH
    Edited by Sjakie
    add COH
    raw get error fixed in v0.0.44
    Jan,
    1:armed == true | 1:armed == false does not work in ER 6 as you mentioned it's working.
    As you can see in debug QA590 is ER6 and QA 598 ER5
    @jgab
    is to possible to add variable (ie. logRule) where will be save rule number + rule name incl. some icons. I would like to use to my log to know which rule is running
    current state:
      rule("wait(00:00:10); log('Starting rule')", name={"Test rule"})
    27.09.2025] [11:18:46] [DEBUG] [QA_ER6_1551]: Starting rule
    new state:
      rule("wait(00:00:10); log(logRule..'Starting rule')", name={"Test rule"})
    [27.09.2025] [11:21:46] [DEBUG] [QA_ER6_1551]: 🎬 [Rule:77 Test rule]: Starting rule
    Edited by petrkl12
    Jan,
    Can I add something to get rid of those errors in all QA's for operating lights in COH?
    22 hours ago, petrkl12 said:
    @jgab
    current state:
    new state:
    So, technically,
    is not a rule. It has no '=>' defining a rule. It's just an statment being evaluated.
    So the options to name it has no effect, as nothing is "remembered" after the expression is evaluated.
    Expressions like these are useful to setup initial values, or trigger rules at startup etc.
    Normally, when the rule function evaluates a statement, it prints the value it returns.
    So ex.
    will produce 2 log statements
    the first being the er log statement, and the second being what the rule(...) evaluated to. In this case it's because log('Hupp'), besides logging it to the console also return the string it logged, so the rule("log('Hupp')") will also return Hupp
    Usually it's convenient to see the result value of a statement, but we can turn it off with
    In this case we will only get one 'Hupp' logged.
    If all your expression do their own logging and you don't care about the return result you can turn it off in er.opts,
    ex.
    or you can make your own expr function, that works like rule but for expressions and turns off the result
    When defining rules, it's a different matter.
    Most of the logging of a rule is controlled by the er.opts table.
    See
    We can control what to log and what icons/emoji to prefix these logs with.
    Some of these opts flags can be functions, and if defined, are called instead of the standard print function. This means ex. that we can have our own function to print when a rule is started. Or we use it as a hook, and just print the standard message and then record somewhere that the rule has started.
    One "hook" I see is missing is when a rule is defined. It always logs using the rule._rule.ruleDefPrefix emoji.
    So, I have added in v0.0.45 the flags er.opts.defined that is by default true and will log rule defined. If false no log.
    If a function will be called with the rule object. There one could add some recording that rule was defined or whatever, and then log.
    If the function returns false/nil ER will continue to log the rule defined with the default message. If it returns true ER will assume that the function decides how to log the defined function (or not).
    Also, in v0.0.45, there is a local variable 'rule' being the rule running.
    Ex.
    37 minutes ago, Sjakie said:
    Jan,
    You are defining a table like
    where bar is nil.
    It can be a misspelling in the HT table. Ex
    Here HT.barr is misspelled HT.bar. HT.barr don't exist and evaluates to nil.
    See if you can recognize the tables from the IDs and where in the code they are defined.
    Jan, your newest version
    Sorry, fixed in 0.0.46
    @jgab, @petrkl12 Thanks both of you to tackle this error.
    Confusing for me was Hue_room with 4 lights gave 4 faults.
    strange token in HomeTable re-added the lights after restore did the trick.
    In ER5 I had a rule trigger for a remote of the form:
    rule([[key = vremote:key =>
    || key == '1:Pressed' >> hL.index = stepUp(hL.index, tS); hL.devices:value = nextValue(hL.index, hL.curve, hL.low, hL.high, tS)
    || key == '2:Pressed' >> hL.index = stepDown(hL.index, tS); hL.devices:value = nextValue(hL.index, hL.curve, hL.low, hL.high, tS)
    || key == '1:HeldDown' >> hL.devices:on; log('isOn hL'); hL.index = currentStep(hL.devices[1]:value, hL.curve, hL.low, hL.high, tS)
    || key == '2:HeldDown' >> hL.devices:off
    With action statements in a case statement. I can see that I need to modify the case statements(s) with an explicit case ... end. The trigger generates an error of "Compiler: 'assign' not allowed in trigger expression at pos 1"
    I can't work out the syntax to trigger on any key press. Is that possible or do I need to have a rule per key:attribute
    You can't have an assignment in the condition/test. This works
    If I use that I get Rule has no triggers 'vremote:key => local key = vremote:key; case || key == '1:Pressed' >> hL.index..'
