Showing results for tags 'local network'.
  1. Anyone help! after adding some virtual devices the logging from iOS devices was normal... i geed accesss to those new VD to other users, saved it... and then made a backup... suddenly all iOS devices can't connect to HC2... i get the message "trying to reconnect"... i have change the password for my poweruser, erased the app and reinstalled it and i keep getting that message... all in local network and with APP... on browser it logs normally... and in iphone if i turn off wifi and thought browser i go to home.fibaro.com i can login in... its just the apps and in all of the users (different devices) in local netwrok
  2. Hey guys, I'm facing a connection issue with my new HCL. I tried to update to latest firmware, after the HCL restarted, only the power LED is on. HCL is connected directly to router, and the ethernet cable is verified working. I'm unable to detect the HCL on the local network via the Fibaro Finder app even after trying to boot in recovery mode. Any ideas? Thanks!
