Hi
Bought a new sonos 5 II today and every thing working fine whith my iphone, but when i would like to connect it to Fibaro it doesnt work
The sonos 5 is connected with wifi and i have recerved a IP for it, so it will not change
Problem 1
i am loading sonos plugin 1.0 at fibaro HC2 4.100 . Then i press search i get " Unfortunately there are no results for device search "
If i point the plugin direct to IP (not searching) it will connect and i got the basic functions (play pause volume ...)
Problem 2
I am trying to configure the VD from Krikroff pointing the VD to "ip" and port 80 (i can ping sonos speaker)
In debug mode the logg says "comunication error"
[DEBUG] 09:37:38: -------------------------------------------------------------------------
[DEBUG] 09:37:38: -- HC2 Toolkit Framework version 1.0.6
[DEBUG] 09:37:38: -- Current interpreter version is Lua 5.1
[DEBUG] 09:37:38: -- Total memory in use by Lua: 226.89 Kbytes
[DEBUG] 09:37:38: Toolkit.Debug loaded in memory...
[DEBUG] 09:37:38: Benchmark [Toolkit.Debug lib]: elapsed time: 0.000 cpu secs
[DEBUG] 09:37:38: Toolkit.Collections.Queue loaded in memory...
[DEBUG] 09:37:38: Benchmark [Toolkit.Collections.Queue lib]: elapsed time: 0.000 cpu secs
[DEBUG] 09:37:38: Toolkit.Net loaded in memory...
[DEBUG] 09:37:38: Benchmark [Toolkit.Net lib]: elapsed time: 0.000 cpu secs
[DEBUG] 09:37:38: Toolkit.Xml loaded in memory...
[DEBUG] 09:37:38: Benchmark [Toolkit.Xml lib]: elapsed time: 0.010 cpu secs
[DEBUG] 09:37:38: Toolkit.HttpUtility loaded in memory...
[DEBUG] 09:37:38: Benchmark [Toolkit.HttpUtility lib]: elapsed time: 0.000 cpu secs
[DEBUG] 09:37:38: -- SONOS Advanced Remote version 1.0.0
[DEBUG] 09:37:38: SONOS Advanced Remote V 1.0.0 loaded in memory...
[DEBUG] 09:37:38: Benchmark [SONOS Advanced Remote V 1.0.0 lib]: elapsed time: 0.000 cpu secs
[DEBUG] 09:37:38: HC2 start script at Sat Dec 31 09:37:38 2016
[DEBUG] 09:37:38: Get status topology, look for speakers IP
[DEBUG] 09:37:38: Communication error code: 2
[DEBUG] 09:37:38: retry #0
Anyone ?
