How to fix the ZigBee instability
If you encounter issues such as slow responses or disconnections with ZigBee devices, particularly after a firmware update or backup recovery, try this suggested fix:
Start the "Add Zigbee Device" process and let it run for about a minute or until the hub stops it. You might need to repeat this process a few times to stabilize the communication.
I personally run this process automatically every three days to maintain stability.
Please note that some problems might not be related to HC3, such as issues caused by distance or faulty devices.
I'm curious if this works for others, so feel free to share your experience. Thank you!
3 answers to this question
I will try this!
How did u automate the process?
    On 9/19/2025 at 7:47 AM, Whswede said:
    I will try this!
    If it works for you,
    I can post my QA for you, or you can find the HTTP command for that using Swagger
    I don't think I need it as the device I have been losing constantly now finally seems to given up all together. No matter what I cannot seem to include it again. Thanks anyway!
