Showing results for tags 'plug-in'.
Found 3 results
  1. Hello everybody, I was wondering is it possible to develop a plugin for HC2, I'd like to connect my Sonoff devices to my HC. But i have to use ewelink-API but i can't import it into the Lua code. I've successfully that API into Homey app on Homey pro. I was hoping to do the same with Fibaro Home center. anyone has an idea how this could be done. Thanks in advance
  2. I can't get plug-ins to work on HC2. Loaded Sony TV plug-in and searched for TV with search button in Network configuration. No IP devices comes up on the list. Also manually entered IP address, but plug-in still won't connect to tv. TV is on and on same network as HC2. I can ping the TV ip, so definetely on the network, but HC2 won't find it. Anyone else experienced the same? I have the same issue with a customer and none of their devices show on the device list in LAN network. Please help. I emailed support and no response.
  3. Gondo
    Plug-ins
    Hello, I'm just deciding which gateway I should buy - HC 2 or HC Lite. I don't need voice control, VOIP, master controller or LUA. I plan connect 5 thermostats, 7 blind controllers, some door and window sensors, 2 water leak sensors, sliding gate, 3 RGBW controllers and maybe some power outlets. The only difference between HC 2 or HC Lite I've found are plug-ins. But I didn't find any info about them. Are they important? What are plug-ins for? The price of HC 2 is more than double than HC lite. Are the plug-ins worth for this price?
