    🚀 EventRunner 6 - Release v0.0.16
    Changes in v0.0.16
    •  Feature: add coercion function for comparison operators
    •  :key property for centralSceneEvents - returns "keyId:keyAttribute" to compare with
    • 🐛 improve error handling in tokenizer
    Generated automatically from git commits
    📥 Download
    • GitHub Releases:
    • Direct .fqa files:
    📚 Documentation
    • Full Documentation:
    This release was automatically generated from commit 2fa43d7
    2 hours ago, Sjakie said:
    Error table is nil
    Error
     rule.lua:112: bad argument #2 to 'date' (number has no integer representation)
    Ok, the  rule.lua:112: bad argument #2 to 'date' (number has no integer representation)
    error was because of the bad long date format 12/21/00:00. It should start with a "/" if you don't have the year, like /03/21/00:00
    However the error message was bad. In v0.0.16 the error reporting system is much better (in general for all types of syntax/compiler errors)
    The "Error table is nil" - is it part of some more log?
    When something goes wrong while the rules are running an error message should be logged and the rule is disabled - so it doesn't cause more troubles.
    Jan, in your example sheet you show HT definition and usage like this
    but on other pages you are explaining variable usage, like below
    Let's break this down:
    • rule - Function to define automation rules
    • var - Table for storing variables accessible across all rules
    • triggerVar - Table for variables that can trigger rules when changed
    and its saying, that triggerVars are the ones that can be used as triggers in rules, while vars are globally accessible variables,but in the example above you still define HT table as var.HT and still using its elements in rules as triggers. What am i missing?
    is just a table reference, returning something like 754. So the statement is 754:breached - triggering when device 754 is breached.
    triggerVar.x = 88
    rule("x => log('x is %s',x)")
    will trigger whenever variable x changes values. It will not cause trigger when we initialize it to 88
    but if we do
    rule(2@sunset => x = 42")
    the rule will trigger at sunset.
    So, triggerVar.x = 88 will declare var.x = 88 but the compiler also remembers that it should generate an event when it changes value.
    It actually emits the sourceTrigger {type='trigger-variable',name='x'} in this case.
    triggerVar.x = 88
    but if we do
    so this actually means that every variable delacred as var.x = 88 can also be used as a trigger in any rule.
    Eventualy both work the same way. The only difference is that the latter one will not cause any triger when initializing right?
    The first rule will complain that there is no triggers in the rule. x is just a plain variable.
    The second will work. 'y' is a variable, but also a trigger variable.
    Technically, it is initialized when we do triggerVar.y = 88, and that does not cause any event to be emitted.
    Later if we assign 'y' a value (different from 88) it will emit an event and the rule will trigger.
    🚀 EventRunner 6 - Release v0.0.19
    Changes in v0.0.19
    •  Feature: add uptime tracking and event formatting
    • 🐛 Fix: correct assignment error in parser
    • ♻️ Refactor: improve rule handling and logging
    • 🧪 Test: add usage examples for QuickApp
    •  Feature: add commit message guidelines and VS Code settings
    • 📚 Docs: include examples and formatting rules for conventional commits
    📥 Download
    • GitHub Releases:
    📚 Documentation
    This release was automatically generated from commit 13f3873
    Wooow you release updates faster as I manage!
    Jan, I am on version .18
    If I want to update to version .19 it does't show any ER6 qa's.
    Restarted HC3 version 5.180
    Safari >> nada
    Chrome the same
    deleted ERUpdater nothing changed
    If I install  2 new QA's they will be visible in ERUpdater
    error:
    .start()
    Util.defvar("Hue",Hue)
    No integer no clue what is wrong in ER5 no error
    Error in handler
    Edited by Sjakie
    install 2 new QA's >>visual
    Safari >> nada
    Chrome the same
    error:
    .start()
    Error in handler
    Reload page and press refresh - refresh re-reads the ER6's installed.
    Your error messages are a bit hard to decipher ;-)
    23 minutes ago, Sjakie said:
    There is no Util.* or Util.defvar in ER6. You add the function to er.variables.*
    If you have access to 'er'
    [QUICKAPP540]: ./include/parser.lua:383: attempt to index a nil value (field '_dbg') >> here I have a lot of
    Edited by Sjakie
    removed HUE add QA541
    Jan, ERUpdater still show not all ER6 QA's
    Now it shows only those who I uploaded yesterday.
    So 3 hidden en 3 visible.
    Rereshed a few times no luck
    🚀 EventRunner 6 - Release v0.0.20
    Changes in v0.0.20
    •  Feature: Add addon support and refactor builtins and rules
      • Refactored `builtins.lua` to remove redundant uptime and weather property definitions, now handled by `addons`.
      • Updated `parser.lua` to improve property access handling.
      • Modified `rule.lua` to load rules asynchronously, enhancing startup performance.
    •  Feature: add add-on documentation for EventRunner 6
    • 🐛 Fix: global(name) returns success, message
    • 🐛 Fix: bug in parsing of {<table>}:property <op> <expression>
    📥 Download
    • GitHub Releases:
    📚 Documentation
    This release was automatically generated from commit 90adf52
    I think it's the update of the drop down the has issues - do me a favor and test this.
    Open ERUpdater, and in main replace QuickApp:refreshClicked() with the version below that logs the ER6 it finds in the console. See if it logs all the ER6 ?
    Jan did it.
    still 3 QA's showing.
    Refreshed > nada
    Other browser >> same
    They don't show in the console log? And you are sure that they are ER6 QAs? (It can't upgrade ER5s)
    The way they are found is that they have the property
    You know how to get into swagger and get the device structure and look at the properties?
    Check if your non-recognized QAs has the property....
    Sorry Jan swagger does't work well must wait on new fw. I don't want to use beta.
    After new uploads and copied main in I see now in updater 7 ER6 QA's.
    Sorry I can't help to discover what is wrong.
    No clue what this is?
    ["var","elog"]: Expected function, got: nil (disabling)
    This I don't use anymore
    Edited by Sjakie
    Jan apologize but my swagger does't work properly, ned to wait on fw update. I don't want to use beta.
    I fixed it installed 4 new ER6 and copied old in new.
    Refreshed ERUpdater saw 3 old and 4 new ones  >>changed names >> nothing after refresh.
    Restarted HC3 (is slower as usual)
    Now I see 7 ER6
    Sorry I could not help to get where it's going wrong.
    No red x
    [ERROR] [QUICKAPP545]: [Rule:4]: ["var","elog"]: Expected function, got: nil (disabling)
    [03.09.2025] [07:57:54] [DEBUG] [QUICKAPP545]: Parser: Expected ] at pos 175
    #licht_Hal_Slot_Unsecure =>
    hal.Achterlamp:value = xy=[0.5396,0.4224];
    🚀 EventRunner 6 - Release v0.0.21
    Changes in v0.0.21
    •  Feature: update add-on setup instructions and examples
    • ♻️ Refactor: change loadLibrary function to local scope
    • ♻️ Refactor: improve error handling in rule definitions
    •  Feature: add synchronous HTTP call functionality
    •  Feature: implement HC3 API integration
    • ♻️ Refactor: update HTTP client authorization handling
    • 📚 Docs: add release notes for v0.0.20
    📥 Download
    • GitHub Releases:
    📚 Documentation
    This release was automatically generated from commit 4bab44f
    Now I see 7 ER6
    No red x
    This line has 2 wrongs...
    You are assign :value the result of assigning xy = ...
    Assignment in ER5&ER6 don't return a value.
    Also this is wrong syntax, and was not allowed in ER5 either...
    To create an array use
    xy={0.5396,0.4224}>
    You probably wanted to do
