Jan sorry but I don't get it working.
As mentioned I have a QA named HomeTable  and the info is stored in a Global Variable >> is working in ER 5 with:
    If it works with the code you show there, you must have read in the table into a lua variable named 'HT'.
    Ex.
    local HT = json.decode((fibaro.getGlobalVariable(<name of your HT GV>)))
    So, somewhere in your ER5 code you have something like that?
    Then you loop over that variable and put it in er.variables (or just 'var' if you did, local var = er.variables)
    for k,v in pairs(HT) do var[k]=v end
    That's it. NO er.defvars or er.reverseMapDef....
    Thanks for HT!
    No support for HUE dimmer?
    [QUICKAPP503]: rule.lua:320: Unknown property in getprop trigger: key
    1 minute ago, Sjakie said:
    Thanks for HT!
    You have to show me the rule. Hue is a separate QA these days...
    2 minutes ago, Sjakie said:
    The :key property is not implemented - should be - I 'll add it to my todo list.
    Jn can this cause error in handling?
    same error in handling and not implemented putprop
    Edited by Sjakie
    add put prop
    The ||>> looks different in ER6. See ch. on upgrading ER5 -> ER6.
    The log don't support the #color tag.
    Installation tips
    There is a ERUpdater.fqa QA that can be installed. It allows to upgrade/downgrade EeventRunner 6, and install new copies of EventRunner6.
    The QA shows available versions and installed EventRunner 6 on the HC3.
    Select version and which installed EventRunner 6 you want to upgrade and click "Upgrade"
    Select version and click "Install" if you want to install a new version.
    Button "Refresh" updates the dropdown menus.
    It will download the version from my GitHub and update/replace the files:
    It will leave all other files untouched, including 'main'
    rule.lua:9: bad argument #2 to 'format' (number has no integer representation)
    Jan can I get back color in debug?
    Jan,
    I saw some newer versions.
    I uploaded the 2 ER6 QA's from yesterday.
    If I want to update the Updater does't find them perhaps due to the renaming I did?
    ER6-.......
    You can rename them. The updater have other means to find them.
    I think it's the drop down menu that doesn't update correctly (always a bit buggy). It usually helps if you reload the browser page.
    Error table is nil
    Error
     rule.lua:112: bad argument #2 to 'date' (number has no integer representation)
    Edited by Sjakie
    add error
    29 minutes ago, Sjakie said:
    Error table is nil
    Error
    You must tell me what version you are running
    2 ER-6 Visuable
    1 ER- 6 not visable
    Refreshed browser >> nada
    Switched from Safari >> Google chrome >> nada
    latest version 0.0.14
    @jgab
    The key property is a really needed one. This is one of the reasons i use almost everywhere ER5. Customers installtions where they have 30-40 pcs od 5-6 buttoned wall switches, plus remote controllers to most of them, it is an absolute disaster doing it in some block scenes or other LUA way. Thanks for adding it to ER6
    @Neo Andersson, its on the list see some remark before
    Yeah i saw it, i just wanted to thank to JGAB for adding it
    Jan, must I give you also those error in handling?
    I have a lot of them
    3 QA's with ER6 running with errors --[[blocked]]
    >> will wait till the known issues are solved to continue
    Edited by Sjakie
    blocked
