Jan will copy when error's are back before I change anything. I suspect those errors shows only at the moment the rule is executed.
ErUpdater does't show my Eventrunner QA's again.
What did I do I restored my ER6 QA's after going back to earlier date of the HC3
Edited by Sjakie
ERUpdater
I have re-write all my rules from ER4 to ER6 and it works without any problems with super speed 😀 Thanks @jgab
I have only issue with Nodered. I would like to also use in ER6. How to do it?
I mean ie.
    I
    I mean ie.
    They are not there yet, I will port the nodered functions tomorrow or Saturday.
    ER6 is missing some functions from ER5. I will provide them as "add-ins" which means that you have to add a file to the ER6 QA with the missing functions.
    This file could also be a good place to put your own Lua functions you use in your rules...
    There is some documentation
    There are
    for sync http calls and node-red integration.
    The node-red integration deserve some more documentation but works the same as in ER5
    Jan, unfortunately this error is back.
    bug in ER6
    HT.DetectRestart is on for cca 3 seconds than it's automatically switched to off state.
    In log there is Start test, SwitchUnifi is off - it's OK but everything after wait is not done :(
    I have also tried wait(00:01:00) - same result  - SwitchUnifi is not on and End test is not in log...
    Edited by petrkl12
    @jgab Is it possible to add some summary after loading rules (ie. # rules, # rules with errors, # triggered variables etc.)?
    Is there also way/rule how to send notifcation in case of error in ER6?
    Edited by petrkl12
    The wait bug was introduced with the last wait fix... I have fixed the fix in v0.0.41
    There is an event posted for rule runtime errors
    I will add some more statistics that can be logged. If there is an error while loading rules it stops.
    @jgab In version 0.0.41 it still doesn't work
    Edited by petrkl12
    I think Nodered integration can't work as you have in your example.
    There are minumum two bugs:
    1.
    2.
    Edited by petrkl12
    Jan, if a light switch off I get this error:
    In ERUpdater  you can't see the present version of the QA, should be handy?
    Is it possible that this crash has to do with the lua:311 error because crash comes? after switching off lights
    Edited by Sjakie
    add crash
    Jan the debug order is't  in order of execution.
    First        >>>>> $Bezetting_Toilet >>>> Vrij  (Occupation== Free)
    Second  >>>>> #licht_Toilet_Spaar_Plus        (light dim)
    Third      >>>>> #licht_Toilet_Uit                       (light off)
    remark # is a post
    in version 42 there is still issue with wait(00:01)
    Edited by petrkl12
    It works for me(!)
    00:01 is 1 minute =60 seconds
    00:00:01 is one second.
    remark # is a post
    Events are processed strictly in the order  they are generated.
    If you post an event, other rules may trigger before if their triggering events are already queued up.
    A wait in a rule let other events in queue run before
    33 minutes ago, jgab said:
    It works for me(!)
    Sorry, it's working - my mistake ....
    Edited by petrkl12
    It’s supposed to wait for 1 hour?
    I was playing with wait and I setup 1 hour 😆
    I have some suggestion - It could be perfect to have possibility to setup name for rules - ie. rule('myVar=1', nameRule="Setting variable myVar")
    That name than could be in log
    [21.09.2025] [15:12:07] [DEBUG] [QA_ER6_1551]: 👎 [Rule:14 - Setting variable myVar]
    [21.09.2025] [15:12:08] [DEBUG] [QA_ER6_1551]: 🎬 [Rule:14 - Setting variable myVar]: #device{"id":55,"value":164.1,"old":357.7,"property":"power"}
    Yes, naming rules are on my todo-list.
    ok, thanks
    btw. nodered is working 👍
