Showing results for tags 'somfy rts'.
Found 4 results
  1. Hi guys, I am considering Fibaro as my home automation platform and am I wondering if it will work with my Somfy RTS blinds. I searched the forum, but found only old threads that mentions either Somfy Z-WAVE integration module that is sold only in US and no one apparently tested if th works with Fibaro or use something like RFXtrx433E that apparently can work with Fibaro using RabsPI as bridge. So my question is if something changed or to be more precise what is the best way to implement Somfy RTS into Fibaro.
  2. Hello, I have somfy glydea ultra 60e rts installed for curtains on Walli Roller Shutter. Previously, on Fibaro Roller Shutter module, it worked perfectly. However, on the roller shutter, the curtain wont open/close until i pull the curtain slightly. Secondly, how can i keep the Roller Shutter ON as when it goes to standby, the motor cannot be controlled Walli Roller Shutter on Somfy RTS.mp4
  3. Hello everyone, I just got in my new flat and decided to set-up my domotic apparatus starting from a Yubii Home hub. No issues with dimmers, door/window and smoke sensors. The problem is that my flat was pre-equipped with Somfy RTS shutters and a Danfoss Ally radiator hub (Zigbee protocol), which unfortuantely are not comatible with the Z-Wave protocol. I have been looking around to understand what could be the easiest course of action to controll all devices from my Yubii Home box. From my understanding, either a Jeedom or an Eedomus hub, along with a RFXCom module, should do the trick for both the shutters (hence the RFXCom module) and the radiator hub. As I'm not an expert however, I was hoping that someone here could either confirm the above makes sense or propose an alternative course of action. Thank you in advance for your help!
  4. Witam, czy ktoś z szanownych forumowiczów zechce pomóc i opowiedzieć jak sterować za pomocą Fibaro roletami SOMFY Teraz sterowanie odbywa się tylko za pomocą pilota, który ma przyciski „ Up ”, „ Down ” i „ My ” (zapisana ulubiona pozycja) + przycisk do wyboru która roleta steruje w danej chwili - max można sterować tym pilotem 4 roletami Konkretnie: mam dostęp tylko do kabla zasilającego i pilota, którym teraz można sterować roletami (nie ma żadnych innych przycisków sterujących) chodzi o sterowanie 4 rolety a w przyszłości 7 pilot wyglada tak: https://e-rolety.eu/userdata/gfx/c4a4043bff1944051ee88625eb86d7d2.jpg z góry dziękuję za pomoc, Marcin
