Sonos API Player standalone
INTRODUCTION
Sonos is the ultimate wireless home sound system that brings brilliant sound to all parts of house, room by room. Sonos API Player QA enables Fibaro Home Center 3 to control Sonos Wi-Fi multi-room speakers and show their status using node-sonos-http-api as mediator between Sonos and Fibaro.
PREREQUISITES
  • Fibaro Home Center 3, HC3L or Yubii Home with firmware 5.070 or greater
  • Node.js capable device such as Raspberry PI with installed jishi node-sonos-http-api
  • One or more Sonos Wi-Fi multi-room speaker
FEATURES
  • Support for My Sonos stations and playlists. User can easily get list of My Sonos stations and playlist to QA and start playing from QA or other QA and scene code
  • Support for grouping actions join and leave
  • Support for Spotify, Apple Music and Amazon music
  • Support for text to speech TTS for Google, VoiceRSS and AWS Poly
  • Support for playing clips for e.g. doorbell or alarm functions
  • Supports all standard audio commands PLAY, PAUSE, STOP, PREVIOUS, NEXT, MUTE/UNMUTE, SHUFFLE, REPEAT and CROSSFADE
  • Support for all other functions available by jishi node-sonos-http-api
  • User can restart QA device
  • Debug mode with different levels
  • Multi language support with 25 languages included (see APPENDIX 1 for the list). QA can use HC3 selected language or user can select any other available language. QA will be automatically translated to the selected language
  • User can also setup icons to show current status of the player or leave HC3 default icon
INSTALLATION
UPGRADE
To upgrade from version 1.0 to 1.1 please download this file: Sonos API Player QA v1.1 update.zip Unzip it and copy/paste code for each file as named main, common and app
After saving QA please change settings of QA variables TTSlanguage and/or TTSvoice as necessary.
AVAILABLE DOWNLOAD
  • Sonos API Player QA v1.1
  • User manual EN v1.1
TERMS AND CONDITIONS
DISCLAIMER
VERSION HISTORY
  • 1.1.0 - corrected say and sayall commands language handling error, added Korean language for QA and changed TTS language handling to enable usage of all available languages by selected TTS service.
  • 1.0.0 - First public release
Look and feel:
Spoiler
Enjoy coding and your new Sonos API Player QA! :-)
Sankotronic
Edited by Sankotronic
New version 1.1.0
What's New in Version 1.1.0   See changelog
Changes in version 1.1.0
  • say and sayall commands corrected language handling error
  • added Korean language for QA
  • changed TTS language handling to enable usage of all available languages by selected TTS service
Upgrade from v1.0.0 to v1.1.0
  • From above description text download file Sonos API Player QA v1.1 update.zip
  • unzip and then copy/paste new code to each file as named main, common and app and then save
  • Change settings for QA variable TTSlanguage with appropriate language code for selected TTS service
  • Like 4
  • Thanks 3
Sankotronic
Hello ALL!
This QA must be either that good or not so much used since there is no comments and only 1 review after 120 downloads ?
Anyway, for all those that have mix of Sonos S1 and S2 or just have more than one Sonos system on same home network, here you can find more information how to setup jishi node-sonos-http-api:
Thank you for using Sonos API Player QA and for all support! :-)
Sankotronic
Just to inform you that QA is tested with the latest Sonos OS S2 version 15.8 (build 75145120) for Play 1, Play 3, Sonos One and Sonos Roam and is working properly.
