Showing results for tags 'lamellas positioning'.
Found 3 results
  1. Version 1.1.2
    91 downloads
    INTRODUCTION The script can control all blinds that are changed daily at the same time or at the same event. The script should be called cyclically every minute. For this purpose, for example, the script "Main scene FTBE" from Sankotronic can be used. USAGE In the blind_table add a new line for every blind and every event. The same blind may hold several events or several positions. Call the script cyclically every minute by your script which sets normally the TimeOfDay variable PREREQUISITES Fibaro Home Center 2 COPYRIGHT THIS SOFTWARE IS PROVIDED 'AS-IS', WITHOUT ANY EXPRESS OR IMPLIED WARRANTY. IN NO EVENT WILL THE AUTHOR(S) BE HELD LIABLE FOR ANY DAMAGES ARISING FROM THE USE OF THIS SOFTWARE. Everyone is permitted to copy and distribute verbatim or modified copies of this license document. Permission is granted to anyone to use this software for any purpose, including commercial applications, and to alter it and redistribute it freely. CREDITS Scene Icon designed by Sankotronic and found at Sankotronic scene icon pack 1 1.0.0 Function calculateTime(..) copied from Sankotronic script Main scene FTBE
  2. I have 20 modules which function properly for 3 years. Lately one module does not function. It does get the command (i hear a click) but nothing happens neither when using the switch nor when sending command. The only way to return it to function is running calibration but then after a day or so it lose all functions again. Another issue which again developed lately, multiple shutter modules is that when running scripts the do not set the lamellas to the desired angle. These modules used to work fine. Any ideas?
  3. Hi I have 8 x venetian blinders in my apartment controlled by Fibaro Remote Shutter 2 and HC2. No physical switches have been installed, so the only way I operate them is via app or scenes triggered elswhere from dimmer or relays on the walls - works ok but not very intuitive as I use double/triple clicks for predefined scenes. I would like to add some complex and comfortable solution to control them all them with a remote controller but in more intuitive way. I have found something like this below: 1. https://www.remotec.com.hk/wp-content/uploads/2015/12/ZRC-100-User-Manual_V1.57_20130430.pdf - looks like it support scenes, and multilevel devices but.. I see it too complicated to use it for example for just quick opening and closing a blinder etc. 2. http://www.z-wave.in/shop/smart-remotes/duwi-remote/ - looks much better in term of ergonomy. Will be much quicker to operate devices by my elder parents. 8 groups - with two buttons plus 3 extra scenes but I wonder if I will be able to operate lamellas with that one so that when I hold the button it will move the blinder and stops once released or just fully open/close when triggered no matter how long/short you pushed it. 3. https://www.fakro.pl/att/COMMON/offer/servis/user_manuals/ZWP10_FAKRO.pdf - has 4 groups and 2 channels each (A bit less intuitive than duwi) thus able to control 8 blinders in total - enough for me. Support multilevel (longer click, longer than 0.5s) and basic so I will be able to set lamellas angle as proffered. The only drawback I see, there is no possibility to run a scenes so no option to control let's say a group of blinders in whole room. Have anyone tried to test mentioned controllers, maybe can advise something else to try? I am interested in your experience and opinions. Thanks
