cag014 732
If you encounter issues such as slow responses or disconnections with ZigBee devices, particularly after a firmware update or backup recovery, try this suggested fix:
Start the "Add Zigbee Device" process and let it run for about a minute or until the hub stops it. You might need to repeat this process a few times to stabilize the communication.
I personally run this process automatically every three days to maintain stability.
Please note that some problems might not be related to HC3, such as issues caused by distance or faulty devices.
I'm curious if this works for others, so feel free to share your experience. Thank you!
