Showing results for tags 'single switch 2'.
Found 3 results
  1. Hi, I've the classic doorbell and I should like to know the automatization of the doorbell when the doorbell is played I create action in my Fibaro HCL but I don't know if Fibaro single switch is recommended with the doorbell or need another device by Fibaro?
  2. This is my last attempt to find an answer for a problem that keeps me busy for some months now. So, please Fibaro guru help me before i'm throw away everything. I want to switch one light on and off. This light has multiple push switches. Not standard On/Off switches, but switches that give an impulse to the EPN 520. And this relais is turning the lamp on and off. I want all this being handled remotely by a Single switch 2 and keep of course the other switches. (see attached Schema). I already saw an item on this to replace EPN520 completely, but this is not th
  3. Hi there i have had my home center lite for a few years now without any problems. all my devices are fibaro single and double siwtches. i recently purchased a single switch 2 - FGS213. It is correctly wired but it cannot be discovered by the system. i don’t know what do. I tried everything. i brought the home center as close as possible, I tried using the reset button on the module and nothing. can some one tel me what I’m doing wrong? many thanks.
